This is really odd. Esp the doc.owncloud.org thing - that is certainly not in our code. Are you sure the update was complete and some files from oC are not left over perhaps? I am trying to find out how this can happen but I canāt find anythingā¦
Upgraded from 12.0.0 to 12.0.1RC4 using beta channel without a glitch! Everything went just fine!
Great job Nextcloud team!
I canāt replicate this on mine.
Same here but using the daily channel instead. Not a single glitch and in less than 5 minutes. No more T-Shirts ![]()
Tried to update from 12ā¦0.0 to 12.0.1 RC4 on a PC running OpenMediaVault 3.0.86 - Debian Linux
First I tried the beta channel the the daily channel.
Both with the same result.
First I get this error message
Then I tries a āRetry Updateā
Given the prevalence of using Letās Encrypt, it would be great if the Nextcloud upgrader would accommodate this.
There are other ways to make it work:
Morten, time outs are odd - seems a server issue, what do you see in the logs?!!?? Is the zip handling PHP module installed?
I changed my stable version (12.0.0) to beta and went to update to 12.0.1 RC4 (as admin). I pushed the open update button and it started, but failed due to write permission errors from the copy of the config, et al to the updater folder (the entire list of files was included). I logged on to the terminal (Debian Jessie) and changed the permissions to 777 on the entire folder, ran it again and got the same errors. Am I doing something wrong? By the way, this is a test server I have setup to test new releases.
update from 12.0.0 to 12.0.1rc4 worked without any issue on my testhost.
Hint:
SEL must be disabled prior update, if used.
Itās not being used. I ran through the disable commands for selinux and they werenāt even recognized. Iāll mess around with parent permissions for a bit. Thanks. By the way, I love your software. Keep up the good work.
Hmm, this only says āsomething went wrongā, any idea WHAT went wrong? Info from the logs perhaps, and what happens if you reload?
Thanks!
Actually I have no Idea what went wrong. Actually on updating to RC4 I got the same messing wich could be fixed by using the occ upgrade command.
The updater.log is giving the following:
2017-08-04T17:09:53+0000 mtVgmkwGP9 [info] request to updater
2017-08-04T17:09:53+0000 mtVgmkwGP9 [info] currentStep()
2017-08-04T17:09:53+0000 mtVgmkwGP9 [info] show HTML page
2017-08-04T17:09:53+0000 mtVgmkwGP9 [info] current version: 12.0.1 RC4 build time: 2017-07-30T14:12:49+00:00 0a369747a0856035369fb072e7215fa92322ad17
2017-08-04T17:09:53+0000 mtVgmkwGP9 [info] getUpdateServerResponse()
2017-08-04T17:09:53+0000 mtVgmkwGP9 [info] updaterServer: https://updates.nextcloud.org/updater_server/
2017-08-04T17:09:53+0000 mtVgmkwGP9 [info] releaseChannel: beta
2017-08-04T17:09:53+0000 mtVgmkwGP9 [info] internal version: 12.0.1.3
2017-08-04T17:09:53+0000 mtVgmkwGP9 [info] updateURL: https://updates.nextcloud.org/updater_server/?version=12x0x1x3xxxbetaxx2017-07-30T14%3A12%3A49%2B00%3A00+0a369747a0856035369fb072e7215fa92322ad17x7x0x20
