Hi there,
I tried a lot of things already, but I don’t get it running. So I just ask here, perhaps somebody can help me.
My configuration is the following:
- I installed the NextcloudPi SD card image and everything is running very well.
- Then I installed Docker and installed an ebook library image/container which I can access via the configured port. And again, everything is working wonderfully.
Now, I would like to access the ebook library docker container via mycloud.url/library, but I’m having problems to configure the Apache Reverse Proxy right.
I tested copying
ProxyPass /library http://127.0.0.1:8080/library
ProxyPassReverse /library http://127.0.0.1:8080/library
into the nextcloud.conf and into a new conf file and the configuration from here (airsonic docker documentation), but when I try to load mycloud.url/library in my browser, I’m always redirected to the Nextcloud login screen.
I already consulted the Apache Documentation, Documentations to other docker images etc.
Does somebody of you got an idea how to do this correctly? I just don’t get any further.
Any help would be great!
Best regards
