Sorry to hear you’re facing problems ![]()
example
longer
example
here
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can ![]()
Nextcloud version (eg, 29.0.5): 29.0.7.1
Operating system and version (eg, Ubuntu 24.04): Debian 12
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 8.3): 8.2.20
I accidentally deleted my DB, how could I restore it?
Is this the first time you’ve seen this error? (Y/N):Y
The output of your config.php file in var/www/nextcloud (make sure you remove any identifiable information!):
'instanceid' => 'Redacted',
'passwordsalt' => 'Redacted',
'secret' => 'Redacted',
0 => 'Redacted',
'version' => '29.0.7.1',
'overwrite.cli.url' => 'Redacted',
'dbname' => 'nextcloud',
'dbhost' => 'localhost:8080',
'dbuser' => 'nextclouduser',
'dbpassword' => 'Redacted',
'theme' => '',
'loglevel' => 2,
I spotted this in the error, and this is what happens when accessing the website
```Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
More details can be found in the server log.```
```Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [1045] Access denied for user 'nextclouduser'@'localhost' (using password: YES)```
