I did an installation of nextcloud 12 on my local computer with an apache webserver because I want to test it but after the installation I get only a HTTP ERROR 503. An owncloud installation on the same computer works out of the box. What is the problem?
It’s hard to know with the limited information you provided, but it sounds like this:
I don’t use nginx but apache as webserver and my php version is 7.0 and the problem exists from the scratch.
Have you looked at your Apache logs? a common path for them would be /var/log/apache2/error.log
Thank’s for the tip. I solved the problem.
Don’t leave us hanging! What was the solution?
Oh sorry, it was a permission problem which I found in the error.log thank’s of your hint.
Thanks! I had a hunch that was it.