2017-08-04T17:09:54+0000 mtVgmkwGP9 [info] getUpdateServerResponse response: Array
[version] => 12.0.1.4
[versionstring] => Nextcloud 12.0.1 RC5
[url] => https://download.nextcloud.com/server/prereleases/nextcloud-12.0.1RC5.zip
[web] => https://docs.nextcloud.com/server/11/admin_manual/maintenance/upgrade.html
[autoupdater] => 1
[signature] => AeLhXIbPjXJyAY3PwaNev71Ou8GC/iQzvn/QKHPlLdjTWkZCIsuld5Jr6a+mNiP2
+dhoOIux6GPXZP08fGp0+AXMLZxBWTGW2OdIo43N/QXGzUOwoaPuGnT8vaoSFjtW
2RFtJt6N5ukyAwxt1H0vmjJkZfV/dXYcxpL4wuJtOYzhABIoBCzAqjvxqgH0x05O
GBwOm9swDIY87i9A1G1O9SGaB3gEvj3RTgHAmMY6hOjR45vPPDBKfnWANzR4x1Gd
tcMwGZSUn1c/t6+447TLwCZ97L8lfVMbfZUsSwUDhyfZuzQJsDuANn74SfRiZFbe
Eb+ldvds2wbIh/BZdTfSNA==
2017-08-04T17:09:54+0000 mtVgmkwGP9 [info] checkForUpdate() Array
[autoupdater] => 1
2017-08-04T17:09:54+0000 mtVgmkwGP9 [info] end of checkForUpdate() Update to Nextcloud 12.0.1 RC5 available. (channel: "beta")<br /><span class="light">Following file will be downloaded automatically:</span> <code class="light">https://download.nextcloud.com/server/prereleases/nextcloud-12.0.1RC5.zip</code>
2017-08-04T17:09:59+0000 Ly2DlsvEXR [info] request to updater
2017-08-04T17:09:59+0000 Ly2DlsvEXR [info] currentStep()
2017-08-04T17:09:59+0000 Ly2DlsvEXR [info] POST request for step "1"
2017-08-04T17:09:59+0000 Ly2DlsvEXR [info] startStep("1")
2017-08-04T17:09:59+0000 Ly2DlsvEXR [info] checkForExpectedFilesAndFolders()
2017-08-04T17:09:59+0000 Ly2DlsvEXR [info] end of checkForExpectedFilesAndFolders()
2017-08-04T17:09:59+0000 Ly2DlsvEXR [info] endStep("1")
2017-08-04T17:10:00+0000 xIBZrdyQXy [info] request to updater
2017-08-04T17:10:00+0000 xIBZrdyQXy [info] currentStep()
2017-08-04T17:10:00+0000 xIBZrdyQXy [info] Step 1 is in state "end".
2017-08-04T17:10:00+0000 xIBZrdyQXy [info] POST request for step "2"
2017-08-04T17:10:00+0000 xIBZrdyQXy [info] startStep("2")
2017-08-04T17:10:00+0000 xIBZrdyQXy [info] checkWritePermissions()
2017-08-04T17:10:00+0000 xIBZrdyQXy [info] end of checkWritePermissions()
2017-08-04T17:10:00+0000 xIBZrdyQXy [info] endStep("2")
2017-08-04T17:10:00+0000 9k25Aop75f [info] request to updater
2017-08-04T17:10:00+0000 9k25Aop75f [info] currentStep()
2017-08-04T17:10:00+0000 9k25Aop75f [info] Step 2 is in state "end".
2017-08-04T17:10:00+0000 9k25Aop75f [info] POST request for step "3"
2017-08-04T17:10:00+0000 9k25Aop75f [info] startStep("3")
2017-08-04T17:10:00+0000 9k25Aop75f [info] setMaintenanceMode("true")
2017-08-04T17:10:00+0000 9k25Aop75f [info] configFileName /var/www/nextcloud/updater/../config/config.php
2017-08-04T17:10:00+0000 9k25Aop75f [info] end of setMaintenanceMode()
2017-08-04T17:10:00+0000 9k25Aop75f [info] endStep("3")
2017-08-04T17:10:01+0000 gQNjt8LYNI [info] request to updater
2017-08-04T17:10:01+0000 gQNjt8LYNI [info] currentStep()
2017-08-04T17:10:01+0000 gQNjt8LYNI [info] Step 3 is in state "end".
