- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
30.0.5
Official Docker FPM image
Caddy 2
Caddy 2
- PHP version (e.g, 8.3):
8.2
No
Ever since I installed Notify Push
- `Docker
- `No
This is basically a follow up of my comment in this Notify Push Github issue, because I thought it’s more a support request than a real problem with the app (probably).
I am trying to correctly setup the Notify Push app, so that it can be used by my clients.
Currently it seems to be half working.
If I load the Nextcloud website, it successfully makes a Websockets connection to the notify push server on wss://nc.example.de/push/ws and exchanges a few messages.
I’ve also noticed in the Websockets messages, that e.g. when I create a new file in a directory using the Desktop client, it gets a “notify_file” message.
However, it doesn’t actually reload the file list so that the this new file gets visible, but maybe that’s just how it works.
Also the metrics look fine:
./occ notify_push:metrics
Active connection count: 3
Active user count: 2
Total connection count: 6
Total database query count: 4
Events received: 15
Messages sent: 2
Nevertheless, when I execute occ notify_push:self-test on the Nextcloud container, I get an error message:
./occ notify_push:self-test
✓ redis is configured
✓ push server is receiving redis messages
✓ push server can load mount info from database
✓ push server can connect to the Nextcloud server
🗴 push server is not a trusted proxy by Nextcloud or another proxy in the chain.
Nextcloud resolved the following client address for the test request: "<my-public-ip>" instead of the expected "1.2.3.4" test value.
The following trusted proxies are currently configured: "172.19.0.0/16", "127.0.0.1"
The following x-forwarded-for header was received by Nextcloud: "<my-public-ip>"
from the following remote: <my-public-ip>
<my-public-ip> is not a trusted as a reverse proxy by Nextcloud
See https://docs.nextcloud.com/server/latest/admin_manual/configuration_server/reverse_proxy_configuration.html#defining-trusted-proxies for how to add trusted proxies.
If you're having issues getting the trusted proxy setup working, you can try bypassing any existing reverse proxy
in your setup by setting the `NEXTCLOUD_URL` environment variable to point directly to the internal Nextcloud webserver url
(You will still need the ip address of the push server added as trusted proxy)
My question is, what part of my Caddy/ Nextcloud configuration is wrong, that this self check doesn’t pass and how can I fix it?
And secondary, is it even necessary to fix this, or is this self-check just a false alarm, because the WS connection seems to be working (for public clients).
The problem is, that I don’t really know if I really have a reverse proxy.
Sure, I am using Caddy to proxy all the HTTPS requests to the PHP-FPM app, but it’s more something that I would see as a classical webserver.
In addition, I am using Unix sockets as much as possible, so that I don’t know if it makes sense to add the Nextcloud/ Notify Push Docker container (network 172.19.0.0/16) to my Caddy network (172.23.0.0/16) or the other way around.
Do I need to configure trusted proxies at all in my Nextcloud / Caddy configuration?
Do I need to add/ modify the “X-Forwarded-For” header in the Caddy configuration at all? IIRC it should add/forward one by default, if the IP is in the range of trusted_proxies.
Any help would be greatly appreciated, since this issue is bothering me for a really long time already.
If you are missing some logs/ configuration, feel free to ask.
