I’m having trouble mounting an SMB share from the same server on which I’m hosting my Nextcloud Docker image (The linuxserver distribution specifically). The documentation is a bit vague about how this works, and since Nextcloud offers no error messages here, I can’t diagnose the issue easily. I’m using global credentials, but I’ve also tried entering my server share credentials manually, with the same results. Can someone help me determine if I’m entering my mount info properly?
HOST: 192.168.x.x (The IP address of the server, but I redacted the last digits. I’ve also tried the hostname, //hostname, smb://192.168.x.x, and smb://hostname.local)
SHARE: share (Just an example name, but I’m using the name of the remote share on my server, I’ve tried with and without a / preceding it)
REMOTE SUBFOLDER: (nothing)
DOMAIN: (nothing)
I assume the issue has to do with the host, but none of the documentation specifies what format should be used for it - could someone help me out?