2017-08-04T17:10:01+0000 gQNjt8LYNI [info] POST request for step "4"
2017-08-04T17:10:01+0000 gQNjt8LYNI [info] startStep("4")
2017-08-04T17:10:01+0000 gQNjt8LYNI [info] createBackup()
2017-08-04T17:10:11+0000 gQNjt8LYNI [info] end of createBackup()
2017-08-04T17:10:11+0000 gQNjt8LYNI [info] endStep("4")
2017-08-04T17:10:11+0000 PkrrjSFSIC [info] request to updater
2017-08-04T17:10:11+0000 PkrrjSFSIC [info] currentStep()
2017-08-04T17:10:11+0000 PkrrjSFSIC [info] Step 4 is in state "end".
2017-08-04T17:10:11+0000 PkrrjSFSIC [info] POST request for step "5"
2017-08-04T17:10:11+0000 PkrrjSFSIC [info] startStep("5")
2017-08-04T17:10:11+0000 PkrrjSFSIC [info] downloadUpdate()
2017-08-04T17:10:11+0000 PkrrjSFSIC [info] getUpdateServerResponse()
2017-08-04T17:10:11+0000 PkrrjSFSIC [info] updaterServer: https://updates.nextcloud.org/updater_server/
2017-08-04T17:10:11+0000 PkrrjSFSIC [info] releaseChannel: beta
2017-08-04T17:10:11+0000 PkrrjSFSIC [info] internal version: 12.0.1.3
2017-08-04T17:10:11+0000 PkrrjSFSIC [info] updateURL: https://updates.nextcloud.org/updater_server/?version=12x0x1x3xxxbetaxx2017-07-30T14%3A12%3A49%2B00%3A00+0a369747a0856035369fb072e7215fa92322ad17x7x0x20
2017-08-04T17:10:12+0000 PkrrjSFSIC [info] getUpdateServerResponse response: Array
[autoupdater] => 1
2017-08-04T17:10:12+0000 PkrrjSFSIC [info] storage location exists
2017-08-04T17:10:18+0000 PkrrjSFSIC [info] end of downloadUpdate()
2017-08-04T17:10:18+0000 PkrrjSFSIC [info] endStep("5")
2017-08-04T17:10:18+0000 rSXtXxSnEX [info] request to updater
2017-08-04T17:10:18+0000 rSXtXxSnEX [info] currentStep()
2017-08-04T17:10:18+0000 rSXtXxSnEX [info] Step 5 is in state "end".
2017-08-04T17:10:18+0000 rSXtXxSnEX [info] POST request for step "6"
2017-08-04T17:10:19+0000 rSXtXxSnEX [info] startStep("6")
2017-08-04T17:10:19+0000 rSXtXxSnEX [info] verifyIntegrity()
2017-08-04T17:10:19+0000 rSXtXxSnEX [info] getUpdateServerResponse()
2017-08-04T17:10:19+0000 rSXtXxSnEX [info] updaterServer: https://updates.nextcloud.org/updater_server/
2017-08-04T17:10:19+0000 rSXtXxSnEX [info] releaseChannel: beta
2017-08-04T17:10:19+0000 rSXtXxSnEX [info] internal version: 12.0.1.3
2017-08-04T17:10:19+0000 rSXtXxSnEX [info] updateURL: https://updates.nextcloud.org/updater_server/?version=12x0x1x3xxxbetaxx2017-07-30T14%3A12%3A49%2B00%3A00+0a369747a0856035369fb072e7215fa92322ad17x7x0x20
2017-08-04T17:10:19+0000 rSXtXxSnEX [info] getUpdateServerResponse response: Array
[autoupdater] => 1
2017-08-04T17:10:19+0000 rSXtXxSnEX [info] storage location: /owncloud_data/updater-oc93z1rhfmbp/downloads/
2017-08-04T17:10:19+0000 rSXtXxSnEX [info] end of verifyIntegrity()
2017-08-04T17:10:19+0000 rSXtXxSnEX [info] endStep("6")
2017-08-04T17:10:19+0000 CVNqehz0fm [info] request to updater
2017-08-04T17:10:19+0000 CVNqehz0fm [info] currentStep()
2017-08-04T17:10:19+0000 CVNqehz0fm [info] Step 6 is in state "end".
