I have successfully installed Nextcloud with nginx, mariadb, php7.2. Now I am trying to integrate onlyoffice. I have used the docker for it. My problem is, I musst run Nextcloud and Onlyoffice on a different port from 443 because this one is used at all.
I can reach my nextcloud on https:/apps.mydomain.de:8443/nextcloud
I have installed onlyoffice with docker.
If i do https://onlyoffice.mydomain.de:8443/welcome I can reach the Server
If i do https://onlyoffice.mydomain.de:8443 (without welcome) the url get changed in https://onlyoffice.klimaflex.de/welcome
This is my nginx for onlyoffice
server {
listen 443 ssl http2;
server_name onlyoffice.mydomain.de;
# Include SSL configuration
include /etc/nginx/snippets/ssl.conf;
# Configuration for OnlyOffice
location / {
proxy_pass https://192.168.1.8:4433;
proxy_redirect off;
proxy_set_header Host $http_host;
proxy_set_header X-Forwarded-Host $server_name;
If I try to set up onlyoffice in nextcloud I everything seems ok. But wenn I try to open a file I get an error
Fehler beim Anschließen (Im Dokumentenservice ist ein Fehler aufgetreten: Error while downloading the document file to be converted.)
Will it be possible to run only office on a different port than 443?
I also have tested colloborate online without look.
Please can some one give me a littel assist at this issue. I have spend hours of searching the internet without any success.
Thanks a lot
Andreas
