Fixed with the js file. Thanks
Same error here. Interestingly, if I share a pdf via link to a random colleague they can open the pdf no problem.
Fresh install on Ubuntu Server 20.04, Nextcloud 21.0.2.1 (no docker, no snap).
Same problem here. Updated to verson 21.0.2 a few days ago.
No snap or docker. Ubuntu Server installation.
Did not want to open a new issue, BUT: I am running into the same error but only with older pdfs that sit on my instance for more than 4 years.
What is the culprit for that behaviour? Does that mean the new PDF Viewer script is not compatible with older versions of a PDF file… that would be a nuisance to me…
Which nc version are you using?