- execute
occ notify_push:self-teston the Nextcloud container
2025/01/27 22:24:30 INFO http.log.access handled request {"request": {"remote_ip": "<my-public-ip>", "remote_port": "30813", "client_ip": "<my-public-ip>", "proto": "HTTP/3.0", "method": "POST", "host": "nc.example.de", "uri": "/apps/notify_push/pre_auth", "headers": {"Accept": ["application/json, text/plain, */*"], "Accept-Encoding": ["gzip, deflate, br, zstd"], "X-Requested-With": ["XMLHttpRequest, XMLHttpRequest"], "Dnt": ["1"], "Cookie": ["REDACTED"], "Accept-Language": ["de,en-US;q=0.7,en;q=0.3"], "Origin": ["https://nc.example.de"], "Sec-Fetch-Dest": ["empty"], "Sec-Fetch-Mode": ["cors"], "User-Agent": ["Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"], "Requesttoken": ["Ko+PMsbegTHWqF+HDP741/jp+uv3+8E6TtCkHjQnHws=:GtjcZ4f1wGiy3yyxRJKpo9O7tarcrYh3YaOSe1Jzb38="], "Content-Length": ["0"], "Sec-Fetch-Site": ["same-origin"], "Alt-Used": ["nc.example.de"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4867, "proto": "h3", "server_name": "nc.example.de"}}, "bytes_read": 0, "user_id": "", "duration": 0.054048284, "size": 32, "status": 200, "resp_headers": {"Referrer-Policy": ["no-referrer"], "Server": ["Caddy"], "Content-Disposition": ["inline; filename=\"\""], "Content-Length": ["32"], "X-Xss-Protection": ["1; mode=block"], "Strict-Transport-Security": ["max-age=31536000"], "X-Content-Type-Options": ["nosniff"], "X-Frame-Options": ["SAMEORIGIN"], "Content-Security-Policy": ["default-src 'none';base-uri 'none';manifest-src 'self';frame-ancestors 'none'"], "X-Robots-Tag": ["noindex, nofollow"], "X-Permitted-Cross-Domain-Policies": ["none"], "Date": ["Mon, 27 Jan 2025 22:24:30 GMT"], "Permissions-Policy": ["interest-cohort=()"], "Content-Type": ["text/html; charset=UTF-8"], "X-Request-Id": ["fjjrbVhtSYjtQOBEvEoO"], "Cache-Control": ["no-cache, no-store, must-revalidate"], "Feature-Policy": ["autoplay 'none';camera 'none';fullscreen 'none';geolocation 'none';microphone 'none';payment 'none'"]}}
2025/01/27 22:25:36 INFO http.log.access handled request {"request": {"remote_ip": "<my-public-ip>", "remote_port": "38474", "client_ip": "<my-public-ip>", "proto": "HTTP/1.1", "method": "GET", "host": "nc.example.de", "uri": "/index.php/apps/notify_push/uid", "headers": {"Authorization": ["REDACTED"], "X-Forwarded-For": ["<my-public-ip>"], "Accept": ["*/*"]}, "tls": {"resumed": true, "version": 772, "cipher_suite": 4867, "proto": "http/1.1", "server_name": "nc.example.de"}}, "bytes_read": 0, "user_id": "", "duration": 0.065548934, "size": 16, "status": 200, "resp_headers": {"Content-Disposition": ["inline; filename=\"\""], "X-Content-Type-Options": ["nosniff"], "Cache-Control": ["no-cache, no-store, must-revalidate"], "Content-Length": ["16"], "X-Request-Id": ["Nj6um7boc1EttfCTuhcl"], "X-Frame-Options": ["SAMEORIGIN"], "X-Xss-Protection": ["1; mode=block"], "Referrer-Policy": ["no-referrer"], "Alt-Svc": ["h3=\":443\"; ma=2592000"], "Feature-Policy": ["autoplay 'none';camera 'none';fullscreen 'none';geolocation 'none';microphone 'none';payment 'none'"], "Strict-Transport-Security": ["max-age=31536000"], "X-Permitted-Cross-Domain-Policies": ["none"], "Server": ["Caddy"], "Content-Type": ["text/html; charset=UTF-8"], "Content-Security-Policy": ["default-src 'none';base-uri 'none';manifest-src 'self';frame-ancestors 'none'"], "X-Robots-Tag": ["noindex, nofollow"], "Set-Cookie": ["REDACTED"], "Permissions-Policy": ["interest-cohort=()"]}}
