Nextcloud AIO borg backup issue
Hi folk!
I’ve problems with backup in my NC AIO installation.
Yesterday I’ve done a bckup before update to AIO version 5.0.0, and during the operation the electricity has gone out.
After I try to do the bkup again but the log say ā€œFailed to create/acquire the lockā€ to /root/.cache/borg…
so I try to update the mastercontainer and it gone well and now it’s perfectly run.
But the backup issue remain.
I attempted to unlock with borg break-lock via CLI and than from AIO interface I done a check of my previous backup.
The check is ok but the Backup restore combo box is empty e backup problem remain.
I’m not expert in this stuff.
Someone can help me plz?
thnks
Hi, can you check if this helps?
GREAT!!!
this no only Help…this is the SOLUTION
Thank a lot
Augusto :smile:
