I installed nextcloud on my rasberry pi 4 2gb runing rasbian i can acces nextcloud with http but when i use https i can make a secure connection but get a 404 not found error
welcome to the user-forum of NC.
I suggest searching said forum first and then opening a new thread. I’m sure there would have been helpful hints on here for your problem.
one of it might be your overwrite.cli.url in your config.php - it should point to your URL and not to your local IP. PLUS it should be https…
I changed my config, same error.
I also could not find any posts having the same problem.
maybe you want to take a look here?
https://docs.nextcloud.com/server/latest/admin_manual/installation/source_installation.html#apache-web-server-configuration
IT WORKS !!! So the problem was that the default virtualhost file uses the correct dir /etc/www/html/
but ssl config file uses /etc/www/html/nextcloud wich does not exist. I am so happy and i wuld like to thank eveyone who contrubuted to NextCloud
