If you’re urgently looking for support to keep your business running, consider checking out our paid support options.
In order to help you as quickly as possible, before clicking Create Topic please provide as much of the following as you can (you can cut and paste this into your topic):
Nextcloud version (eg, 10.0.2): 12.0.3
Operating system and version (eg, Ubuntu 16.04): QTS 4.3.3
PHP version (eg, 5.6):
Is this the first time you’ve seen this error?: Just installed Nextcloud on a QNAP
Can you reliably replicate it? (If so, please outline steps):
HTTP-header “X-Frame-Options” er ikke satt opp lik “SAMEORIGIN”. Dette kan være en sikkerhetsrisiko og vi anbefaler at denne innstillingen endres.
“Strict-Transport-Security”- (Streng transportsikkerhet) HTTP-hodet er ikke satt opp til minst “15552000” sekunder. For forbedret sikkerhet anbefales det å skru på HSTS som beskrevet i våre sikkerhetstips.
I’m trying to fix this problem, but I’m a totally newbie regarding this. I do not know how to edit these files etc. I do now how to SSH into my QNAP, but I’m not sure to find the right files that I need to be configuring though.
I’m more of a user that likes to look at the screen, and find the file, but when I’m working in SSH environment I’m totally blanc.
I’m also facing a problem regarding e-mail themes, can’t seeme to find the themes I can use for describing new users what rules etc that needs to be followed to use my nextcloud server.
I want to use CRON, but that doesn’t seem to work. It says I need to have som parameters in some file, but cant seem to find the file either:(
I would love some help, a step by step instruction list of what to do would be much appretiated.
PHP Comments starting with '#' are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T15:06:50+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T15:04:58+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T14:51:26+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T14:43:08+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T14:28:07+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T14:23:59+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T14:19:29+0100
Error PHP Automatically populating $HTTP_RAW_POST_DATA is deprecated and will be removed in a future version. To avoid this warning set ‘always_populate_raw_post_data’ to ‘-1’ in php.ini and use the php://input stream instead. at Unknown#0 2017-10-29T12:23:11+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:55:11+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:55:09+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:55:07+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:53:02+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:48:17+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:44:39+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:44:35+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:44:01+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:43:53+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:43:52+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:43:42+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:43:31+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:38:58+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:37:39+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:35:39+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:35:08+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:34:58+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:34:29+0100
Error PHP Automatically populating $HTTP_RAW_POST_DATA is deprecated and will be removed in a future version. To avoid this warning set ‘always_populate_raw_post_data’ to ‘-1’ in php.ini and use the php://input stream instead. at Unknown#0 2017-10-29T11:34:22+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:34:05+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:33:52+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:33:51+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:33:43+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:33:39+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:33:15+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:29:29+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:29:27+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:28:57+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:28:54+0100
Error PHP Automatically populating $HTTP_RAW_POST_DATA is deprecated and will be removed in a future version. To avoid this warning set ‘always_populate_raw_post_data’ to ‘-1’ in php.ini and use the php://input stream instead. at Unknown#0 2017-10-29T11:27:03+0100
Error PHP Automatically populating $HTTP_RAW_POST_DATA is deprecated and will be removed in a future version. To avoid this warning set ‘always_populate_raw_post_data’ to ‘-1’ in php.ini and use the php://input stream instead. at Unknown#0 2017-10-29T11:25:41+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:25:31+0100
Error PHP Automatically populating $HTTP_RAW_POST_DATA is deprecated and will be removed in a future version. To avoid this warning set ‘always_populate_raw_post_data’ to ‘-1’ in php.ini and use the php://input stream instead. at Unknown#0 2017-10-29T11:24:48+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:11:15+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:10:49+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:10:48+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:10:47+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:10:44+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:10:28+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:10:08+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:10:06+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:04:05+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:04:03+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:03:11+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:03:09+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:03:08+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:03:06+0100
Error PHP Comments starting with ‘#’ are deprecated in Unknown on line 1 at Unknown#0 2017-10-29T11:02:58+0100
Dont know how to find this:frowning:
