Trying to switch to AIO to get a more robust experience, till now I used a manual install. I got the AIO running behind traefik proxy, verified the domain and setted up the containers to pull but the apache container is giving me problems.
Output of docker exec -it nextcloud-aio-mastercontainer docker pull nextcloud/aio-apache:latest
failed to register layer: unlinkat /usr/local/apache2/cgi-bin: invalid argument
Output of docker logs nextcloud-aio-mastercontainer
Trying to fix docker.sock permissions internally...
Creating docker group internally with id 998
Initial startup of Nextcloud All-in-One complete!
You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
E.g. https://internal.ip.of.this.server:8080
If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
https://your-domain-that-points-to-this-server.tld:8443
{"level":"info","ts":1705649233.8632507,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[Fri Jan 19 07:27:13.891420 2024] [mpm_event:notice] [pid 114:tid 140123072736072] AH00489: Apache/2.4.58 (Unix) OpenSSL/3.1.4 configured -- resuming normal operations
[Fri Jan 19 07:27:13.892771 2024] [core:notice] [pid 114:tid 140123072736072] AH00094: Command line: 'httpd -D FOREGROUND'
[19-Jan-2024 07:27:14] NOTICE: fpm is running, pid 122
[19-Jan-2024 07:27:14] NOTICE: ready to handle connections
NOTICE: PHP message: Slim Application Error
Type: Exception
Code: 0
Message: Could not pull image nextcloud/aio-apache:latest. Please run 'sudo docker exec -it nextcloud-aio-mastercontainer docker pull nextcloud/aio-apache:latest' in order to find out why it failed.
File: /var/www/docker-aio/php/src/Docker/DockerActionManager.php
Line: 590
Trace: #0 /var/www/docker-aio/php/src/Controller/DockerController.php(54): AIO\Docker\DockerActionManager->PullImage(Object(AIO\Container\Container))
#1 /var/www/docker-aio/php/src/Controller/DockerController.php(202): AIO\Controller\DockerController->PerformRecursiveContainerStart('nextcloud-aio-a...', true)
#2 /var/www/docker-aio/php/src/Controller/DockerController.php(182): AIO\Controller\DockerController->startTopContainer(true)
#3 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(38): AIO\Controller\DockerController->StartContainer(Object(GuzzleHttp\Psr7\ServerRequest), Object(GuzzleHttp\Psr7\Response), Array)
#4 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(358): Slim\Handlers\Strategies\RequestResponse->__invoke(Array, Object(GuzzleHttp\Psr7\ServerRequest), Object(GuzzleHttp\Psr7\Response), Array)
#5 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(65): Slim\Routing\Route->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#6 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(65): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#7 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(315): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#8 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(68): Slim\Routing\Route->run(Object(GuzzleHttp\Psr7\ServerRequest))
#9 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(476): Slim\Routing\RouteRunner->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#10 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(168): Slim\Csrf\Guard->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Slim\Routing\RouteRunner))
#11 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(115): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#12 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(121): Slim\Views\TwigMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#13 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(38): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#14 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(269): AIO\Middleware\AuthMiddleware->__invoke(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#15 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(76): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#16 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(121): Slim\Middleware\ErrorMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#17 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(65): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#18 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(199): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#19 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(183): Slim\App->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#20 /var/www/docker-aio/php/public/index.php(185): Slim\App->run()
#21 {main}
Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
