I used
sudo docker run \
--init \
--sig-proxy=false \
--name nextcloud-aio-mastercontainer \
--restart always \
--publish 80:80 \
--publish 8080:8080 \
--publish 8443:8443 \
--volume nextcloud_aio_mastercontainer:/mnt/docker-aio-config \
--volume /var/run/docker.sock:/var/run/docker.sock:ro \
nextcloud/all-in-one:latest
To install the nextcloud-aio
When I open the https://192.168.2.41:8080
, and enter my domain name, it says
The domain is not reachable on Port 443 from within this container. Have you opened port 443/tcp in your router/firewall? If yes is the problem most likely that the router or firewall forbids local access to your domain. You can work around that by setting up a local DNS-server.
curl http://localhost:443
worked
curl -v http://localhost:443
* Trying 127.0.0.1:443...
* Connected to localhost (127.0.0.1) port 443 (#0)
> GET / HTTP/1.1
> Host: localhost:443
> User-Agent: curl/7.81.0
> Accept: */*
* Mark bundle as not supporting multiuse
< HTTP/1.1 200 OK
< Content-Type: text/html
< ETag: "3586987658"
< Last-Modified: Fri, 08 Nov 2024 09:28:04 GMT
< Content-Length: 49
< Accept-Ranges: bytes
< Date: Fri, 08 Nov 2024 09:29:20 GMT
< Server: lighttpd/1.4.76
95a2efb10cbede42cf578357332875f07a4e6dfa69543a0a
* Connection #0 to host localhost left intact
But when I curl -v https://localhost:443
* ALPN, offering h2
* ALPN, offering http/1.1
* CAfile: /etc/ssl/certs/ca-certificates.crt
* CApath: /etc/ssl/certs
* TLSv1.0 (OUT), TLS header, Certificate Status (22):
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* (5454) (IN), , Unknown (72):
* error:0A00010B:SSL routines::wrong version number
* Closing connection 0
curl: (35) error:0A00010B:SSL routines::wrong version number
Could someone help me with this problem, 443 port is working on http not on https.
