NCP from RPi 4 to RPi 5 - problem with backup / restore
I got my new RPi 5 recently and just wanted to upgrade from my existing and functioning RPi 4 (NC Version 28).
Here’s what I did so far:
  1. started fresh NCP on the RPi 5 (NC 30)
  2. made a backup from NCP (RPi 4) without data
  3. Restored RPi 4-Config into RPi 5
  4. Tried to import NCP Backup
  5. Got this failure:
extracting backup file /media/nextcloud-bkp_20250302_1740938529.tar.gz...
restore files...
Restoring old '/var/www/nextcloud/data' to '/var/www/nextcloud/data'...
restore database...
ERROR at line 1: Unknown command '\-'.
Error restoring nextcloud database
Cleanup...
I thought that maybe the problem would be NC28 vs NC30 - but even after downgrading the RPi5 to 28, it did end up with the same error.
I hesitate to upgrade to the new distribution, as it seems not to be the problemsolver in this case.
Additionally, I tried to restore from a backup on the RPi4 and now my files are not accessible anymore – even after ncp-fix-permissions ran through without failure.
note: I already asked in the Telegram-Chat.
Why not trying to update the working rpi4 instance to newest software revisions (ncp 1.55.3, nc 30, php8.3) than try to do the transition.
Keep in mind new ncp setups are armbian based.
The NCP-Updater wouldn’t let me update to the latest revision (at least not without upgrading the dist to bookworm).
(Cant provide a screenshot right now.)
What about?
sudo ncp-dist-upgrade
Please, consider giving more info about your setup, at least the output of
sudo ncp-report
Sorry, I was away from the machine for a bit.
Here’s the ncp-report:
<–! Paste this in GitHub report →
NextcloudPi diagnostics
NextcloudPi version  v1.55.3
NextcloudPi image    NextCloudPi_09-14-22
OS                   Debian GNU/Linux 11. 6.1.21-v8+ (aarch64)
automount            yes
USB devices          sda
datadir              /media/myCloudDrive/ncdata
data in SD           no
data filesystem      ext2/ext3
data disk usage      1.9T/3.6T
rootfs usage         19G/117G
swapfile             /var/swap
dbdir                /var/lib/mysql
Nextcloud check      ok
Nextcloud version    28.0.14.1
HTTPD service        up
PHP service          up
MariaDB service      up
Redis service        up
HPB service          up
Postfix service      up
Internet check       ok
Public IPv4          ***REMOVED SENSITIVE VALUE***
Public IPv6          ***REMOVED SENSITIVE VALUE***
Port 80              open
Port 443             open
IP                   ***REMOVED SENSITIVE VALUE***
Gateway              ***REMOVED SENSITIVE VALUE***
Interface            eth0
Certificates         ***REMOVED SENSITIVE VALUE***
NAT loopback         no
Uptime               6days
Nextcloud configuration
        "trusted_domains": {
            "0": "localhost",
            "5": "nextcloudpi.local",
            "7": "nextcloudpi",
            "8": "nextcloudpi.lan",
            "11": "2a02:8109:9380:eb00:ae3f:f5d7:901a:fba9",
            "1": "192.168.1.5",
            "12": "spurgo.hopto.org",
            "20": "spurgo.ddns.net",
            "22": "192.168.1.5",
            "3": "nextcloudpi",
            "": "nextcloudpi",
            "21": "spurgo.hopto.org",
            "14": "nextcloudpi"
        "dbtype": "mysql",
        "version": "28.0.14.1",
        "overwrite.cli.url": "https:\/\/nextcloudpi\/",
        "dbport": "",
        "mysql.utf8mb4": true,
        "redis": {
            "port": 0,
            "timeout": 0,
        "tempdirectory": "\/media\/myCloudDrive\/ncdata\/tmp",
        "mail_smtpmode": "smtp",
        "mail_smtpauthtype": "LOGIN",
        "preview_max_x": 2048,
        "preview_max_y": 2048,
        "jpeg_quality": 60,
        "overwriteprotocol": "https",
        "logfile": "\/media\/myCloudDrive\/ncdata\/nextcloud.log",
        "loglevel": 0,
        "log_type": "file",
        "htaccess.RewriteBase": "\/",
        "theme": "",
        "has_rebuilt_cache": true,
        "mail_sendmailmode": "smtp",
        "mail_smtpport": "587",
        "data-fingerprint": "a1e0dbb5f46c98d3eadf72ddbc9f1b2c",
        "mail_smtpauth": 1,
        "twofactor_enforced": "true",
            "admin"
        "twofactor_enforced_excluded_groups": [
            "hirnformation",
            "Bruchst\u00fccke"
        "memories.exiftool": "\/var\/www\/nextcloud\/apps\/memories\/bin-ext\/exiftool-aarch64-glibc",
        "memories.vod.path": "\/var\/www\/nextcloud\/apps\/memories\/bin-ext\/go-vod-aarch64",
        "enabledPreviewProviders": [
            "OC\\Preview\\Image",
            "OC\\Preview\\HEIC",
            "OC\\Preview\\TIFF",
            "OC\\Preview\\Movie",
            "OC\\Preview\\Imaginary"
        "memories.vod.disable": false,
        "memories.vod.ffprobe": "\/usr\/bin\/ffprobe"
HTTPd logs
[Sat Mar 08 00:00:00.909153 2025] [ssl:warn] [pid 797:tid 797] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Sat Mar 08 00:00:00.921652 2025] [mpm_event:notice] [pid 797:tid 797] AH00489: Apache/2.4.62 (Debian) OpenSSL/1.1.1w configured -- resuming normal operations
[Sat Mar 08 00:00:00.921718 2025] [core:notice] [pid 797:tid 797] AH00094: Command line: '/usr/sbin/apache2'
[Sat Mar 08 09:35:45.965119 2025] [core:error] [pid 3592070:tid 3592127] [client 194.68.244.54:40890] AH10244: invalid URI path (/cgi-bin/.%2e/.%2e/.%2e/.%2e/.%2e/.%2e/.%2e/.%2e/.%2e/.%2e/bin/sh)
[Sat Mar 08 09:35:49.153526 2025] [core:error] [pid 3592070:tid 3592146] [client 194.68.244.54:40894] AH10244: invalid URI path (/cgi-bin/%%32%65%%32%65/%%32%65%%32%65/%%32%65%%32%65/%%32%65%%32%65/%%32%65%%32%65/%%32%65%%32%65/%%32%65%%32%65/bin/sh)
Database logs
tail: cannot open '/var/log/mysql/*.log' for reading: No such file or directory
Nextcloud logs
