Need to reinstall from scratch? Containers not starting/removed after upgrade from 11.7 to 11.8 failed
This is very incomplete. Last night’s update seems to have caused pretty bad failure. If I can provide any more information please let me know.
    • AIO 11.7/8 / Server version unknown (was removed)
    • ubuntu 24.04/docker
    • apache (latest AIO update))
    • AIO
    • whichever got shipped with dockerised AIO 11.7
    • Yes
    • apparently during last night's update
    • AIO
    • no.
(1) AIO docker containers stopped and aren’t starting up, apparently since last night’s attempted update to 11.8.
(3) nextcloud-aio-nextcloud container was initially still present (though stopped). Several attempts in AIO Interface to stop and start the containers were unsuccessful and eventually the n-a-n container has disappeared completely, but still shows as stopped in AIO.
  1. Not sure it can be replicated. Seems pretty catastrophic.
  2. The N-a-n container has disappeared and AIO doesn’t seem able to recreate it.
Please let me know if I can provde any other logs (with a non-existent n-a-n container).
2025-09-18T16:33:35.345465846Z Trying to fix docker.sock permissions internally...
2025-09-18T16:33:35.349263102Z Creating docker group internally with id 984
2025-09-18T16:33:35.721547961Z e[0;31mYou've set AIO_COMMUNITY_CONTAINERS but the option was removed.
2025-09-18T16:33:35.721574119Z The community containers get managed via the AIO interface now.e[0m
2025-09-18T16:33:35.976494367Z e[0;92mInitial startup of Nextcloud All-in-One complete!
2025-09-18T16:33:35.976538095Z You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
2025-09-18T16:33:35.976545200Z E.g. https://internal.ip.of.this.server:8080
2025-09-18T16:33:35.976549807Z ⚠️ Important: do always use an ip-address if you access this port and not a domain as HSTS might block access to it later!
2025-09-18T16:33:35.976555873Z
2025-09-18T16:33:35.976559861Z If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
2025-09-18T16:33:35.976565107Z https://your-domain-that-points-to-this-server.tld:8443e[0m
2025-09-18T16:33:36.271444099Z /usr/lib/python3.12/site-packages/supervisor/options.py:13: UserWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html. The pkg_resources package is slated for removal as early as 2025-11-30. Refrain from using this package or pin to Setuptools<81.
2025-09-18T16:33:36.271472673Z   import pkg_resources
2025-09-18T16:33:37.351729371Z ++ head -1 /mnt/docker-aio-config/data/daily_backup_time
2025-09-18T16:33:37.353875469Z + BACKUP_TIME=23:45
2025-09-18T16:33:37.353911390Z + export BACKUP_TIME
2025-09-18T16:33:37.353918415Z + export DAILY_BACKUP=1
2025-09-18T16:33:37.353923539Z + DAILY_BACKUP=1
2025-09-18T16:33:37.353929105Z ++ sed -n 2p /mnt/docker-aio-config/data/daily_backup_time
2025-09-18T16:33:37.358343387Z + '[' '' '!=' automaticUpdatesAreNotEnabled ']'
2025-09-18T16:33:37.358372433Z + export AUTOMATIC_UPDATES=1
2025-09-18T16:33:37.358377905Z + AUTOMATIC_UPDATES=1
2025-09-18T16:33:37.358382662Z ++ sed -n 3p /mnt/docker-aio-config/data/daily_backup_time
2025-09-18T16:33:37.359825081Z + '[' '' '!=' successNotificationsAreNotEnabled ']'
2025-09-18T16:33:37.359848023Z + export SEND_SUCCESS_NOTIFICATIONS=1
2025-09-18T16:33:37.359852935Z + SEND_SUCCESS_NOTIFICATIONS=1
2025-09-18T16:33:37.359857732Z + set +x
2025-09-18T16:33:37.405971507Z [18-Sep-2025 16:33:37] NOTICE: fpm is running, pid 189
2025-09-18T16:33:37.406009650Z [18-Sep-2025 16:33:37] NOTICE: ready to handle connections
2025-09-18T16:33:37.411271225Z [Thu Sep 18 16:33:37.410600 2025] [mpm_event:notice] [pid 183:tid 183] AH00489: Apache/2.4.65 (Unix) OpenSSL/3.5.2 configured -- resuming normal operations
2025-09-18T16:33:37.411297864Z [Thu Sep 18 16:33:37.410654 2025] [core:notice] [pid 183:tid 183] AH00094: Command line: 'httpd -D FOREGROUND'
2025-09-18T16:33:37.416555121Z {"level":"info","ts":1758213217.415861,"msg":"maxprocs: Leaving GOMAXPROCS=8: CPU quota undefined"}
2025-09-18T16:33:37.416577094Z {"level":"info","ts":1758213217.4160771,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":121269790310,"previous":9223372036854775807}
2025-09-18T16:33:37.416580811Z {"level":"info","ts":1758213217.416119,"msg":"using config from file","file":"/Caddyfile"}
2025-09-18T16:33:37.417571078Z {"level":"info","ts":1758213217.4174411,"msg":"adapted config to JSON","adapter":"caddyfile"}
2025-09-18T16:33:37.421124752Z {"level":"info","ts":1758213217.4206748,"msg":"serving initial configuration"}
2025-09-18T16:37:35.786919787Z Deleting duplicate sessions
2025-09-18T17:00:33.761806114Z NOTICE: PHP message: Slim Application Error
2025-09-18T17:00:33.761858738Z Type: GuzzleHttp\Exception\ClientException
2025-09-18T17:00:33.761867709Z Code: 404
2025-09-18T17:00:33.761873554Z Message: Client error: `GET http://127.0.0.1/v1.41/containers/nextcloud-aio-nextcloud/logs?stdout=true&stderr=true&timestamps=true` resulted in a `404 Not Found` response:
