Hey,
we just published the RCs for the maintenance releases that are planned for next week Thursday. They are all available on the beta channel of the updater.
The changelog can be found below.
Thanks for all the feedback we received in the last weeks and that went into a number of small fixes for our stable releases.
15.0.5 RC 1
- Show autocompletion as soon as β@β is typed (server#13961)
- Trim filename in webfrontend for windows compatibility (server#13978)
- Clean code and fix drop zone shadow (server#13982)
- Show original path in trashbin (server#14029)
- Update icewind/smb to 3.0.1 (server#14068)
- Fix: Check if
$this->params['user']is an array (server#14085) - [Security] Bump lodash from 4.17.10 to 4.17.11 in /apps/updatenotification (server#14093)
- [Security] Bump lodash from 4.17.10 to 4.17.11 in /apps/accessibility (server#14094)
- [Security] Bump lodash from 4.17.10 to 4.17.11 in /apps/oauth2 (server#14095)
- Make sure the relative path is always a string (server#14101)
- Fix the thorrtler whitelist bitmask (server#14151)
- [Security] Bump handlebars from 4.0.12 to 4.1.0 in /build (server#14187)
- Fix recent files (server#14195)
- Update CRL to contain revoked files_external_dropbox, passman & payback (server#14201)
- Ensure attribute names are lower cased (server#14203)
- Fix small glitches in update notification page (server#14207)
- Fix expiration date changing (server#14212)
- Fix trashbin restore translation (server#14213)
- Remove trailing spaces from localized strings (server#14225)
- Fixing phpdoc in FullTextSearch/Model/ISearchResult (server#14268)
- Fix empty file uploads to S3 (and other streaming storages) (server#14273)
- Do not do redirect handling when loggin out (server#14275)
- Catch Request exception in testRemoteUrl (server#14277)
- Correctly determinate the owner in case of shared external storages (server#14283)
- Fix header label visibility on open menu (server#14287)
- Prefix $path for filename for internal file cache (server#14288)
- Set false as default for requirePNG (server#14292)
- Use proper scroll container when dragging files (server#14301)
- Fix OC.getCurrentUser() on guest pages (server#14308)
- Fix ocm end-point discovery discovery (server#14312)
- Try to support 7.3 for DAV (3rdparty#213)
- Backport/stable15/streams 0.7.1 (3rdparty#244)
- Donβt add empty entries to the objects array (activity#347)
- Ensure parameters are always an array (activity#350)
14.0.8 RC 1
- Update icewind/smb to 3.0.1 (server#14069)
- Fix: Check if
$this->params['user']is an array (server#14086) - [Security] Bump extend from 3.0.1 to 3.0.2 in /build (server#14089)
- [Security] Bump lodash from 4.17.10 to 4.17.11 in /apps/accessibility (server#14090)
- [Security] Bump lodash from 4.17.10 to 4.17.11 in /build (server#14091)
- [Security] Bump lodash from 4.17.10 to 4.17.11 in /apps/oauth2 (server#14092)
- [Security] Bump lodash from 4.17.10 to 4.17.11 in /apps/updatenotification (server#14096)
- Fix the thorrtler whitelist bitmask (server#14152)
- [Security] Bump handlebars from 4.0.11 to 4.1.0 in /build (server#14188)
- Fix recent files (server#14196)
- Update CRL to contain revoked files_external_dropbox, passman & payback (server#14202)
- Fix small glitches in update notification page (server#14205)
- Ensure attribute names are lower cased (server#14206)
- Remove trailing spaces from localized strings (server#14226)
- Catch Request exception in testRemoteUrl (server#14278)
- Correctly determinate the owner in case of shared external storages (server#14284)
- Make sure the parameters are always an array (activity#348)
