I’ve been trying to figure out how Thunderbird wizard with auto-discovery works with calendars. I asked about this mechanism on Thunderbird forum but without answer.
Maybe You guys have an answer.
Does it work ? What kind of solutions it needs ? Some dns records to search for caldav calendars published on nextcloud ?
I would appreciate any help pointing me to this topic
Regards.
AFAIK autodiscovery does not work out of the box with Thunderbird. I would recommend using the following two addons in order to add your Nextcloud calendar and contacts to Thunderbird:
