Nextcloud version: 28.0.4
Operating system and version (eg, Ubuntu 20.04): Docker Nextcloud Image on Ubuntu 22.04
Apache or nginx version (eg, Apache 2.4.25): Docker Nextcloud Image
PHP version (eg, 7.4): Docker Nextcloud Image
For all my ~200 Users that sign in with LDAP, I am facing quota display problems. A quota of 1TB is displayed, while a quota of 500MB is enforced.
- my default quota as per user settings is 500MB:
- I have checked and validated in the database that the quota setting for all my users is set to “default”:
SELECT * FROM preferences where preferences.appid = 'files' and preferences.configkey = 'quota'; - A quota of 500MB is enforced - filling an account with 490 MB and then uploading a 10MB file leads to “insufficient space” errors.
- The visual bar in the files app is based on a 500MB quota. It turns red and almost full when 490MB are in the account.
- This issue does not appear for local users, only for LDAP users.
- In my LDAP sync settings, the fields for “Default Quota” and “Quota Field” are empty.
A few months ago I was syncing this from LDAP, and I may have had a default of 1TB set here (so that’s where the number may come from).
It’s been like this for months and multiple nextcloud versions. Users have used multiple browsers, computers, Nextcloud has been restarted and upgraded many times. I will not believe that this is a caching issue ![]()
Does anyone have an idea how to further troubleshoot this?
I can’t find any “cached” quota in the LDAP modules’ config:
mysql> SELECT DISTINCT preferences.configkey FROM preferences where preferences.appid = 'user_ldap';
| configkey |
| cached-group-memberships- |
| displayName |
| firstLoginAccomplished |
| foundDeleted |
| homePath |
| isDeleted |
| lastAvatarChecksum |
| lastProfileChecksum |
| uid |
LDAP Quota in the DB is empty too.
mysql> SELECT * FROM appconfig where appid = 'user_ldap' and configkey = 'ldap_quota_def';
| appid | configkey | configvalue | type | lazy |
| user_ldap | ldap_quota_def | | 2 | 0 |
Thanks for any hint!