2017-08-04T17:10:19+0000 CVNqehz0fm [info] POST request for step "7"
2017-08-04T17:10:19+0000 CVNqehz0fm [info] startStep("7")
2017-08-04T17:10:19+0000 CVNqehz0fm [info] extractDownload()
2017-08-04T17:10:19+0000 CVNqehz0fm [info] storage location: /owncloud_data/updater-oc93z1rhfmbp/downloads/
2017-08-04T17:10:25+0000 CVNqehz0fm [info] end of extractDownload()
2017-08-04T17:10:25+0000 CVNqehz0fm [info] endStep("7")
2017-08-04T17:10:26+0000 J5Hbx14dUM [info] request to updater
2017-08-04T17:10:26+0000 J5Hbx14dUM [info] currentStep()
2017-08-04T17:10:26+0000 J5Hbx14dUM [info] Step 7 is in state "end".
2017-08-04T17:10:26+0000 J5Hbx14dUM [info] POST request for step "8"
2017-08-04T17:10:26+0000 J5Hbx14dUM [info] startStep("8")
2017-08-04T17:10:26+0000 J5Hbx14dUM [info] replaceEntryPoints()
2017-08-04T17:10:26+0000 J5Hbx14dUM [info] replace index.php
2017-08-04T17:10:26+0000 J5Hbx14dUM [info] replace status.php
2017-08-04T17:10:26+0000 J5Hbx14dUM [info] replace remote.php
2017-08-04T17:10:26+0000 J5Hbx14dUM [info] replace public.php
2017-08-04T17:10:26+0000 J5Hbx14dUM [info] replace ocs/v1.php
2017-08-04T17:10:26+0000 J5Hbx14dUM [info] replace ocs/v2.php
2017-08-04T17:10:26+0000 J5Hbx14dUM [info] end of replaceEntryPoints()
2017-08-04T17:10:26+0000 J5Hbx14dUM [info] endStep("8")
2017-08-04T17:10:26+0000 QlFNPDkI1Z [info] request to updater
2017-08-04T17:10:26+0000 QlFNPDkI1Z [info] currentStep()
2017-08-04T17:10:26+0000 QlFNPDkI1Z [info] Step 8 is in state "end".
2017-08-04T17:10:26+0000 QlFNPDkI1Z [info] POST request for step "9"
2017-08-04T17:10:26+0000 QlFNPDkI1Z [info] startStep("9")
2017-08-04T17:10:28+0000 QlFNPDkI1Z [info] deleteOldFiles()
2017-08-04T17:10:28+0000 QlFNPDkI1Z [info] config sample exists
2017-08-04T17:10:28+0000 QlFNPDkI1Z [info] thmes README exists
2017-08-04T17:10:29+0000 QlFNPDkI1Z [info] end of deleteOldFiles()
2017-08-04T17:10:29+0000 QlFNPDkI1Z [info] endStep("9")
2017-08-04T17:10:29+0000 FEVt49KDa0 [info] request to updater
2017-08-04T17:10:29+0000 FEVt49KDa0 [info] currentStep()
2017-08-04T17:10:29+0000 FEVt49KDa0 [info] Step 9 is in state "end".
2017-08-04T17:10:29+0000 FEVt49KDa0 [info] POST request for step "10"
2017-08-04T17:10:29+0000 FEVt49KDa0 [info] startStep("10")
2017-08-04T17:10:29+0000 FEVt49KDa0 [info] moveNewVersionInPlace()
2017-08-04T17:10:29+0000 FEVt49KDa0 [info] storage location: /owncloud_data/updater-oc93z1rhfmbp/downloads/nextcloud/
2017-08-04T17:10:34+0000 FEVt49KDa0 [info] end of moveNewVersionInPlace()
2017-08-04T17:10:34+0000 FEVt49KDa0 [info] endStep("10")
2017-08-04T17:10:41+0000 yHcokYVUCg [info] request to updater
2017-08-04T17:10:41+0000 yHcokYVUCg [info] currentStep()
2017-08-04T17:10:53+0000 yHcokYVUCg [info] Step 10 is in state "end".
