CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
383f1a41007c nextcloud/aio-apache:latest "start.sh /usr/bin/s…" 2 hours ago Exited (0) 2 hours ago nextcloud-aio-apache
3ba6b8c4f1a3 nextcloud/aio-nextcloud:latest "/start.sh /usr/bin/…" 2 hours ago Up 3 minutes (healthy) 9000/tcp nextcloud-aio-nextcloud
cd4c52ccbed4 nextcloud/aio-redis:latest "start.sh" 2 hours ago Up 3 minutes (healthy) 6379/tcp nextcloud-aio-redis
76373d6284c6 nextcloud/aio-postgresql:latest "start.sh" 2 hours ago Up 3 minutes (healthy) 5432/tcp nextcloud-aio-database
e095b4519a3f nextcloud/aio-domaincheck:latest "/start.sh" 2 hours ago Exited (137) 2 hours ago nextcloud-aio-domaincheck
2fd1ccd07a19 nextcloud/all-in-one:latest "start.sh /usr/bin/s…" 2 hours ago Up 3 minutes (healthy) 0.0.0.0:80->80/tcp, :::80->80/tcp, 0.0.0.0:8080->8080/tcp, :::8080->8080/tcp, 0.0.0.0:8443->8443/tcp, :::8443->8443/tcp nextcloud-aio-mastercontainer
Apache Log:
Waiting for Nextcloud to start...
nc: getaddrinfo for host "nextcloud-aio-nextcloud" port 9000: Name or service not known
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 172.17.0.6. Set the 'ServerName' directive globally to suppress this message
{"level":"info","ts":1663834651.4324899,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
{"level":"warn","ts":1663834651.4346657,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/Caddyfile","line":2}
{"level":"info","ts":1663834651.4358983,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1663834651.4362164,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0003924d0"}
{"level":"info","ts":1663834651.4362478,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"warn","ts":1663834651.4362597,"logger":"http","msg":"automatic HTTP->HTTPS redirects are disabled","server_name":"srv0"}
{"level":"info","ts":1663834651.437259,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/mnt/data/caddy"}
{"level":"info","ts":1663834651.4373107,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1663834651.4374712,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["c.meyer.de"]}
{"level":"info","ts":1663834651.4379838,"msg":"autosaved config (load with --resume flag)","file":"/var/www/.config/caddy/autosave.json"}
{"level":"info","ts":1663834651.4380043,"msg":"serving initial configuration"}
{"level":"info","ts":1663834651.4384208,"logger":"tls.obtain","msg":"acquiring lock","identifier":"c.meyer.de"}
{"level":"info","ts":1663834651.4411757,"logger":"tls.obtain","msg":"lock acquired","identifier":"c.meyer.de"}
{"level":"info","ts":1663834652.2783682,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["c.meyer.de"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":""}
{"level":"info","ts":1663834652.2784834,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["c.meyer.de"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":""}
{"level":"info","ts":1663834652.7654939,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"c.meyer.de","challenge_type":"tls-alpn-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
{"level":"error","ts":1663834654.1353533,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"c.meyer.de","challenge_type":"tls-alpn-01","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"Cannot negotiate ALPN protocol \"acme-tls/1\" for tls-alpn-01 challenge","instance":"","subproblems":[]}}
{"level":"error","ts":1663834654.1354105,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"c.meyer.de","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"Cannot negotiate ALPN protocol \"acme-tls/1\" for tls-alpn-01 challenge","instance":"","subproblems":[]},"order":"https://acme-v02.api.letsencrypt.org/acme/order/743275557/127787781647","attempt":1,"max_attempts":3}
