Nextcloud version: 28.0.5
Operating system and version: Debian 11
PHP version: 8.1
NCP version 1.53.2
Hi community,
for a while I face the following problem when running “ncp-update”:
Downloading updates
Performing updates
/usr/local/bin/ncp-update: line 45: ./update.sh: No such file or directory
It seems as the scope in which the script is run doesn’t match the required one. When I open the script /usr/local/bin/ncp-update and run all the commands in a terminal one by one it works but I have to run “update.sh” without “./” in the terminal.
I don’t know what’s messed up here but I would be thankful if I could just run “ncp-update” again without hassling around with the scripts and running each command on its own.
Perhaps someone has a simple solution.
Thanks.
Edit:
my PATH variable is
PATH=/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
perhaps the problem is in here.
Edit2:
in the script “/usr/local/bin/ncp-update” in line 32 there seems to be no cd-ing to directory $TEMPDIR so ./update.sh is truely not found. But how can the below code not do “cd “$TEMPDIR””? I don’t understand what the code snippet is supposed to check…especially the “[[ -f /.ncp-image]]” part.
[[ -f /.ncp-image ]] || {
cd "$TEMPDIR" # update locally during build
[[ -z "$2" ]] || {
git fetch origin "$2" || {
echo "Error: Could not fetch $2"
exit 1
git checkout FETCH_HEAD