2025-09-18T17:00:33.761881535Z {"message":"No such container: nextcloud-aio-nextcloud"}
2025-09-18T17:00:33.761888056Z File: /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Exception/RequestException.php
2025-09-18T17:00:33.761894127Z Line: 111
2025-09-18T17:00:33.761899611Z Trace: #0 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Middleware.php(72): GuzzleHttp\Exception\RequestException::create(Object(GuzzleHttp\Psr7\Request), Object(GuzzleHttp\Psr7\Response), NULL, Array, NULL)
2025-09-18T17:00:33.761907060Z #1 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(209): GuzzleHttp\Middleware::{closure:{closure:{closure:GuzzleHttp\Middleware::httpErrors():60}:61}:67}(Object(GuzzleHttp\Psr7\Response))
2025-09-18T17:00:33.761914567Z #2 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(158): GuzzleHttp\Promise\Promise::callHandler(1, Object(GuzzleHttp\Psr7\Response), NULL)
2025-09-18T17:00:33.761921268Z #3 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/TaskQueue.php(52): GuzzleHttp\Promise\Promise::{closure:GuzzleHttp\Promise\Promise::settle():156}()
2025-09-18T17:00:33.761927927Z #4 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(251): GuzzleHttp\Promise\TaskQueue->run(true)
2025-09-18T17:00:33.761934188Z #5 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(227): GuzzleHttp\Promise\Promise->invokeWaitFn()
2025-09-18T17:00:33.761940338Z #6 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(272): GuzzleHttp\Promise\Promise->waitIfPending()
2025-09-18T17:00:33.761946286Z #7 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(229): GuzzleHttp\Promise\Promise->invokeWaitList()
2025-09-18T17:00:33.761952326Z #8 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(69): GuzzleHttp\Promise\Promise->waitIfPending()
2025-09-18T17:00:33.761958540Z #9 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Client.php(189): GuzzleHttp\Promise\Promise->wait()
2025-09-18T17:00:33.761985961Z #10 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/ClientTrait.php(44): GuzzleHttp\Client->request('GET', 'http://127.0.0....', Array)
2025-09-18T17:00:33.761994350Z #11 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(146): GuzzleHttp\Client->get('http://127.0.0....')
2025-09-18T17:00:33.761999035Z #12 /var/www/docker-aio/php/src/Controller/DockerController.php(71): AIO\Docker\DockerActionManager->GetLogs('nextcloud-aio-n...')
2025-09-18T17:00:33.762004195Z #13 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(39): AIO\Controller\DockerController->GetLogs(Object(GuzzleHttp\Psr7\ServerRequest), Object(GuzzleHttp\Psr7\Response), Array)
2025-09-18T17:00:33.762009665Z #14 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(362): Slim\Handlers\Strategies\RequestResponse->__invoke(Array, Object(GuzzleHttp\Psr7\ServerRequest), Object(GuzzleHttp\Psr7\Response), Array)
2025-09-18T17:00:33.762015164Z #15 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\Routing\Route->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-09-18T17:00:33.762020082Z #16 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-09-18T17:00:33.762025074Z #17 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(321): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-09-18T17:00:33.762029722Z #18 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(74): Slim\Routing\Route->run(Object(GuzzleHttp\Psr7\ServerRequest))
2025-09-18T17:00:33.762034342Z #19 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-09-18T17:00:33.762039171Z #20 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Slim\Routing\RouteRunner))
2025-09-18T17:00:33.762044551Z #21 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-09-18T17:00:33.762049713Z #22 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2025-09-18T17:00:33.762055986Z #23 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(36): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-09-18T17:00:33.762060993Z #24 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2025-09-18T17:00:33.762066504Z #25 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-09-18T17:00:33.762077113Z #26 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2025-09-18T17:00:33.762082519Z #27 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-09-18T17:00:33.762087452Z #28 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-09-18T17:00:33.762092154Z #29 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-09-18T17:00:33.762096694Z #30 /var/www/docker-aio/php/public/index.php(198): Slim\App->run()
2025-09-18T17:00:33.762101144Z #31 {main}
2025-09-18T17:00:33.762104943Z Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
PASTE
PASTE HERE
inaccessible
This is the method I have been using for a long time to update Nextcloud AIO:
:backhand_index_pointing_right: Link to the procedure
Today I updated from 11.7.0 → 11.8.0 using the same approach on three different servers, and everything went smoothly without any issues.
