Nextcloud 20 upgrade FAIL
@Baggers did you this?
I only had 2 that I could see I got loads of fails when doing the update but yes I just enabled both of them. Im probably going to end up redoing the whole thing if I dont get the core apps when the server comes back up
I did it - but id does not work.
Even if you enable them the icons DO NOT appear in the tool bar…It’s an utter mess…
Nextcloud is turning into a MONSTER application - but mostly I want a RELIABLE calendar, contacts, tasks…There is not point doing rocket scinece if the basics are not working properly …
The only option for me is to revert to NC19:
  • restore one week old (ie lose one weeks data) backup ov NC19
  • restore the config fron one week ago
  • REvert the Pg database fo NC19 schema…
  • BLOCK all updates for nextcloud - from docker and from app itself…
Hours of wated time…All I want is a calender and contacts…!!
lol - All Sizzle (new dashboard) and no Bang !
I already gave you the links to the release files for the apps. Place them into apps/ and you are good.
This is obviously not the case. The upgrade fails and leaves things in a broken state. You cannot simply just remove the .state file to get things back either. You have to restore from backups.
Sorry for that, it is OK for me as explained, maybe another issue?
