- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
replace me
replace me
replace me
replace me
- PHP version (e.g, 8.3):
replace me
replace me
replace me
replace me
replace me
After following the official Guide for AIO docker installation on newly installed Ubuntu 25.04, I face the reproducible problem of getting this Error message in docker on first login to the Web Interface:
PHP message: Could not start domaincheck container: Could not start container nextcloud-aio-domaincheck: {“message”:“failed to set up container networking: driver failed programming external connectivity on endpoint nextcloud-aio-domaincheck (f8e0f5184da32e57fec466db9b587ece92ff264d2a70e9cb1ab5aa1165138669): failed to bind host port for 0.0.0.0:443:172.18.0.3:443/tcp: address already in use”}
In the following I get
Domaincheck container is not running
and I am advised for some other reverse proxy setup modifying APACHE_PORT. But this installation is thought to work without reverse proxy. So everyone not using a reverse proxy setup may face this problem.
PASTE HERE
PASTE
PASTE HERE
PASTE HERE
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