{"level":"error","ts":1663834654.1354535,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"c.meyer.de","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 403 urn:ietf:params:acme:error:unauthorized - Cannot negotiate ALPN protocol \"acme-tls/1\" for tls-alpn-01 challenge"}
{"level":"error","ts":1663834654.1354778,"logger":"tls.obtain","msg":"will retry","error":"[c.meyer.de] Obtain: [c.meyer.de] solving challenge: c.meyer.de: [c.meyer.de] authorization failed: HTTP 403 urn:ietf:params:acme:error:unauthorized - Cannot negotiate ALPN protocol \"acme-tls/1\" for tls-alpn-01 challenge (ca=https://acme-v02.api.letsencrypt.org/directory)","attempt":1,"retrying_in":60,"elapsed":2.694256894,"max_duration":2592000}
{"level":"info","ts":1663834703.1944914,"msg":"shutting down apps, then terminating","signal":"SIGTERM"}
{"level":"warn","ts":1663834703.194546,"msg":"exiting; byeee!! 👋","signal":"SIGTERM"}
{"level":"info","ts":1663834703.195875,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0003924d0"}
{"level":"info","ts":1663834703.1959393,"logger":"tls.obtain","msg":"releasing lock","identifier":"c.meyer.de"}
{"level":"error","ts":1663834703.1961439,"logger":"tls.obtain","msg":"unable to unlock","identifier":"c.meyer.de","lock_key":"issue_cert_c.meyer.de","error":"remove /mnt/data/caddy/locks/issue_cert_c.meyer.de.lock: no such file or directory"}
{"level":"error","ts":1663834703.1961849,"logger":"tls","msg":"job failed","error":"c.meyer.de: obtaining certificate: context canceled"}
{"level":"info","ts":1663834703.197529,"logger":"admin","msg":"stopped previous server","address":"tcp/localhost:2019"}
{"level":"info","ts":1663834703.197552,"msg":"shutdown complete","signal":"SIGTERM","exit_code":0}
Firewal Log:
192.168.144.90 = Nextcloud
192.168.144.253 = Opnsense with HA Proxy
192.168.144.52.2814 > 192.168.252.253.9292: Flags [S], cksum 0x0e38 (correct), seq 1143265525, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
00:00:00.214011 rule 67/0(match): pass in on em1: (tos 0x0, ttl 127, id 41599, offset 0, flags [DF], proto TCP (6), length 52)
192.168.144.52.2815 > 192.168.252.253.9292: Flags [S], cksum 0xd969 (correct), seq 643705737, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
00:00:00.001514 rule 67/0(match): pass in on em1: (tos 0x0, ttl 127, id 41601, offset 0, flags [DF], proto TCP (6), length 52)
192.168.144.52.2816 > 192.168.252.253.9292: Flags [S], cksum 0x9293 (correct), seq 1175409325, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
00:00:00.000745 rule 67/0(match): pass in on em1: (tos 0x0, ttl 127, id 41603, offset 0, flags [DF], proto TCP (6), length 52)
192.168.144.52.2817 > 192.168.252.253.9292: Flags [S], cksum 0x6faf (correct), seq 1807765471, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
00:00:00.000835 rule 67/0(match): pass in on em1: (tos 0x0, ttl 127, id 41605, offset 0, flags [DF], proto TCP (6), length 52)
192.168.144.52.2818 > 192.168.252.253.9292: Flags [S], cksum 0x50e4 (correct), seq 3097829828, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
00:00:00.005110 rule 67/0(match): pass in on em1: (tos 0x0, ttl 127, id 41616, offset 0, flags [DF], proto TCP (6), length 52)
192.168.144.52.2819 > 192.168.252.253.9292: Flags [S], cksum 0xa4b9 (correct), seq 4151152421, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
00:00:00.220121 rule 66/0(match): pass in on em1: (tos 0x0, ttl 51, id 46203, offset 0, flags [DF], proto TCP (6), length 60)
