example
longer
example
here
Nextcloud version (eg, 29.0.5): Nextcloud Hub 8 (29.0.4)
I moved my server to a new network I have no control over the assigned local ip.
The previous local ip was 192.168.0.3
the new local ip is 192.168.1.51
When I go to Admin Settings → Open Nextcloud AIO Interface
it still is set to 192.168.0.3
Remote access via the domain works but I cant access the AIO Interface I need for updates etc.
I did as instructed and ran the command in the linked section.
I changed the AIO_URL variable to the correct ip, then i rebooted the host and thus all containers. Sadly in the Administration Overview the link is still pointing to the old ip. calling it up manually gives me the same message as before
" Nextcloud AIO Login
The login is blocked since Nextcloud is running.
Please use the automatic login from your Nextcloud.
If that is not possible, you can unblock the login by running sudo docker stop nextcloud-aio-apache"
the domain under “domain” did not change and
i assume apache_ip_binding should be left on “0.0.0.0” too.
Note: You can change the domain/ip-address/port of the button by simply stopping the containers, visiting the AIO interface from the correct and desired domain/ip-address/port and clicking once on Start containers .