2017-08-04T17:10:53+0000 yHcokYVUCg [info] POST request for step "11"
2017-08-04T17:10:53+0000 yHcokYVUCg [info] startStep("11")
2017-08-04T17:10:57+0000 yHcokYVUCg [info] setMaintenanceMode("false")
2017-08-04T17:10:57+0000 yHcokYVUCg [info] configFileName /var/www/nextcloud/updater/../config/config.php
2017-08-04T17:10:57+0000 yHcokYVUCg [info] end of setMaintenanceMode()
2017-08-04T17:10:57+0000 yHcokYVUCg [info] endStep("11")
2017-08-04T17:10:57+0000 cVg1DbaCqW [info] request to updater
2017-08-04T17:10:57+0000 cVg1DbaCqW [info] currentStep()
2017-08-04T17:10:57+0000 cVg1DbaCqW [info] Step 11 is in state "end".
2017-08-04T17:10:57+0000 cVg1DbaCqW [info] POST request for step "12"
2017-08-04T17:10:57+0000 cVg1DbaCqW [info] startStep("12")
2017-08-04T17:10:57+0000 cVg1DbaCqW [info] finalize()
2017-08-04T17:10:57+0000 cVg1DbaCqW [info] storage location: /owncloud_data/updater-oc93z1rhfmbp/downloads/nextcloud/
2017-08-04T17:10:57+0000 cVg1DbaCqW [info] call opcache_reset()
2017-08-04T17:10:57+0000 cVg1DbaCqW [info] end of finalize()
2017-08-04T17:10:57+0000 cVg1DbaCqW [info] endStep("12")
On Reload I get:
In the nextcloud.log I think the relavent part is:
{"reqId":"NvGy4wHXgiBTnd821osG","level":0,"time":"2017-08-04T19:11:23+02:00","remoteAddr":"2.247.241.106","user":"--","app":"core","method":"GET","url":"\/","message":"Scss is disabled for \/var\/www\/nextcloud\/core\/css\/server.scss, ignoring","userAgent":"Mozilla\/5.0 (Windows NT 10.0; WOW64; rv:54.0) Gecko\/20100101 Firefox\/54.0","version":"12.0.1.3"}
{"reqId":"NvGy4wHXgiBTnd821osG","level":0,"time":"2017-08-04T19:11:23+02:00","remoteAddr":"2.247.241.106","user":"--","app":"core","method":"GET","url":"\/","message":"Scss is disabled for \/var\/www\/nextcloud\/core\/css\/share.scss, ignoring","userAgent":"Mozilla\/5.0 (Windows NT 10.0; WOW64; rv:54.0) Gecko\/20100101 Firefox\/54.0","version":"12.0.1.3"}
{"reqId":"lmMa0GRZEkVyL36VbmpU","level":1,"time":"2017-08-04T19:11:27+02:00","remoteAddr":"2.247.241.106","user":"--","app":"updater","method":"GET","url":"\/core\/ajax\/update.php?requesttoken=cbLKEkxuFJ1xpW2UGO9fo%2FVjEiwW29WRVDXWQSf4rHg%3D%3ASYOMfyQ9XPA36y%2BhK6tv9rJXel5isYzGM1juNHfA%2FRM%3D","message":"\\OC\\Updater::setDebugLogLevel: Set log level to debug","userAgent":"Mozilla\/5.0 (Windows NT 10.0; WOW64; rv:54.0) Gecko\/20100101 Firefox\/54.0","version":"12.0.1.3"}
{"reqId":"lmMa0GRZEkVyL36VbmpU","level":1,"time":"2017-08-04T19:11:27+02:00","remoteAddr":"2.247.241.106","user":"--","app":"updater","method":"GET","url":"\/core\/ajax\/update.php?requesttoken=cbLKEkxuFJ1xpW2UGO9fo%2FVjEiwW29WRVDXWQSf4rHg%3D%3ASYOMfyQ9XPA36y%2BhK6tv9rJXel5isYzGM1juNHfA%2FRM%3D","message":"\\OC\\Updater::maintenanceEnabled: Turned on maintenance mode","userAgent":"Mozilla\/5.0 (Windows NT 10.0; WOW64; rv:54.0) Gecko\/20100101 Firefox\/54.0","version":"12.0.1.3"}
