Nextcloud version: 20.0.2
Operating system and version: Armbian 20.11
Apache or nginx version: nginx 1.14.2
PHP version: 7.3
Since I upgraded NC from 10.0.5 to 20.0.2, it tries to use the Noto Emoji font in certain parts, where it should not. For example, in the Settings overview I see this:
If I inspect the element and remove 'Noto Color Emoji' from css/core/6be2-396b-css-variables.css with my browser, I get the correct text render. As you can see, the exaggerated spacing is gone and the arrow is not an emoji anymore:
Is this the first time you’ve seen this error?: Y
- Install Nextcloud 20
- Browse your NC instance with Noto Emoji installed on your system
'instanceid' => '',
'passwordsalt' => '',
'secret' => '',
0 => '',
'datadirectory' => '/media/extData/ncdata',
'version' => '20.0.2.2',
'overwrite.cli.url' => '',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => '',
'dbpassword' => '',
'redis' =>
'port' => 0,
'timeout' => 0.0,
'theme' => '',
'loglevel' => 2,
'mail_smtpmode' => 'sendmail',
'mail_domain' => '',
'updater.secret' => '',
'app_install_overwrite' =>
0 => 'calendar',