2025/01/27 22:30:50 INFO http.log.access handled request {"request": {"remote_ip": "<my-public-ip>", "remote_port": "30810", "client_ip": "<my-public-ip>", "proto": "HTTP/3.0", "method": "POST", "host": "nc.example.de", "uri": "/apps/notify_push/pre_auth", "headers": {"Accept-Language": ["de,en-US;q=0.7,en;q=0.3"], "X-Requested-With": ["XMLHttpRequest, XMLHttpRequest"], "Requesttoken": ["nwYQgJc2O6gUY+nzvQsxI1ymSoEBc+gHR1X5Wyr9HTs=:r1FD1dYdevFwFJrF9WdgV3f0BcAqJaFKaCbPPkypbU8="], "Sec-Fetch-Mode": ["cors"], "Sec-Fetch-Site": ["same-origin"], "User-Agent": ["Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"], "Accept-Encoding": ["gzip, deflate, br, zstd"], "Accept": ["application/json, text/plain, */*"], "Dnt": ["1"], "Alt-Used": ["nc.example.de"], "Cookie": ["REDACTED"], "Content-Length": ["0"], "Origin": ["https://nc.example.de"], "Sec-Fetch-Dest": ["empty"]}, "tls": {"resumed": true, "version": 772, "cipher_suite": 4867, "proto": "h3", "server_name": "nc.example.de"}}, "bytes_read": 0, "user_id": "", "duration": 0.054329857, "size": 32, "status": 200, "resp_headers": {"X-Content-Type-Options": ["nosniff"], "Date": ["Mon, 27 Jan 2025 22:30:50 GMT"], "Content-Security-Policy": ["default-src 'none';base-uri 'none';manifest-src 'self';frame-ancestors 'none'"], "Content-Length": ["32"], "Content-Type": ["text/html; charset=UTF-8"], "Feature-Policy": ["autoplay 'none';camera 'none';fullscreen 'none';geolocation 'none';microphone 'none';payment 'none'"], "Permissions-Policy": ["interest-cohort=()"], "X-Permitted-Cross-Domain-Policies": ["none"], "Referrer-Policy": ["no-referrer"], "Server": ["Caddy"], "Content-Disposition": ["inline; filename=\"\""], "X-Request-Id": ["yB6f0dprEw98kXjxSfNo"], "Cache-Control": ["no-cache, no-store, must-revalidate"], "X-Frame-Options": ["SAMEORIGIN"], "X-Robots-Tag": ["noindex, nofollow"], "Strict-Transport-Security": ["max-age=31536000"], "X-Xss-Protection": ["1; mode=block"]}}
2025/01/27 22:37:08 INFO http.log.access handled request {"request": {"remote_ip": "<my-public-ip>", "remote_port": "39326", "client_ip": "<my-public-ip>", "proto": "HTTP/1.1", "method": "GET", "host": "nc.example.de", "uri": "/index.php/apps/notify_push/test/remote", "headers": {"X-Forwarded-For": ["1.2.3.4"], "Accept": ["*/*"]}, "tls": {"resumed": true, "version": 772, "cipher_suite": 4867, "proto": "http/1.1", "server_name": "nc.example.de"}}, "bytes_read": 0, "user_id": "", "duration": 0.02161757, "size": 14, "status": 200, "resp_headers": {"X-Xss-Protection": ["1; mode=block"], "Feature-Policy": ["autoplay 'none';camera 'none';fullscreen 'none';geolocation 'none';microphone 'none';payment 'none'"], "Content-Length": ["14"], "Content-Type": ["text/html; charset=UTF-8"], "Cache-Control": ["no-cache, no-store, must-revalidate"], "Content-Disposition": ["inline; filename=\"\""], "X-Permitted-Cross-Domain-Policies": ["none"], "Permissions-Policy": ["interest-cohort=()"], "X-Robots-Tag": ["noindex, nofollow"], "Alt-Svc": ["h3=\":443\"; ma=2592000"], "Set-Cookie": ["REDACTED"], "X-Request-Id": ["GNJyVnB6SPP6FNuYynTZ"], "Referrer-Policy": ["no-referrer"], "Strict-Transport-Security": ["max-age=31536000"], "X-Frame-Options": ["SAMEORIGIN"], "Server": ["Caddy"], "Content-Security-Policy": ["default-src 'none';base-uri 'none';manifest-src 'self';frame-ancestors 'none'"], "X-Content-Type-Options": ["nosniff"]}}