{"reqId":"Z8xF3CiSxb1QB2Hg256ragAAANg","level":1,"time":"2025-03-08T13:27:56+00:00","remoteAddr":"170.64.221.89","user":"--","app":"no app in context","method":"GET","url":"/.git/config","message":"Unable to generate a URL for the named route \"cloud_federation_api.RequestHandler.addShare\" as such route does not exist.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.129 Safari/537.36","version":"28.0.14.1","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"cloud_federation_api.RequestHandler.addShare\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":380,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":65,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":103,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":115,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/apps/cloud_federation_api/lib/Capabilities.php","line":63,"function":"linkToRouteAbsolute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/CapabilitiesManager.php","line":74,"function":"getCapabilities","class":"OCA\\CloudFederationAPI\\Capabilities","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":156,"function":"getCapabilities","class":"OC\\CapabilitiesManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":266,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":142,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":845,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":1200,"function":"init","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":37,"args":["/var/www/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"cloud_federation_api.RequestHandler.addShare\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"cloud_federation_api.RequestHandler.addShare\" as such route does not exist."}}
{"reqId":"Z8xF3CiSxb1QB2Hg256ragAAANg","level":1,"time":"2025-03-08T13:27:56+00:00","remoteAddr":"170.64.221.89","user":"--","app":"no app in context","method":"GET","url":"/.git/config","message":"Unable to generate a URL for the named route \"notify_push.Auth.preAuth\" as such route does not exist.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.129 Safari/537.36","version":"28.0.14.1","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"notify_push.Auth.preAuth\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":380,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":65,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":103,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/apps/notify_push/lib/Capabilities.php","line":36,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/CapabilitiesManager.php","line":74,"function":"getCapabilities","class":"OCA\\NotifyPush\\Capabilities","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":156,"function":"getCapabilities","class":"OC\\CapabilitiesManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":266,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":142,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":845,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":1200,"function":"init","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":37,"args":["/var/www/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"notify_push.Auth.preAuth\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"notify_push.Auth.preAuth\" as such route does not exist."}}
{"reqId":"Z8xF3CiSxb1QB2Hg256ragAAANg","level":1,"time":"2025-03-08T13:27:56+00:00","remoteAddr":"170.64.221.89","user":"--","app":"no app in context","method":"GET","url":"/.git/config","message":"Unable to generate a URL for the named route \"richdocuments.document.editOnline\" as such route does not exist.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.129 Safari/537.36","version":"28.0.14.1","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"richdocuments.document.editOnline\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":380,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":65,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":103,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":115,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/apps/richdocuments/lib/Capabilities.php","line":155,"function":"linkToRouteAbsolute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/CapabilitiesManager.php","line":74,"function":"getCapabilities","class":"OCA\\Richdocuments\\Capabilities","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":156,"function":"getCapabilities","class":"OC\\CapabilitiesManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":266,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":142,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":845,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":1200,"function":"init","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":37,"args":["/var/www/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"richdocuments.document.editOnline\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"richdocuments.document.editOnline\" as such route does not exist."}}
{"reqId":"Z8xF3CiSxb1QB2Hg256ragAAANg","level":1,"time":"2025-03-08T13:27:56+00:00","remoteAddr":"170.64.221.89","user":"--","app":"no app in context","method":"GET","url":"/.git/config","message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.129 Safari/537.36","version":"28.0.14.1","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":380,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":65,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":103,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/ImageManager.php","line":71,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/ThemingDefaults.php","line":314,"function":"getImageUrl","class":"OCA\\Theming\\ImageManager","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/Capabilities.php","line":105,"function":"getBackground","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/CapabilitiesManager.php","line":74,"function":"getCapabilities","class":"OCA\\Theming\\Capabilities","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":156,"function":"getCapabilities","class":"OC\\CapabilitiesManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":266,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":142,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":845,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":1200,"function":"init","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":37,"args":["/var/www/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist."}}
{"reqId":"Z8xF3CiSxb1QB2Hg256ragAAANg","level":1,"time":"2025-03-08T13:27:56+00:00","remoteAddr":"170.64.221.89","user":"--","app":"no app in context","method":"GET","url":"/.git/config","message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.129 Safari/537.36","version":"28.0.14.1","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":380,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":65,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":103,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/ThemingDefaults.php","line":305,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/Capabilities.php","line":143,"function":"getLogo","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/CapabilitiesManager.php","line":74,"function":"getCapabilities","class":"OCA\\Theming\\Capabilities","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":156,"function":"getCapabilities","class":"OC\\CapabilitiesManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":266,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":142,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":845,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":1200,"function":"init","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":37,"args":["/var/www/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist."}}
