Hello
I am facing an issue that i never encounter before.
Trying to deploy nextcloud-aio on an ubuntu CT (on proxmox) via ansible.
First i provision the LXC, then i install docker-ce within it, and then i deploy the nextcloud/all-in-one image with the correct parameters :
- name: Deploy Nextcloud instance
community.docker.docker_container:
image: nextcloud/all-in-one
restart_policy: always
ports:
- 8080:8080
volumes:
env:
APACHE_PORT: "11000"
APACHE_IP_BINDING: "0.0.0.0"
The weird thing is as soon as i go to the AIO-ADMIN on port 8080, i have at the top of the page this warning :
Warning : Undefined array key 1 in /var/www/docker-aio/php/src/Docker/DockerActionManager.php on line 751
Everything seems working good, except that i have some performances issues.
Is there anything to be done ?
Please let me know how to provide you any logs or information
Thanks a lot
