Nextcloud 32 + OnlyOffice -- "Download with invalid jwt" / "Track with invalid jwt in body"
I am struggling since days and running into a persistent JWT issue between Nextcloud 32.0.5
and OnlyOffice Document Server (Docker) and would appreciate
guidance from someone familiar with the internal JWT validation logic.
Environment
  • Version: 32.0.5
  • OS: Debian (DietPi on a Odroid HC4)
  • Webserver: NGINX
  • PHP: 8.4 (php8.4-fpm)
  • OnlyOffice App: 9.12.0
OnlyOffice
  • Document Server running in Docker
  • Docker IP: 172.17.0.2
  • Host public IP: ExternalIP
  • OS: Debian 11
Problem
When opening or editing documents, I get the following errors in
Nextcloud:
1) Health check
[onlyoffice] getConvertedUri on check error
2) Callback
[onlyoffice] Track with invalid jwt in body
POST /index.php/apps/onlyoffice/track
3) Download
[onlyoffice] Download with invalid jwt
GET /index.php/apps/onlyoffice/download?doc=...
JWT Configuration
OnlyOffice local.json
"token": {
  "enable": {
    "request": {
      "inbox": true,
      "outbox": true
    "browser": true
  "inbox": {
    "header": "Authorization",
    "inBody": false
  "outbox": {
    "inBody": false
The secret is correctly set in local.json and matches the one
configured in Nextcloud.
Nextcloud OCC settings
occ config:app:get onlyoffice jwt_secret
occ config:app:get onlyoffice jwt_header
occ config:app:get onlyoffice jwt_header_key
Result:
  • jwt_secret → correct and matches OO
  • jwt_header → Authorization
  • jwt_header_key → Bearer
NGINX (Nextcloud)
Authorization header is passed to PHP-FPM:
fastcgi_param HTTP_AUTHORIZATION $http_authorization;
Special locations for OnlyOffice endpoints:
location = /index.php/apps/onlyoffice/track {
    include fastcgi_params;
    fastcgi_param SCRIPT_FILENAME $document_root/index.php;
    fastcgi_buffering off;
    fastcgi_pass unix:/run/php/php8.4-fpm.sock;
Body buffering disabled for callback route.
What has been verified
  • System time synchronized (CET vs UTC difference understood)
  • JWT secret identical on both sides
  • inBody set to false on OnlyOffice
  • Header mode set to Authorization/Bearer
  • No reverse proxy between systems
  • Direct curl from OO container to NC works (HTTP 200/403 as expected
    depending on endpoint)
Example from OO container:
docker exec onlyoffice_server curl -i https://cloud.trialogevent.de/index.php/apps/onlyoffice/empty
Returns 403 (expected without valid token).
Question
At this point, it looks like:
  • Either Nextcloud signs JWT differently than OnlyOffice expects
  • Or OnlyOffice validates a different payload format than NC 32 sends
  • Or something changed in NC32 JWT handling compared to NC30 (which
    worked)
Has anyone successfully run Nextcloud 32 + OnlyOffice (latest) with
header-based JWT (Authorization: Bearer) and inBody=false?
Is there any known change in JWT validation logic in recent Document
Server versions?
Any insight into what specifically causes Download with invalid jwt
would be greatly appreciated.
Thank you.
No one has any idea?