2025/01/27 22:37:08 INFO http.log.access handled request {"request": {"remote_ip": "<my-public-ip>", "remote_port": "39326", "client_ip": "<my-public-ip>", "proto": "HTTP/1.1", "method": "GET", "host": "nc.example.de", "uri": "/index.php/apps/notify_push/test/cookie", "headers": {"Accept": ["*/*"]}, "tls": {"resumed": true, "version": 772, "cipher_suite": 4867, "proto": "http/1.1", "server_name": "nc.example.de"}}, "bytes_read": 0, "user_id": "", "duration": 0.047174252, "size": 10, "status": 200, "resp_headers": {"Feature-Policy": ["autoplay 'none';camera 'none';fullscreen 'none';geolocation 'none';microphone 'none';payment 'none'"], "Cache-Control": ["no-cache, no-store, must-revalidate"], "Content-Type": ["application/json; charset=utf-8"], "Strict-Transport-Security": ["max-age=31536000"], "X-Content-Type-Options": ["nosniff"], "Set-Cookie": ["REDACTED"], "X-Robots-Tag": ["noindex, nofollow"], "Server": ["Caddy"], "Content-Security-Policy": ["default-src 'none';base-uri 'none';manifest-src 'self';frame-ancestors 'none'"], "X-Request-Id": ["djuNNblpkbA8agSJtX9q"], "X-Frame-Options": ["SAMEORIGIN"], "X-Permitted-Cross-Domain-Policies": ["none"], "X-Xss-Protection": ["1; mode=block"], "Referrer-Policy": ["no-referrer"], "Alt-Svc": ["h3=\":443\"; ma=2592000"], "Content-Length": ["10"], "Permissions-Policy": ["interest-cohort=()"]}}
"htaccess.RewriteBase": "\/",
"apps_paths": [
"url": "\/apps",
"writable": false
"url": "\/custom_apps",
"writable": true
"nc.example.de",
"trusted_proxies": array (
0 => '172.19.0.0/16', # actually no idea what value would make sense here
1 => '127.0.0.1',
"overwrite.cli.url": "https:\/\/nc.example.de",
"overwriteprotocol": "https",
"dbtype": "mysql",
"version": "30.0.5.1",
"mysql.utf8mb4": true,
"mail_smtpmode": "smtp",
"mail_sendmailmode": "smtp",
"mail_smtpport": "587",
"mail_smtpauth": 1,
"mail_smtpauthtype": "PLAIN",
"enable_previews": true,
"preview_max_memory": 512,
"enabledPreviewProviders": [
"OC\\Preview\\PNG",
"OC\\Preview\\JPEG",
"OC\\Preview\\GIF",
"OC\\Preview\\BMP",
"OC\\Preview\\XBitmap",
"OC\\Preview\\MP3",
"OC\\Preview\\TXT",
"OC\\Preview\\MarkDown",
"OC\\Preview\\OpenDocument",
"OC\\Preview\\Krita",
"OC\\Preview\\Imaginary",
"OC\\Preview\\HEIC",
"OC\\Preview\\PDF",
"OC\\Preview\\SVG",
"OC\\Preview\\Movie",
"OC\\Preview\\MKV",
"OC\\Preview\\MP4",
"OC\\Preview\\AVI"
"redis": {
"port": 6379,
"loglevel": 2,
"theme": "",
"onlyoffice": {
"verify_peer_off": true
"activity_use_cached_mountpoints": true,
"defaultapp": "files",
"default_phone_region": "DE",
"app_install_overwrite": [
"imageconverter",
"previewgenerator"
"jpeg_quality": 60,
"preview_max_x": 2048,
"preview_max_y": 2048,
"log_type": "errorlog",
"memories.vod.disable": false,
"memories.vod.external": true,
"memories.vod.bind": "",
"memories.vod.connect": "10.26.3.12:47788",
"memories.vod.path": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/go-vod-amd64",
"memories.exiftool_no_local": true,
"memories.exiftool": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/exiftool-amd64-glibc",
"memories.vod.qf": 25,
"maintenance_window_start": 0,
"memories.gis_type": 1,
"memories.vod.vaapi.low_power": true,
"memories.vod.vaapi": true,
"memories.vod.use_transpose": true
- activity: 3.0.0
- admin_audit: 1.20.0
- app_api: 4.0.5
- calendar: 5.0.9
- circles: 30.0.0