80.187.65.179.9164 > 192.168.252.253.443: Flags [S], cksum 0x325b (correct), seq 982578561, win 65535, options [mss 1340,sackOK,TS val 93219552 ecr 0,nop,wscale 8], length 0
00:00:00.009273 rule 66/0(match): pass in on em1: (tos 0x0, ttl 51, id 41577, offset 0, flags [DF], proto TCP (6), length 60)
80.187.65.179.9165 > 192.168.252.253.443: Flags [S], cksum 0x995f (correct), seq 2511745874, win 65535, options [mss 1340,sackOK,TS val 93219556 ecr 0,nop,wscale 8], length 0
00:00:00.104391 rule 60/0(match) [uid 80]: pass out on em0: (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 60)
192.168.144.253.59513 > 192.168.144.2.443: Flags [S], cksum 0xb87f (incorrect -> 0x4f32), seq 1265648558, win 65228, options [mss 1460,nop,wscale 7,sackOK,TS val 3868189132 ecr 0], length 0
00:00:00.039332 rule 60/0(match) [uid 80]: pass out on em0: (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 60)
192.168.144.253.59514 > 192.168.144.2.443: Flags [S], cksum 0xb87f (incorrect -> 0x073c), seq 3439798714, win 65228, options [mss 1460,nop,wscale 7,sackOK,TS val 2762802177 ecr 0], length 0
00:00:01.735475 rule 66/0(match): pass in on em1: (tos 0x0, ttl 126, id 52528, offset 0, flags [DF], proto TCP (6), length 52)
192.168.254.83.60377 > 192.168.252.253.443: Flags [S], cksum 0x1747 (correct), seq 663210918, win 64240, options [mss 1319,nop,wscale 8,nop,nop,sackOK], length 0
00:00:00.238521 rule 60/0(match) [uid 80]: pass out on em0: (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 60)
192.168.144.253.59515 > 192.168.144.90.8080: Flags [S], cksum 0xb8d7 (incorrect -> 0x24a7), seq 233517909, win 65228, options [mss 1460,nop,wscale 7,sackOK,TS val 3307560305 ecr 0], length 0
00:00:00.941569 rule 66/0(match): pass in on em1: (tos 0x0, ttl 127, id 41867, offset 0, flags [DF], proto TCP (6), length 52)
192.168.144.52.2821 > 192.168.252.253.443: Flags [S], cksum 0x566e (correct), seq 2857192736, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
00:00:00.013327 rule 60/0(match) [uid 80]: pass out on em0: (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 60)
192.168.144.253.59516 > 192.168.144.90.11000: Flags [S], cksum 0xb8d7 (incorrect -> 0x5b8c), seq 2285815403, win 65228, options [mss 1460,nop,wscale 7,sackOK,TS val 774414442 ecr 0], length 0
00:00:00.443139 rule 66/0(match): pass in on em1: (tos 0x0, ttl 127, id 41876, offset 0, flags [DF], proto TCP (6), length 52)
192.168.144.52.2822 > 192.168.252.253.443: Flags [S], cksum 0xcc85 (correct), seq 1782912784, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
00:00:00.006810 rule 60/0(match) [uid 80]: pass out on em0: (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 60)
192.168.144.253.59517 > 192.168.144.2.443: Flags [S], cksum 0xb87f (incorrect -> 0x5877), seq 849581123, win 65228, options [mss 1460,nop,wscale 7,sackOK,TS val 1002261390 ecr 0], length 0
00:00:00.590722 rule 60/0(match) [uid 80]: pass out on em0: (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 60)
192.168.144.253.59518 > 192.168.144.90.11000: Flags [S], cksum 0xb8d7 (incorrect -> 0xdeeb), seq 1996881397, win 65228, options [mss 1460,nop,wscale 7,sackOK,TS val 215817295 ecr 0], length 0
00:00:01.012133 rule 60/0(match) [uid 80]: pass out on em0: (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 60)
192.168.144.253.59519 > 192.168.144.90.11000: Flags [S], cksum 0xb8d7 (incorrect -> 0x6453), seq 2147586077, win 65228, options [mss 1460,nop,wscale 7,sackOK,TS val 3092795463 ecr 0], length 0
