Need freelancer for small job "error Deleting files..."
I have a debian box running Docker with nextcloud. I moved the data over to a larger drive and ran docker-compose from that drive. I copied the data over and some workstations resynched.
Now I am getting an error on some dir/files “error deleting files…” I have tried clearing the oc_file_locks in the mariadb but doesn’t seem to work as well as adding a ‘filelocking.enabled’ => false, to the config.php I’ve tried and don’t know what to do next. Not sure if installing redis will resolve but seems like a good thing to do. Are u able to help?
Thanks
Hello @mrchip
I can surely help you in your requirement.
Kindly reach me at [norman1{at}talentsfromindia{dot}com] or over skype, so that we can discuss in detail and can proceed it further.
Skype: live:norman_2445
Regards,
Norman
OFF TOPIC
best domainname in a whole while! great! :heart:
thank you, I’ll reach out to you