{"reqId":"lmMa0GRZEkVyL36VbmpU","level":0,"time":"2017-08-04T19:11:27+02:00","remoteAddr":"2.247.241.106","user":"--","app":"core","method":"GET","url":"\/core\/ajax\/update.php?requesttoken=cbLKEkxuFJ1xpW2UGO9fo%2FVjEiwW29WRVDXWQSf4rHg%3D%3ASYOMfyQ9XPA36y%2BhK6tv9rJXel5isYzGM1juNHfA%2FRM%3D","message":"starting upgrade from 12.0.1.3 to 12.0.1.4","userAgent":"Mozilla\/5.0 (Windows NT 10.0; WOW64; rv:54.0) Gecko\/20100101 Firefox\/54.0","version":"12.0.1.3"}
{"reqId":"lmMa0GRZEkVyL36VbmpU","level":1,"time":"2017-08-04T19:11:27+02:00","remoteAddr":"2.247.241.106","user":"--","app":"updater","method":"GET","url":"\/core\/ajax\/update.php?requesttoken=cbLKEkxuFJ1xpW2UGO9fo%2FVjEiwW29WRVDXWQSf4rHg%3D%3ASYOMfyQ9XPA36y%2BhK6tv9rJXel5isYzGM1juNHfA%2FRM%3D","message":"\\OC\\Repair::step: Repair step: Repair MySQL collation","userAgent":"Mozilla\/5.0 (Windows NT 10.0; WOW64; rv:54.0) Gecko\/20100101 Firefox\/54.0","version":"12.0.1.3"}
{"reqId":"lmMa0GRZEkVyL36VbmpU","level":1,"time":"2017-08-04T19:11:27+02:00","remoteAddr":"2.247.241.106","user":"--","app":"updater","method":"GET","url":"\/core\/ajax\/update.php?requesttoken=cbLKEkxuFJ1xpW2UGO9fo%2FVjEiwW29WRVDXWQSf4rHg%3D%3ASYOMfyQ9XPA36y%2BhK6tv9rJXel5isYzGM1juNHfA%2FRM%3D","message":"\\OC\\Repair::info: Repair info: All tables already have the correct collation -> nothing to do","userAgent":"Mozilla\/5.0 (Windows NT 10.0; WOW64; rv:54.0) Gecko\/20100101 Firefox\/54.0","version":"12.0.1.3"}
{"reqId":"lmMa0GRZEkVyL36VbmpU","level":1,"time":"2017-08-04T19:11:27+02:00","remoteAddr":"2.247.241.106","user":"--","app":"updater","method":"GET","url":"\/core\/ajax\/update.php?requesttoken=cbLKEkxuFJ1xpW2UGO9fo%2FVjEiwW29WRVDXWQSf4rHg%3D%3ASYOMfyQ9XPA36y%2BhK6tv9rJXel5isYzGM1juNHfA%2FRM%3D","message":"\\OC\\Repair::step: Repair step: Repair SQLite autoincrement","userAgent":"Mozilla\/5.0 (Windows NT 10.0; WOW64; rv:54.0) Gecko\/20100101 Firefox\/54.0","version":"12.0.1.3"}
{"reqId":"lmMa0GRZEkVyL36VbmpU","level":1,"time":"2017-08-04T19:11:27+02:00","remoteAddr":"2.247.241.106","user":"--","app":"updater","method":"GET","url":"\/core\/ajax\/update.php?requesttoken=cbLKEkxuFJ1xpW2UGO9fo%2FVjEiwW29WRVDXWQSf4rHg%3D%3ASYOMfyQ9XPA36y%2BhK6tv9rJXel5isYzGM1juNHfA%2FRM%3D","message":"\\OC\\Repair::step: Repair step: Copy data from accounts table when migrating from ownCloud","userAgent":"Mozilla\/5.0 (Windows NT 10.0; WOW64; rv:54.0) Gecko\/20100101 Firefox\/54.0","version":"12.0.1.3"}