- comments: 1.20.1
- contacts: 6.1.3
- contactsinteraction: 1.11.0
- dashboard: 7.10.0
- dav: 1.31.1
- federation: 1.20.0
- files: 2.2.0
- files_downloadlimit: 3.0.0
- files_external: 1.22.0
- files_pdfviewer: 3.0.0
- files_reminders: 1.3.0
- files_retention: 1.19.0
- files_sharing: 1.22.0
- files_trashbin: 1.20.1
- files_versions: 1.23.0
- firstrunwizard: 3.0.0
- forms: 4.3.5
- groupfolders: 18.0.9
- imageconverter: 2.0.4
- memories: 7.4.1
- music: 2.1.1
- notes: 4.11.0
- notifications: 3.0.0
- notify_push: 1.0.0
- oauth2: 1.18.1
- onlyoffice: 9.5.0
- password_policy: 2.0.0
- polls: 7.2.9
- previewgenerator: 5.7.0
- privacy: 2.0.0
- provisioning_api: 1.20.0
- qownnotesapi: 24.11.0
- recommendations: 3.0.0
- related_resources: 1.5.0
- serverinfo: 2.0.0
- settings: 1.13.0
- sharebymail: 1.20.0
- snappymail: 2.38.2
- support: 2.0.0
- survey_client: 2.0.0
- systemtags: 1.20.0
- tasks: 0.16.1
- text: 4.1.0
- theming: 2.5.0
- twofactor_totp: 12.0.0-dev
- updatenotification: 1.20.0
- user_status: 1.10.0
- viewer: 3.0.0
- weather_status: 1.10.0
- workflowengine: 2.12.0
- bruteforcesettings: 3.0.0 (installed 2.4.0)
- cms_pico: 1.0.21 (installed 1.0.21)
- encryption: 2.18.0
- files_rightclick: 0.15.1 (installed 1.6.0)
- logreader: 3.0.0 (installed 2.13.0)
- maps: 1.5.0 (installed 1.5.0)
- photos: 3.0.2 (installed 2.0.1)
- suspicious_login: 8.0.0
- user_ldap: 1.21.0
Caddyfile
# Global settings
log default {
format console {
time_format wall
servers {
trusted_proxies static private_ranges 172.17.0.0/12 172.19.0.0/16 # Do I need this?
nc.example.de {
log # enables access logs
encode zstd gzip
root * /var/www/html
# Rules here are all from .htaccess
redir /.well-known/carddav /remote.php/dav 301
redir /.well-known/caldav /remote.php/dav 301
redir /.well-known/* /index.php{uri} 301 # Nextcloud front-controller handles routes to /.well-known
redir /remote/* /remote.php{uri} 301
# Secure headers, all from .htaccess except Permissions-Policy, STS and X-Powered-By
header {
Strict-Transport-Security max-age=31536000
Permissions-Policy interest-cohort=()
X-Content-Type-Options nosniff
X-Frame-Options SAMEORIGIN
Referrer-Policy no-referrer
X-XSS-Protection "1; mode=block"
X-Permitted-Cross-Domain-Policies none
X-Robots-Tag "noindex, nofollow"
-X-Powered-By
# Uncomment this block if you use the high speed files backend: https://github.com/nextcloud/notify_push
handle_path /push/* {
reverse_proxy unix//run/notify_push/notify_push.sock
#reverse_proxy 10.26.3.11:7867
# Uncomment this block if you use onlyoffice: https://github.com/nextcloud/all-in-one/blob/main/Containers/apache/Caddyfile
#handle_path /onlyoffice/* {
# reverse_proxy {$ONLYOFFICE_IP}:{$ONLYOFFICE_PORT} {
# header_up X-Forwarded-Host {host}/onlyoffice
# PicoCMS route
#route /sites* {
# uri strip_prefix /sites
# rewrite * /index.php/apps/cms_pico/pico_proxy/{uri}
# reverse_proxy 10.26.3.11:8080
# PHP block
php_fastcgi unix//run/nextcloud/nextcloud.sock {
root /var/www/html # This is needed because inside the container the root directory is different from the one I put in the "root" directive of this Caddyfile. If you don't change this, php-fpm will not be able to find the files to process.
env front_controller_active true # Enable pretty urls
env modHeadersAvailable true # Avoid sending the security headers twice
#header_up X-Forwarded-For "{remote}, 127.0.0.1" # Do I need this?
