31.0.2
TrueNAS-SCALE Electric Eel 24.10
NA
NA
- PHP version (e.g, 8.3):
8.3.19
TrueNAS App/Docker
No
I have configured Nextcloud Assistant to use my local Ollama instance (also running on TrueNAS) and noticed that there was a 5 minute delay when I tried to use Chat with AI. I found that this is due to the jobs being run by cron. I found that if I shell into the Nextcloud container and run occ background-job:worker it works great. I don’t want to have to shell in every time I restart. I have searched like mad on how to run the worker automatically and found little bits here and there but they are all contradictory and confusing. The best option I saw was actually from chatting with the assistant but it seems incomplete and I think may be incorrect. It said to mount a volume and create a shell script that will run workers and time time out / restart them. But it didn’t say how that script would get run automatically. I’m also not clear if the workers need to be restart regularly or not.
TLDR What is the process for automatically running background workers when Nextcloud is running in a docker container?
"default_phone_region": "US",
"htaccess.RewriteBase": "\/",
"apps_paths": [
"url": "\/apps",
"writable": false
"url": "\/custom_apps",
"writable": true
"overwritehost": "nextcloud.xxxxxxxx.xxxxx:8443",
"overwriteprotocol": "https",
"upgrade.disable-web": true,
"dbtype": "pgsql",
"version": "31.0.2.1",
"overwrite.cli.url": "https:\/\/nextcloud.xxxxxxxx.xxxxx:8443",
"dbport": "",
"mail_smtpmode": "smtp",
"mail_smtpsecure": "ssl",
"mail_sendmailmode": "smtp",
"mail_smtpport": "465",
"mail_smtpauth": 1,
"loglevel": 2,
"redis": {
"port": 6379
"app_install_overwrite": [
"news",
"richdocumentscode",
"journal",
"weather",
"cookbook"
"127.0.0.1",
"192.168.1.254",
"localhost",
"nextcloud",
"nextcloud.xxxxxxxx.xxxxx",
- activity: 4.0.0
- app_api: 5.0.2
- assistant: 2.4.0
- bruteforcesettings: 4.0.0
- calendar: 5.2.1
- circles: 31.0.0
- comments: 1.21.0
- contacts: 7.0.5
- contactsinteraction: 1.12.0
- context_chat: 4.2.0
- cookbook: 0.11.3
- dashboard: 7.11.0
- dav: 1.33.0
- federation: 1.21.0
- files: 2.3.1
- files_downloadlimit: 4.0.0
- files_pdfviewer: 4.0.0
- files_reminders: 1.4.0
- files_sharing: 1.23.1
- files_trashbin: 1.21.0
- files_versions: 1.24.0
- firstrunwizard: 4.0.0
- integration_openai: 3.5.0
- integration_openstreetmap: 2.0.1
- logreader: 4.0.0
- mail: 4.3.6
- notes: 4.11.0
- notifications: 4.0.0
- oauth2: 1.19.1
- password_policy: 3.0.0
- privacy: 3.0.0
- profile: 1.0.0
- provisioning_api: 1.21.0
- recommendations: 4.0.0
- related_resources: 2.0.0
- richdocuments: 8.6.4
- serverinfo: 3.0.0
- settings: 1.14.0
- sharebymail: 1.21.0
- systemtags: 1.21.1
- tasks: 0.16.1
- text: 5.0.0
- theming: 2.6.1
- updatenotification: 1.21.0
- user_status: 1.11.0
- viewer: 4.0.0
- weather_status: 1.11.0
- webhook_listeners: 1.2.0
- workflowengine: 2.13.0
- admin_audit: 1.21.0
- encryption: 2.19.0
- files_external: 1.23.0
- journal: 0.0.4 (installed 0.0.4)
- photos: 4.0.0-dev.1 (installed 2.4.0)
- qownnotesapi: 25.2.0 (installed 25.2.0)
- support: 3.0.0 (installed 1.11.0)
- survey_client: 3.0.0 (installed 2.0.0)
- suspicious_login: 9.0.1
- user_ldap: 1.22.0
Thanks,
-Bill