{"reqId":"lmMa0GRZEkVyL36VbmpU","level":1,"time":"2017-08-04T19:11:27+02:00","remoteAddr":"2.247.241.106","user":"--","app":"updater","method":"GET","url":"\/core\/ajax\/update.php?requesttoken=cbLKEkxuFJ1xpW2UGO9fo%2FVjEiwW29WRVDXWQSf4rHg%3D%3ASYOMfyQ9XPA36y%2BhK6tv9rJXel5isYzGM1juNHfA%2FRM%3D","message":"\\OC\\Repair::step: Repair step: Drop account terms table when migrating from ownCloud","userAgent":"Mozilla\/5.0 (Windows NT 10.0; WOW64; rv:54.0) Gecko\/20100101 Firefox\/54.0","version":"12.0.1.3"}
{"reqId":"lmMa0GRZEkVyL36VbmpU","level":1,"time":"2017-08-04T19:11:27+02:00","remoteAddr":"2.247.241.106","user":"--","app":"updater","method":"GET","url":"\/core\/ajax\/update.php?requesttoken=cbLKEkxuFJ1xpW2UGO9fo%2FVjEiwW29WRVDXWQSf4rHg%3D%3ASYOMfyQ9XPA36y%2BhK6tv9rJXel5isYzGM1juNHfA%2FRM%3D","message":"\\OC\\Updater::dbUpgradeBefore: Updating database schema","userAgent":"Mozilla\/5.0 (Windows NT 10.0; WOW64; rv:54.0) Gecko\/20100101 Firefox\/54.0","version":"12.0.1.3"}
{"reqId":"lmMa0GRZEkVyL36VbmpU","level":1,"time":"2017-08-04T19:11:28+02:00","remoteAddr":"2.247.241.106","user":"--","app":"updater","method":"GET","url":"\/core\/ajax\/update.php?requesttoken=cbLKEkxuFJ1xpW2UGO9fo%2FVjEiwW29WRVDXWQSf4rHg%3D%3ASYOMfyQ9XPA36y%2BhK6tv9rJXel5isYzGM1juNHfA%2FRM%3D","message":"\\OC\\Updater::dbUpgrade: Updated database","userAgent":"Mozilla\/5.0 (Windows NT 10.0; WOW64; rv:54.0) Gecko\/20100101 Firefox\/54.0","version":"12.0.1.3"}
{"reqId":"lmMa0GRZEkVyL36VbmpU","level":1,"time":"2017-08-04T19:11:28+02:00","remoteAddr":"2.247.241.106","user":"--","app":"updater","method":"GET","url":"\/core\/ajax\/update.php?requesttoken=cbLKEkxuFJ1xpW2UGO9fo%2FVjEiwW29WRVDXWQSf4rHg%3D%3ASYOMfyQ9XPA36y%2BhK6tv9rJXel5isYzGM1juNHfA%2FRM%3D","message":"\\OC\\Updater::checkAppStoreAppBefore: Checking for update of app \"activity\" in appstore","userAgent":"Mozilla\/5.0 (Windows NT 10.0; WOW64; rv:54.0) Gecko\/20100101 Firefox\/54.0","version":"12.0.1.3"}
{"reqId":"lmMa0GRZEkVyL36VbmpU","level":3,"time":"2017-08-04T19:11:28+02:00","remoteAddr":"2.247.241.106","user":"--","app":"PHP","method":"GET","url":"\/core\/ajax\/update.php?requesttoken=cbLKEkxuFJ1xpW2UGO9fo%2FVjEiwW29WRVDXWQSf4rHg%3D%3ASYOMfyQ9XPA36y%2BhK6tv9rJXel5isYzGM1juNHfA%2FRM%3D","message":"Error: Cannot access private property OCA\\Files_Trashbin\\Storage::$mountPoint at \/var\/www\/nextcloud\/apps\/files_accesscontrol\/lib\/Operation.php#85","userAgent":"Mozilla\/5.0 (Windows NT 10.0; WOW64; rv:54.0) Gecko\/20100101 Firefox\/54.0","version":"12.0.1.3"}
{"reqId":"24ewHC0PRtox15xNdSd3","level":0,"time":"2017-08-04T19:12:37+02:00","remoteAddr":"2.247.241.106","user":"--","app":"core","method":"GET","url":"\/index.php\/apps\/ocsms\/get\/apiversion?format=json","message":"Scss is disabled for \/var\/www\/nextcloud\/core\/css\/server.scss, ignoring","userAgent":"nextcloud-phonesync (1.1.0)","version":"12.0.1.3"}