# From .htaccess, deny access to sensible files and directories
@forbidden {
path /build/* /tests/* /config/* /lib/* /3rdparty/* /templates/* /data/*
path /.* /autotest* /occ* /issue* /indie* /db_* /console*
not path /.well-known/*
error @forbidden 401
# Redirect Dav Clients
@davclnt header_regexp User-Agent (?i)^DavClnt
redir @davclnt /remote.php/webdav{uri} 302
# From .htaccess, set cache for versioned static files (cache-busting)
@immutable {
path *.css *.js *.mjs *.svg *.gif *.png *.jpg *.ico *.wasm *.tflite
query v=*
header @immutable Cache-Control "max-age=15778463, immutable"
# From .htaccess, set cache for normal static files
@static {
not query v=*
header @static Cache-Control "max-age=15778463"
# From .htaccess, cache fonts for 1 week
@woff2 path *.woff2
header @woff2 Cache-Control "max-age=604800"
file_server
Caddy Compose file
services:
caddy:
command:
- "caddy"
- "run"
- "--config"
- "/etc/caddy/Caddyfile"
- "--adapter"
- "caddyfile"
container_name: "Caddy"
image: "caddy:2"
ports:
- "443:443/tcp"
- "443:443/udp"
- "80:80/tcp"
- "8071:8071/tcp"
restart: "unless-stopped"
user: "1100:1100"
volumes:
- "/nfs/freenas/caddy/Caddyfile2:/etc/caddy/Caddyfile"
- "/nfs/freenas/caddy/caddy2-config:/config"
- "/nfs/freenas/caddy/caddy2-data:/data"
- "/nfs/freenas/caddy/nextcloud-unix-socket:/run/nextcloud"
- "/nfs/freenas/caddy/notify-push-unix-socket:/run/notify_push"
- "/nfs/freenas/ncfpm:/var/www/html:ro"
networks:
- caddy
networks:
caddy:
Nextcloud Compose file
version: '3'
services:
app:
container_name: nextcloudfpm
build:
context: https://github.com/major-mayer/nextcloud-docker.git
external_links:
- Caddy
depends_on:
- db
volumes:
- /nfs/freenas/ncfpm:/var/www/html
- /nfs/freenas/dockerfiles/nextcloud/custom-fpm.conf:/usr/local/etc/php-fpm.d/zzz-docker.conf
- /nfs/freenas/dockerfiles/nextcloud/custom-php.ini:/usr/local/etc/php/conf.d/zzz-docker.ini
- /nfs/freenas/caddy/nextcloud-unix-socket:/run/nextcloud
- /nfs/freenas/dockerfiles/nextcloud/redis-session.ini:/usr/local/etc/php/conf.d/redis-session.ini
restart: always
user: 1100:1100
environment:
- REDIS_HOST=redis
- MYSQL_HOST=db
- REDIS_HOST_PASSWORD=XXX
- PHP_MEMORY_LIMIT=1024M
tmpfs: /tmp # Required for Recognize app
notify_push:
image: icewind1991/notify_push:latest
container_name: nextcloud_notify_push
restart: always
user: 1100:1100
depends_on:
- app
environment:
- NEXTCLOUD_URL=https://nc.example.de
- SOCKET_PATH=/run/notify_push/notify_push.sock
volumes_from:
- app
volumes:
- /nfs/freenas/caddy/notify-push-unix-socket:/run/notify_push
command: ./notify_push /var/www/html/config/config.php
[more services...]
Nextcloud config
