I am running NCP behind a reverse proxy (Traefik).
–> NC operation full functional
Remote access to the NCP Web-Panel by redirecting incoming calls from https://ncp.mydomain.com to https://localip:4443 works o.k., but for example pressing the “apply” button for nc-update results in message “invalid” origin.
That’s what I know, as well as using ncp-config. Using the Web Interface via Reverse Proxy was just a try to have a remote management tool. It’s much more comfortable than running ssh via VPN
Our NC (and many other services) is running well behind traefik.
