Hello all,
Iām testing ncp on a debian Buster virtualbox-VM before installing the software on a raspberry pi with two hard drives.
My goal is to test the whole backup and restore procedure, so I have a good feeling using the system
My problem I got stuck setting up the ncp-snapsync-auto, since Snapshots are not synced.
datadir is at /media/data/ncdata on a btrfs formatted drive
snapshots are at /media/data/ncp-snapshots
Backupdrive for config and database: /media/backup (btrfs formatted drive)
snapshots should be synced to /media/backup/ncp-snapshots
I havenāt activated compression.
I have made the following attemts to troubleshoot:
I tried to run the command
/usr/local/bin/btrfs-sync -qd "/media/data/ncp-snapshots" "/media/backup/ncp-snapshots"
as root, copied from /etc/cron.d/ncp-snapsync-auto manually.
Terminal-Output: āRemote userās shell not bash. Shells other than bash are not supported at the momentā
I took a look at https://ownyourbits.com/2018/03/09/easy-sync-of-btrfs-snapshots-with-btrfs-sync/
Installed the script:
sudo wget https://raw.githubusercontent.com/nachoparker/btrfs-sync/master/btrfs-sync -O /usr/local/sbin/btrfs-sync
sudo chmod +x /usr/local/sbin/btrfs-sync
and ran the sync script.
root@nextcloudpi:/home/test# /usr/local/sbin/btrfs-sync -qd "/media/data/ncp-snapshots" "/media/backup/ncp-snapshots"
* Synchronizing '/media/data/ncp-snapshots/manual_2022-01-15_134644'...
* Synchronizing '/media/data/ncp-snapshots/daily_2022-01-15_141702'...
* Synchronizing '/media/data/ncp-snapshots/hourly_2022-01-15_141702'...
* Synchronizing '/media/data/ncp-snapshots/monthly_2022-01-15_141702'...
* Synchronizing '/media/data/ncp-snapshots/weekly_2022-01-15_141702'...
* Synchronizing '/media/data/ncp-snapshots/hourly_2022-01-15_151701'...
Iām not sure where to continue solving my issue. I have issues interpreting the āuse bash not shellā error. And why does the script located in the sbin folder works without problem?
Thank you in advance for your help!
