Nextcloud 19 Beta 2 is out - help us test it!
Thanks, I did this already, but the wheels turn very slow there :wink:
Dear developers,
please bear in mind, that the trashbin retention times do not work with the app group folder enabled. So deleted files in the group folder do move into trash bin, but are not deleted from the trash bin according to the trashbin retention settings e.g. ‘trashbin_retention_obligation’ => 1, 3,
Rgds
Haydar
Hello Haydar,
you repeated your comment regarding groupfolders app and thrashbin.
Please report such things at GitHub or add your comment to existings issues.
S3 still needs trash to work correctly. Deleting files from trash should delete them from the S3 backend along with image previews.
It doesn’t. Previews are not and sometimes the files aren’t removed from the S3 backend either.
Very surprised this is still an issue especially after that S3 partnership advertisement yesterday.
Well, I’ve done this 100 times at github, with all others. So you’ve requested us to test the NC 19, so I did this and I’m just telling you the issues.
Thank you
Haydar
BTW, what do mean with S3 ist this group folders related?, thx
You are responding to a news article created by a bot (see topic category).
Which issue you are referring too?
No, see Amazon S3 - Wikipedia
well it is the following issue at github (group folder and trashbin retention setting do not work)
e.g.
or here
BRGDS
Haydar
I just tested GroupFolder. What exactly are your issues? It works for me in NC19b4 exactly as it did in NC18. (And this thread is about NC19+apps regressions/bugs, right :wink:
As my comment started : “as soon as it been released”
It was on NC14 i think (i can be wrong).
It wasn’t really production ready, so i stopped using it and change my way to share a same folder between groups.
Now i can’t migrate on GroupFolder because of some unresolved issues like the TrashBin retention
yeah Nemskiller is right,
Why I’m repeating this here and in github. Very easy: I try to take every opportunity to point out this issue. I don’t have any other choice. GF is a very good app in enterprise environments, but it is a pain in the butt, that in GF deleted files, will not be removed from the trash bin according to the trash bin obligation times in the config.php. I guess this is what the nextcloud developers and the GF developers should have an close eye on it.
Many people might thing now, this guy with his funny requests, but it is important for the Group Folder users. So please let’s give an hand on it to solve this problem since NC 14
Thanks for your comments. Nurosda just check my github links, right before your actual contribution
Haydar
Well rakekniven,
I and many others have reported this issues, but since a veery long time, there is no action taken from the developers. Why is NC still keeping this app still in it’s repositories?
It is working :slight_smile:
Using it in a few clouds and have no complaints.
I do not understand? As I understand it Groupfolders are essential for an organisation. How can you have shared folders for groups of users without it?
Manuel sharing.
Create a folder and share with users.
I created another thread. Please continue this discussion there.
@rollanders and @rakekniven
don’t you read my mails carefully? This app might work a kind of well. BUT if you delete a file FROM the GROUP Folders, it moves to the trashbin, BUT WILL NOT be removed from there, even if the trash bin retention obligation is set in the config.php. This is why the Group app fails. And I’m not the only one, who complains about it. And see here the entries at github:
BUT if you thing your Group Folders are working, the way, they should be, like deleted in Group Folders items are being removed according to the trash bin retention obligation directive, then tell me please, how it works on your environment. Setting up the GF and using it is not the point, this works for me too
Thank you
Haydar
I read your messages and did not answering you. It was a response to @rollanders question.
ohh sorry for that