00:00:00.402006 rule 66/0(match): pass in on em1: (tos 0x2,ECT(0), ttl 127, id 17022, offset 0, flags [DF], proto TCP (6), length 52)
192.168.144.11.51993 > 192.168.252.253.443: Flags [SEW], cksum 0x805e (correct), seq 880662612, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
00:00:00.007758 rule 60/0(match) [uid 80]: pass out on em0: (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 60)
192.168.144.253.59520 > 192.168.144.90.8080: Flags [S], cksum 0xb8d7 (incorrect -> 0x32a4), seq 2335711402, win 65228, options [mss 1460,nop,wscale 7,sackOK,TS val 1941517881 ecr 0], length 0
00:00:00.635460 rule 60/0(match) [uid 80]: pass out on em0: (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 60)
192.168.144.253.59521 > 192.168.144.90.11000: Flags [S], cksum 0xb8d7 (incorrect -> 0x83f3), seq 2696033783, win 65228, options [mss 1460,nop,wscale 7,sackOK,TS val 873393764 ecr 0], length 0
00:00:01.447019 rule 66/0(match): pass in on em1: (tos 0x0, ttl 127, id 41886, offset 0, flags [DF], proto TCP (6), length 52)
192.168.144.52.2824 > 192.168.252.253.443: Flags [S], cksum 0x9a89 (correct), seq 2251500828, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
00:00:00.013491 rule 60/0(match) [uid 80]: pass out on em0: (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 60)
192.168.144.253.59522 > 192.168.144.12.8090: Flags [S], cksum 0xb889 (incorrect -> 0x38a0), seq 3637235169, win 65228, options [mss 1460,nop,wscale 7,sackOK,TS val 2468877893 ecr 0], length 0
00:00:00.547563 rule 66/0(match): pass in on em1: (tos 0x0, ttl 126, id 11221, offset 0, flags [DF], proto TCP (6), length 52)
192.168.254.113.63816 > 192.168.252.253.443: Flags [S], cksum 0x5292 (correct), seq 3594113936, win 64240, options [mss 1458,nop,wscale 8,nop,nop,sackOK], length 0
00:00:00.098009 rule 60/0(match) [uid 80]: pass out on em0: (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 60)
192.168.144.253.59523 > 192.168.144.90.443: Flags [S], cksum 0xb8d7 (incorrect -> 0xffee), seq 4203134005, win 65228, options [mss 1460,nop,wscale 7,sackOK,TS val 2456182073 ecr 0], length 0
00:00:00.567528 rule 66/0(match): pass in on em1: (tos 0x0, ttl 126, id 11231, offset 0, flags [DF], proto TCP (6), length 52)
192.168.254.113.63817 > 192.168.252.253.443: Flags [S], cksum 0x2540 (correct), seq 4029671147, win 64240, options [mss 1458,nop,wscale 8,nop,nop,sackOK], length 0
00:00:00.199774 rule 60/0(match) [uid 80]: pass out on em0: (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 60)
192.168.144.253.59524 > 192.168.144.2.443: Flags [S], cksum 0xb87f (incorrect -> 0x4919), seq 3844093588, win 65228, options [mss 1460,nop,wscale 7,sackOK,TS val 1562502322 ecr 0], length 0
00:00:00.257451 rule 60/0(match) [uid 80]: pass out on em0: (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 60)
192.168.144.253.59525 > 192.168.144.90.443: Flags [S], cksum 0xb8d7 (incorrect -> 0xe466), seq 2928915251, win 65228, options [mss 1460,nop,wscale 7,sackOK,TS val 4269040038 ecr 0], length 0
00:00:01.023924 rule 60/0(match) [uid 80]: pass out on em0: (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 60)
192.168.144.253.59526 > 192.168.144.90.443: Flags [S], cksum 0xb8d7 (incorrect -> 0x5cb8), seq 1989444906, win 65228, options [mss 1460,nop,wscale 7,sackOK,TS val 2719525816 ecr 0], length 0
00:00:00.576284 rule 66/0(match): pass in on em1: (tos 0x0, ttl 126, id 52713, offset 0, flags [DF], proto TCP (6), length 52)
192.168.254.144.51516 > 192.168.252.253.443: Flags [S], cksum 0xabd5 (correct), seq 3962016833, win 64240, options [mss 1458,nop,wscale 8,nop,nop,sackOK], length 0
00:00:00.142410 rule 60/0(match) [uid 80]: pass out on em0: (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 60)
192.168.144.253.59527 > 192.168.144.2.443: Flags [S], cksum 0xb87f (incorrect -> 0x9b69), seq 689108052, win 65228, options [mss 1460,nop,wscale 7,sackOK,TS val 1328455328 ecr 0], length 0
00:00:00.317848 rule 60/0(match) [uid 80]: pass out on em0: (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 60)
192.168.144.253.59528 > 192.168.144.90.443: Flags [S], cksum 0xb8d7 (incorrect -> 0xab9f), seq 3510976964, win 65228, options [mss 1460,nop,wscale 7,sackOK,TS val 1266392097 ecr 0], length 0
00:00:01.530653 rule 66/0(match): pass in on em1: (tos 0x0, ttl 126, id 52540, offset 0, flags [DF], proto TCP (6), length 52)
192.168.254.83.60378 > 192.168.252.253.443: Flags [S], cksum 0xe973 (correct), seq 2577565533, win 64240, options [mss 1319,nop,wscale 8,nop,nop,sackOK], length 0
00:00:00.199180 rule 60/0(match) [uid 80]: pass out on em0: (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 60)
192.168.144.253.59529 > 192.168.144.2.443: Flags [S], cksum 0xb87f (incorrect -> 0x482b), seq 2257932740, win 65228, options [mss 1460,nop,wscale 7,sackOK,TS val 4000356263 ecr 0], length 0
HA Proxy Config
global
uid 80
gid 80
chroot /var/haproxy
daemon
stats socket /var/run/haproxy.socket group proxy mode 775 level admin
nbproc 1
nbthread 4
hard-stop-after 60s
no strict-limits
maxconn 10000
tune.ssl.default-dh-param 4096
spread-checks 2
tune.bufsize 16384
tune.lua.maxmem 0
log /var/run/log audit debug
lua-prepend-path /tmp/haproxy/lua/?.lua
defaults
log global
option redispatch -1
maxconn 5000
timeout client 30s
timeout connect 30s
timeout server 30s
retries 3
default-server init-addr last,libc
# autogenerated entries for ACLs
# autogenerated entries for config in backends/frontends
# autogenerated entries for stats
# Frontend: LetsEncrypt_443 ()
frontend LetsEncrypt_443
bind 192.168.252.253:443 name 192.168.252.253:443 ssl prefer-client-ciphers ssl-min-ver TLSv1.2 ciphers ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256 ciphersuites TLS_AES_128_GCM_SHA256:TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256 crt-list /tmp/haproxy/ssl/605f6609f106d1.17683543.certlist
mode http
option http-keep-alive
default_backend acme_challenge_backend
option forwardfor
# tuning options
timeout client 30s
# logging options
# ACL: Nextcloud
acl acl_60604e669c3ca4.13013327 hdr(host) -i c.meyer.de
# ACTION: redirect_acme_challenges
use_backend acme_challenge_backend if acl_605f6d4b6453d2.03059920
# ACTION: Nextcloud
use_backend Nextcloud if acl_60604e669c3ca4.13013327
# Frontend: LetsEncrypt_80 ()
frontend LetsEncrypt_80
bind 192.168.252.253:80 name 192.168.252.253:80
mode tcp
# tuning options
timeout client 30s
# logging options
# ACL: find_acme_challenge
acl acl_605f6d4b6453d2.03059920 path_beg -i /.well-known/acme-challenge/
# Frontend (DISABLED): 1_HTTP_frontend ()
# Frontend (DISABLED): 1_HTTPS_frontend ()
# Frontend (DISABLED): 0_SNI_frontend ()
# Backend: acme_challenge_backend (Added by Let's Encrypt plugin)
# health checking is DISABLED
mode http
balance source
# stickiness
stick-table type ip size 50k expire 30m
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server acme_challenge_host 127.0.0.1:43580
# Backend: Nextcloud ()
backend Nextcloud
mode http
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server Nextcloud2 192.168.144.90:11000 ssl verify none
server Nextcloud3 192.168.144.90:443 ssl verify none
server Nextcloud4 192.168.144.90:8443 ssl verify none
server Nextcloud5 192.168.144.90:8080 ssl verify none