It’s important to keep in mind that when a new release comes out, the source server is often overloaded. This means that pulling the Docker images that are part of the AIO package can take considerably longer. Another factor is, of course, the internet connection speed of the server itself.
Examples from my case:
  • Server 1 – update took about 20 minutes
  • Servers 2 and 3 – updates took almost 50 minutes
I am not sure about this. The images are hosted on ghcr.io this would mean AIO overloads GitHubs infrastructure? I doubt it…
Thanks for your quick replies.
One day later and bracing myself for a clean reinstall, everything seems to be working like a charm.
How very strange and pleasant!
Similar issue here.. While upgrading to 11.8.0 all containers came up except for Apache, which is in yellow and it’s marked as (starting). delete apache container and re-started containers. the system rebuild the apache container but still stuck at starting. however im able to access nextcloud either via the local ip and also via my web domain.
when i click on logs on the apache container, this is what i get:
2025-09-24T05:02:18.741257198Z Waiting for Nextcloud to start...
2025-09-24T05:02:23.749798460Z Connection to nextcloud-aio-nextcloud (172.18.0.12) 9000 port [tcp/*] succeeded!
2025-09-24T05:02:24.234787934Z /usr/lib/python3.12/site-packages/supervisor/options.py:13: UserWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html. The pkg_resources package is slated for removal as early as 2025-11-30. Refrain from using this package or pin to Setuptools<81.
2025-09-24T05:02:24.234829176Z   import pkg_resources
2025-09-24T05:02:25.336634330Z [Wed Sep 24 05:02:25.336009 2025] [mpm_event:notice] [pid 44:tid 44] AH00489: Apache/2.4.65 (Unix) configured -- resuming normal operations
2025-09-24T05:02:25.336683702Z [Wed Sep 24 05:02:25.336065 2025] [core:notice] [pid 44:tid 44] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
2025-09-24T05:02:25.353513406Z {"level":"info","ts":1758690145.353277,"msg":"maxprocs: Leaving GOMAXPROCS=48: CPU quota undefined"}
2025-09-24T05:02:25.353939772Z {"level":"info","ts":1758690145.353601,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":151783147929,"previous":9223372036854775807}
2025-09-24T05:02:25.354003275Z {"level":"info","ts":1758690145.3536415,"msg":"using config from file","file":"/tmp/Caddyfile"}
2025-09-24T05:02:25.356404477Z {"level":"info","ts":1758690145.3561082,"msg":"adapted config to JSON","adapter":"caddyfile"}
2025-09-24T05:02:25.370012987Z {"level":"info","ts":1758690145.36968,"msg":"serving initial configuration"}
Any ideas ?
In addition to deleting Apache docker, did you also delete the Apache installation image?
Thanks for replying. I wouldn’t know how to delete the installation image. Also, did not want to delete things on the risk it might break the whole installation.
Running nextcloud AIO on an UnRaid server.
funny thing is everything appears to be working.
Im still able to access nextcloud via the web.
Error logs show this:
Error index NotPermittedExceptionCould not create folder “/appdata_oc2gmu9fypgs/appstore/app-discover-cache/68d3cf31-92a”, folder exists but unable to get cache entry
Debug admin_audit RuntimeExceptionThe loading of lazy AppConfig values have been triggered by app “admin_audit”
also from my cloudflare tunnel client:
025-09-24T11:04:24Z ERR error=“stream 1877 canceled by remote with error code 0” connIndex=3 event=1 ingressRule=0 originService=http://192.168.1.210:11000
Im always scared to update as things always break after an update.
You can find my tutorial here - Nextcloud AIO v10.1.1 - Apache Will Not Start - #19 by vawaver
hi, not using portainer but i figured your guide could be applied same way.
under unraid:
Deleted the apache image.
found bunch of orphaned images left from previous installs i guess and deleted those.
Went back to the containers page and now it says i have an update. It recreated apache container.
it now upgraded to 11.9.0
However, apache container still shows in yellow (starting) even though everything seems to be working.
on your guide it says to delete all containers, but i dont want to loose my configuration.
What container holds the configuration and which containers are ok to delete ?
nextcloud-aio-apache
started
nextcloud-aio-clamav
started
nextcloud-aio-collabora
started
nextcloud-aio-database
started
nextcloud-aio-fulltextsearch
started
nextcloud-aio-imaginary
started
nextcloud-aio-mastercontainer
started
started
nextcloud-aio-notify-push
started
nextcloud-aio-redis
started
nextcloud-aio-talk
started
You don’t need to worry about deleting containers. In Docker, containers are just the “running instances.” All the important stuff — your database, Nextcloud config, settings — is stored in persistent volumes.
That means:
  • You can safely remove any of the Nextcloud AIO containers.
  • When you run docker compose up -d again, they will be recreated automatically.
  • As long as you don’t touch the volumes, none of your data or configuration will be lost.
So if something looks broken, removing containers is fine.
The only thing you must never delete are the volumes — that’s where your data lives.
