Need help setting up Amazon SES as SMTP provider
    • 30.0.4 (docker)
    • Ubuntu 22
    • N/A
    • Nginx
    • 8.2.27
    • no
    • N/A
    • Official docker image (non-AIO) using docker compose
    • Yes, but only as a DNS (not proxied)
I’ve been trying to set up mail sender on my instance, but I can’t seem to get the test mail to be sent properly. When I try to send a test mail from the “Basic Settings” page, I get the following error.
A problem occurred while sending the email. Please revise your settings. (Error: Email could not be sent. Check your mail server log)
  1. Set up identity and user on Amazon SES
  2. Configure the nextcloud’s smtp settings
  3. From the Basic Settings page in the Administration Settings, try to send the test email by clicking Send Mail button
No error or warning messages appear on the log
No relevant messages
N/A
        "htaccess.RewriteBase": "\/",
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "port": 6379
        "upgrade.disable-web": false,
            "localhost",
            "[REDACTED]"
        "dbtype": "mysql",
        "version": "30.0.4.1",
        "overwrite.cli.url": "https:\/\/[REDACTED]",
        "dbport": "",
        "mysql.utf8mb4": true,
        "twofactor_enforced": "true",
        "twofactor_enforced_groups": [],
        "overwriteprotocol": "https",
        "default_phone_region": "KR",
        "loglevel": 0,
        "theme": "",
        "max_chunk_size": 20971520,
        "maintenance_window_start": 18,
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "mail_smtpauth": true,
        "mail_smtpport": "465",
        "mail_smtpsecure": "ssl",
        "mail_smtpauthtype": "LOGIN"
  - activity: 3.0.0
  - app_api: 4.0.3
  - bruteforcesettings: 3.0.0
  - circles: 30.0.0
  - comments: 1.20.1
  - contactsinteraction: 1.11.0
  - dashboard: 7.10.0
  - dav: 1.31.1
  - federation: 1.20.0
  - files: 2.2.0
  - files_downloadlimit: 3.0.0
  - files_external: 1.22.0
  - files_pdfviewer: 3.0.0
  - files_reminders: 1.3.0
  - files_sharing: 1.22.0
  - files_trashbin: 1.20.1
  - files_versions: 1.23.0
  - firstrunwizard: 3.0.0
  - logreader: 3.0.0
  - notifications: 3.0.0
  - oauth2: 1.18.1
  - password_policy: 2.0.0
  - photos: 3.0.2
  - privacy: 2.0.0
  - provisioning_api: 1.20.0
  - recommendations: 3.0.0
  - related_resources: 1.5.0
  - serverinfo: 2.0.0
  - settings: 1.13.0
  - sharebymail: 1.20.0
  - support: 2.0.0
  - survey_client: 2.0.0
  - suspicious_login: 8.0.0
  - systemtags: 1.20.0
  - text: 4.1.0
  - theming: 2.5.0
  - twofactor_totp: 12.0.0-dev
  - updatenotification: 1.20.0
  - user_status: 1.10.0
  - viewer: 3.0.0
  - weather_status: 1.10.0
  - workflowengine: 2.12.0
  - admin_audit: 1.20.0
  - encryption: 2.18.0
  - user_ldap: 1.21.0
Compose
##### docker-compose.yml
services:
  app:
    container_name: nextcloud_app
    image: nextcloud:${NEXTCLOUD_VERSION}
    depends_on:
      - db
      - redis
    links:
      - db
      - redis
    environment:
      - NEXTCLOUD_TRUSTED_DOMAINS=${DOMAIN}
      - MYSQL_HOST=db
      - MYSQL_PASSWORD=${MYSQL_PASSWORD}
      - MYSQL_DATABASE=${MYSQL_DATABASE}
      - MYSQL_USER=${MYSQL_USER}
      - REDIS_HOST=redis
      - NEXTCLOUD_ADMIN_USER=${NEXTCLOUD_ADMIN_USER}
      - NEXTCLOUD_ADMIN_PASSWORD=${NEXTCLOUD_ADMIN_PASSWORD}
      - OBJECT_STORAGE=1
      - OBJECT_STORAGE_CLASS=\\OC\\Files\\ObjectStore\\S3
      - OBJECT_STORAGE_BUCKET=${MINIO_BUCKET}
      - OBJECT_STORAGE_AUTOCREATE_BUCKET=true
      - OBJECT_STORAGE_REGION=ap-northeast-2
      - OBJECT_STORAGE_ENDPOINT=${MINIO_ENDPOINT}
      - OBJECT_STORAGE_ACCESS_KEY=${MINIO_ACCESS_KEY}
      - OBJECT_STORAGE_SECRET_KEY=${MINIO_SECRET_KEY}
      - SMTP_HOST=${NEXTCLOUD_SMTP_HOST}
      - SMTP_PORT=${NEXTCLOUD_SMTP_PORT}
      - SMTP_SECURE=${NEXTCLOUD_SMTP_SECURE}
      - SMTP_NAME=${NEXTCLOUD_SMTP_NAME}
      - SMTP_PASSWORD=${NEXTCLOUD_SMTP_PASSWORD}
      - MAIL_FROM_ADDRESS=${NEXTCLOUD_MAIL_FROM_ADDRESS}
      - MAIL_DOMAIN=${NEXTCLOUD_MAIL_DOMAIN}
    volumes:
      - ./data/nextcloud:/var/www/html
      - ./config/nextcloud:/var/www/html/config
    networks:
      - cloud-net
  db:
    container_name: nextcloud_db
    image: mariadb:11.4
    volumes:
      - ./data/db:/var/lib/mysql
    environment:
      - MYSQL_ROOT_PASSWORD=${MYSQL_ROOT_PASSWORD}
    networks:
      - cloud-net
  redis:
    container_name: nextcloud_redis
    image: redis:alpine
    networks:
      - cloud-net
  cron:
    container_name: nextcloud_cron
    image: nextcloud:${NEXTCLOUD_VERSION}-apache
    entrypoint: /cron.sh
    depends_on:
      - app
    links:
      - db
      - redis
    environment:
      - MYSQL_HOST=db
      - REDIS_HOST=redis
      - OBJECT_STORAGE=1
    volumes:
    networks:
      - cloud-net
networks:
  cloud-net:
    driver: bridge
##### docker-compose.override.yml
# version: '3'
services:
  db:
    restart: unless-stopped
    # ports:
    #   - 3306:3306
  app:
    hostname: nextcloud
    ports:
      - 8080:80
  redis:
  cron:
I see you’re providing your MAIL* and SMTP* config values via your Compose. Make sure those values are the correct ones, as they override whatever you configure in your config/config.php and/or via the GUI. See the note here here for the docker image regarding SMTP.
I’d suggest using steps described in the Admin Manual under Email: Troubleshooting. Specifically the logging related ones to debug what is going on.
