Hi
Iâm trying to get AIO running behind a reverse proxy in docker. I also want to host a website so I want the reverse proxy in a separte container I can use for other services.
I followed the following and got Nextcloud up and running without Talk or Imaginary:
This uses lucaslorentz/caddy-docker-proxy with labels in the destination stacks to populate the Caddy file which seems like a good way of doing it. I have not managed to find documentation which explains how to create a Caddy file manually (file name, extension and location?).
https://github.com/lucaslorentz/caddy-docker-proxy
I have attempted to add the labels and network from tmo1âs tutorial to the AIO docker-compose.yml which has resulted in this Nextcloud-AIO dockercompose.yml:
version: "3.8"
volumes:
services:
nextcloud:
restart: always
volumes:
#ports:
# - 80:80 # Can be removed when running behind a web server or reverse proxy (like Apache, Nginx and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
# - 8080:8080
# - 8443:8443 # Can be removed when running behind a web server or reverse proxy (like Apache, Nginx and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
# environment: # Is needed when using any of the options below
# - AIO_DISABLE_BACKUP_SECTION=false # Setting this to true allows to hide the backup section in the AIO interface.
- APACHE_PORT=11000 # Is needed when running behind a web server or reverse proxy (like Apache, Nginx and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
- APACHE_IP_BINDING=127.0.0.1 # Should be set when running behind a web server or reverse proxy (like Apache, Nginx and else) that is running on the same host. See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
# - COLLABORA_SECCOMP_DISABLED=false # Setting this to true allows to disable Collabora's Seccomp feature. See https://github.com/nextcloud/all-in-one#how-to-disable-collaboras-seccomp-feature
# - NEXTCLOUD_DATADIR=/mnt/ncdata # Allows to set the host directory for Nextcloud's datadir. See https://github.com/nextcloud/all-in-one#how-to-change-the-default-location-of-nextclouds-datadir
# - NEXTCLOUD_MOUNT=/mnt/ # Allows the Nextcloud container to access the chosen directory on the host. See https://github.com/nextcloud/all-in-one#how-to-allow-the-nextcloud-container-to-access-directories-on-the-host
# - NEXTCLOUD_UPLOAD_LIMIT=10G # Can be adjusted if you need more. See https://github.com/nextcloud/all-in-one#how-to-adjust-the-upload-limit-for-nextcloud
# - NEXTCLOUD_MAX_TIME=3600 # Can be adjusted if you need more. See https://github.com/nextcloud/all-in-one#how-to-adjust-the-max-execution-time-for-nextcloud
# - NEXTCLOUD_MEMORY_LIMIT=512M # Can be adjusted if you need more. See https://github.com/nextcloud/all-in-one#how-to-adjust-the-php-memory-limit-for-nextcloud
# - NEXTCLOUD_TRUSTED_CACERTS_DIR=/path/to/my/cacerts # CA certificates in this directory will be trusted by the OS of the nexcloud container (Useful e.g. for LDAPS) See See https://github.com/nextcloud/all-in-one#how-to-trust-user-defiend-certification-authorities-ca
# - NEXTCLOUD_STARTUP_APPS=deck twofactor_totp tasks calendar contacts # Allows to modify the Nextcloud apps that are installed on starting AIO the first time. See https://github.com/nextcloud/all-in-one#how-to-change-the-nextcloud-apps-that-are-installed-on-the-first-startup
# - NEXTCLOUD_ADDITIONAL_APKS=imagemagick # This allows to add additional packages to the Nextcloud container permanently. Default is imagemagick but can be overwritten by modifying this value. See https://github.com/nextcloud/all-in-one#how-to-add-os-packages-permanently-to-the-nextcloud-container
# - NEXTCLOUD_ADDITIONAL_PHP_EXTENSIONS=imagick # This allows to add additional php extensions to the Nextcloud container permanently. Default is imagick but can be overwritten by modifying this value. See https://github.com/nextcloud/all-in-one#how-to-add-php-extensions-permanently-to-the-nextcloud-container
# - NEXTCLOUD_ENABLE_DRI_DEVICE=true # This allows to enable the /dev/dri device in the Nextcloud container which is needed for hardware-transcoding. See https://github.com/nextcloud/all-in-one#how-to-enable-hardware-transcoding-for-nextcloud
# - TALK_PORT=3478 # This allows to adjust the port that the talk container is using.
# - WATCHTOWER_DOCKER_SOCKET_PATH=/var/run/docker.sock # Needs to be specified if the docker socket on the host is not located in the default '/var/run/docker.sock'. Otherwise mastercontainer updates will fail. For macos it needs to be '/var/run/docker.sock'
# networks: # Is needed when you want to create the nextcloud-aio network with ipv6-support using this file, see the network config at the bottom of the file
# - nextcloud-aio # Is needed when you want to create the nextcloud-aio network with ipv6-support using this file, see the network config at the bottom of the file
networks:
caddy:
ipv4_address: 172.16.0.7
labels:
caddy: nextcloud.example.nz
caddy.reverse_proxy: "{{upstreams}}"
# see: https://github.com/lucaslorentz/caddy-docker-proxy/issues/114
caddy.header: /*
# see: https://docs.nextcloud.com/server/23/admin_manual/installation/harden_server.html#enable-http-strict-transport-security
caddy.header.Strict-Transport-Security: '"max-age=15552000;"'
# see: https://docs.nextcloud.com/server/23/admin_manual/issues/general_troubleshooting.html#service-discovery
# https://github.com/lucaslorentz/caddy-docker-proxy/issues/222
caddy.rewrite_0: /.well-known/carddav /remote.php/dav
caddy.rewrite_1: /.well-known/caldav /remote.php/dav
environment:
# See: https://hub.docker.com/_/nextcloud/
- APACHE_DISABLE_REWRITE_IP=1
# See: https://github.com/nextcloud/documentation/issues/7005
# and: https://old.reddit.com/r/NextCloud/comments/s3skdn/nextcloud_behind_caddy_as_a_reverse_proxy_using/hsnj5wh/
- TRUSTED_PROXIES=172.16.0.6
# Optional: Caddy reverse proxy. See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
# You can find further examples here: https://github.com/nextcloud/all-in-one/discussions/588
networks:
caddy:
external: true
and this Caddy docker-compose.yml
version: "3.7"
services:
caddy:
# see here for guidance on which image / tag to choose:
# https://github.com/lucaslorentz/caddy-docker-proxy#docker-images
image: lucaslorentz/caddy-docker-proxy:2.4.0
ports:
- 80:80
- 443:443
environment:
- CADDY_INGRESS_NETWORKS=caddy
networks:
caddy:
ipv4_address: 172.16.0.6
volumes:
- /var/run/docker.sock:/var/run/docker.sock
- caddy_data:/data
restart: unless-stopped
networks:
caddy:
external: true
volumes:
caddy_data: {}
I am receiving a redirected too many times error which I understand means Caddy is sending a http request to a https port on AIO but I donât know how to fix it and I havenât found a reverse proxy tutorial for AIO that I can get working.
Any help fixing this or directions to a working AIO reverse proxy tutorial preferably which doesnât have the proxy in the same stack or on the host would be greatly appreciated.
Thanks
Craig
