I am using Nextcloud on my iPhone7. The application version is 2.16 (00012).
I always get Network connection error while browsing folders. There are other people who uses nextcloud app on their android phones reaching the same nextcloud server.
What might be the problem and how can I fix it.
Thanks.
Is this issue permantly present?
Could you confirm message by clicking on the red cross and refresh?
Yes, issue present.
But I think I have found the reason of the problem. Our server uses self
signed SSL certificate and ios 10 does not trust our SSL certificate.
Now I am trying to solve this restriction problem.
Thanks,
รmer
ลunu yazdฤฑ:
How does it work for you? Did you succeed?
