- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can.
30.0.5
Ubuntu 22.04
Apache from docker
Nginx in router
- PHP version (e.g, 8.3):
PHP from docker
Yes
After transition from Nextcloud AIO working instance to Nextcloud docker instance
Nextcloud docker
No
Migrated AIO instance to Nextcloud docker (community). After migration, all users (total 4) gets logged out at same time from all different Nextcloud client on daily cadence.
Docker is running on Ubuntu and is behind nginx reverse proxy which is installed in openwrt router.
- Migrate from AIO instance to docker
- Retain same config.php except for aio specific entries
- Continue to use same nginx configuration as in AIO instance
- Login to Nextcloud client like iOS, web, Android, Windows with login password / app password.
Expected result:
User to be logged in different client / web unless there is no session activity and session time out.
Actual result:
All users that uses this server gets logged out from all clients on daily cadence. All previously generated app tokens get invalidated.
Please provide the log entries from your Nextcloud log that are generated during the time of problem (via the Copy raw option from Administration settings->Logging screen or from your nextcloud.log
located in your data directory). Feel free to use a pastebin/gist service if necessary.
[core] Warning: Login failed: 'user' (Remote IP: '192.168.1.8')
GET /ocs/v2.php/apps/notifications/api/v2/notifications?format=json
from 192.168.1.8 by user at Jan 18, 2025 at 9:07:40 PM
PASTE
Nginx configuration:
server {
listen 80;
listen [::]:80; # comment to disable IPv6
if ($scheme = "http") {
listen router_ip:443 ssl;
listen 443 ssl http2; # for nginx versions below v1.25.1
listen [::]:443 ssl http2; # for nginx versions below v1.25.1 - comment to disable IPv6
server_name cloud.domain.tld;
# Logging
access_log syslog:server=ip:port,facility=local7,tag=nginx,severity=info;
error_log syslog:server=ip:port,facility=local7,tag=nginx,severity=error;
# Prevent nginx HTTP Server Detection
server_tokens off;
# Add HSTS header
add_header Strict-Transport-Security "max-age=31536000; includeSubDomains; preload" alwa
location / {
proxy_pass http://192.168.1.5:8888$request_uri;
proxy_set_header X-Forwarded-Port $server_port;
proxy_set_header X-Forwarded-Scheme $scheme;
proxy_set_header Accept-Encoding "";
proxy_set_header Host $host;
client_body_buffer_size 512k;
proxy_read_timeout 86400s;
client_max_body_size 0;
# Websocket
proxy_http_version 1.1;
proxy_set_header Connection $connection_upgrade;
location = /.well-known/carddav { return 301 /remote.php/dav/; }
location = /.well-known/caldav { return 301 /remote.php/dav/; }
location /.well-known/webfinger { return 301 /index.php/.well-known/webfinger;}
location /.well-known/nodeinfo { return 301 /index.php/.well-known/nodeinfo;}
The output of occ config:list system
or similar is best, but, if not possible, the contents of your config.php
file from /path/to/nextcloud
is fine (make sure to remove any identifiable information!):
"apps_paths": [
"url": "\/apps",
"writable": false
"url": "\/custom_apps",
"writable": true
"redis": {
"port": 6379
"overwritehost": "cloud.domain.tld",
"overwriteprotocol": "https",
"localhost",
"cloud.domain.tld"
"dbtype": "pgsql",
"version": "30.0.5.1",
"overwrite.cli.url": "https:\/\/cloud.domain.tld\/",
"dbport": "",
"loglevel": 2,
"log_type": "file",
"log_rotate_size": "10485760",
"log.condition": {
"apps": [
"admin_audit"
"upgrade.disable-web": true,
"mail_smtpmode": "smtp",
"activity_expire_days": "30",
"share_folder": "\/Shared",
"htaccess.RewriteBase": "\/",
"mail_sendmailmode": "smtp",
"twofactor_enforced": "true",
"admin"
"default_phone_region": "CA",
"dbpersistent": false,
"appsallowlist": false,
"mail_smtpport": "587",
"mail_smtpauth": 1,
"mail_smtphost": "***REMOVED SENSITIVE VALUE***"
- activity: 3.0.0
- admin_audit: 1.20.0
- bookmarks: 15.0.5
- bruteforcesettings: 3.0.0
- calendar: 5.0.9
- comments: 1.20.1
- contacts: 6.1.3
- contactsinteraction: 1.11.0
- dashboard: 7.10.0
- dav: 1.31.1
- files: 2.2.0
- files_downloadlimit: 3.0.0
- files_fulltextsearch: 30.0.0
- files_pdfviewer: 3.0.0
- files_reminders: 1.3.0
- files_sharing: 1.22.0
- files_trashbin: 1.20.1
- files_versions: 1.23.0
- flow_notifications: 1.10.1
- fulltextsearch: 30.0.0
- fulltextsearch_elasticsearch: 30.0.0
- groupfolders: 18.0.8
- impersonate: 1.17.1
- logreader: 3.0.0
- notifications: 3.0.0
- notify_push: 1.0.0
- oauth2: 1.18.1
- password_policy: 2.0.0
- privacy: 2.0.0
- provisioning_api: 1.20.0
- recommendations: 3.0.0
- related_resources: 1.5.0
- serverinfo: 2.0.0
- settings: 1.13.0
- sharebymail: 1.20.0
- support: 2.0.0
- text: 4.1.0
- theming: 2.5.0
- twofactor_totp: 12.0.0-dev
- viewer: 3.0.0
- workflowengine: 2.12.0
### Tips for increasing the likelihood of a response
* Use the `preformatted text` formatting option in the editor for all log entries and configuration output.
* If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
* Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