{"reqId":"Uw5equRznzNXkNw3kRiH","level":0,"time":"2017-08-04T19:12:41+02:00","remoteAddr":"2.247.241.106","user":"--","app":"core","method":"GET","url":"\/","message":"Scss is disabled for \/var\/www\/nextcloud\/core\/css\/server.scss, ignoring","userAgent":"Mozilla\/5.0 (Windows NT 10.0; WOW64; rv:54.0) Gecko\/20100101 Firefox\/54.0","version":"12.0.1.3"}
{"reqId":"qlSBaandw1hqlj5VRdJj","level":0,"time":"2017-08-04T19:14:36+02:00","remoteAddr":"2.247.241.106","user":"--","app":"core","method":"GET","url":"\/apps\/files\/","message":"Scss is disabled for \/var\/www\/nextcloud\/core\/css\/server.scss, ignoring","userAgent":"Mozilla\/5.0 (Windows NT 10.0; WOW64; rv:54.0) Gecko\/20100101 Firefox\/54.0","version":"12.0.1.3"}
But still I canāt say what went wrong.
That might be the issue⦠@LukasReschke @MorrisJobke @nickvergessen an issue in file access control?
I made an upgrade from RC4 to RC5 and it complains about this on top of the screen.
There were problems with the code integrity check. More informationā¦
Itās the music app and the same thing happened from version 12.0 to 12.01 RC4.
Last time I deleted the app removed the files and installed it again. Is this an app problem?
When I click at the integrity check message I can rescan and check the files.
āSome files have not passed the integrity check. Further information on how to resolve this issue can be found in our documentation. (List of invalid files⦠/ Rescanā¦)ā
If I click list of invalid files it shows this:
"Technical information
The following list covers which files have failed the integrity check. Please read
the previous linked documentation to learn more about the errors and how to fix
them.
Results
- music
- EXCEPTION
- OC\IntegrityCheck\Exceptions\InvalidSignatureException
- Certificate is not valid.
- EXCEPTION
Raw output
Array
[music] => Array
[EXCEPTION] => Array
[class] => OC\IntegrityCheck\Exceptions\InvalidSignatureException
[message] => Certificate is not valid.
So I tried the occ upgrade which works fine. So it must have something to do with the web based updater. And I was connected over mobile internet, sitting in a train while doing the update.
I donāt know if this could make problems.
I would guess it is a problem with the music app. But I couldnāt reproduce it. Update on my test enviroment runnes fine with Music app enabled.
Maby you finde something in the updater.log or the nextcloud.log
I used the web based updater and in nextcloud.log there are two entries during the upgrade.
Warning music Invalid arguments given to Scanner.update - file=OC\Files\Node\File, userId=, userHome=OCA\Music\Utility\Scanner 2017-08-05T09:47:32+0200
Debug music update - /appdata_ocd2ifjvnx5z/appstore/apps.json