{"reqId":"Z8xF3CiSxb1QB2Hg256ragAAANg","level":1,"time":"2025-03-08T13:27:56+00:00","remoteAddr":"170.64.221.89","user":"--","app":"no app in context","method":"GET","url":"/.git/config","message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.129 Safari/537.36","version":"28.0.14.1","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":380,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":65,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":103,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/ThemingDefaults.php","line":305,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/Capabilities.php","line":147,"function":"getLogo","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/CapabilitiesManager.php","line":74,"function":"getCapabilities","class":"OCA\\Theming\\Capabilities","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":156,"function":"getCapabilities","class":"OC\\CapabilitiesManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":266,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":142,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":845,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":1200,"function":"init","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":37,"args":["/var/www/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist."}}
{"reqId":"Z8xF3CiSxb1QB2Hg256ragAAANg","level":1,"time":"2025-03-08T13:27:56+00:00","remoteAddr":"170.64.221.89","user":"--","app":"no app in context","method":"GET","url":"/.git/config","message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.129 Safari/537.36","version":"28.0.14.1","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":380,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":65,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":103,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/ThemingDefaults.php","line":305,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/Capabilities.php","line":148,"function":"getLogo","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/CapabilitiesManager.php","line":74,"function":"getCapabilities","class":"OCA\\Theming\\Capabilities","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":156,"function":"getCapabilities","class":"OC\\CapabilitiesManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":266,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":142,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":845,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":1200,"function":"init","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":37,"args":["/var/www/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist."}}
{"reqId":"Z8xF3SiSxb1QB2Hg256rawAAANE","level":1,"time":"2025-03-08T13:27:57+00:00","remoteAddr":"170.64.221.89","user":"--","app":"core","method":"GET","url":"/.git/config","message":"Trusted domain error. \"170.64.221.89\" tried to access using \"91.64.111.64\" as host.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.129 Safari/537.36","version":"28.0.14.1","data":{"app":"core"}}
{"reqId":"Z8xF3SiSxb1QB2Hg256rawAAANE","level":1,"time":"2025-03-08T13:27:57+00:00","remoteAddr":"170.64.221.89","user":"--","app":"no app in context","method":"GET","url":"/.git/config","message":"Unable to generate a URL for the named route \"cloud_federation_api.RequestHandler.addShare\" as such route does not exist.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.129 Safari/537.36","version":"28.0.14.1","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"cloud_federation_api.RequestHandler.addShare\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":380,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":65,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":103,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":115,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/apps/cloud_federation_api/lib/Capabilities.php","line":63,"function":"linkToRouteAbsolute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/CapabilitiesManager.php","line":74,"function":"getCapabilities","class":"OCA\\CloudFederationAPI\\Capabilities","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":156,"function":"getCapabilities","class":"OC\\CapabilitiesManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":266,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":142,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":845,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":1200,"function":"init","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":37,"args":["/var/www/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"cloud_federation_api.RequestHandler.addShare\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"cloud_federation_api.RequestHandler.addShare\" as such route does not exist."}}
{"reqId":"Z8xF3SiSxb1QB2Hg256rawAAANE","level":1,"time":"2025-03-08T13:27:57+00:00","remoteAddr":"170.64.221.89","user":"--","app":"no app in context","method":"GET","url":"/.git/config","message":"Unable to generate a URL for the named route \"notify_push.Auth.preAuth\" as such route does not exist.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.129 Safari/537.36","version":"28.0.14.1","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"notify_push.Auth.preAuth\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":380,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":65,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":103,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/apps/notify_push/lib/Capabilities.php","line":36,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/CapabilitiesManager.php","line":74,"function":"getCapabilities","class":"OCA\\NotifyPush\\Capabilities","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":156,"function":"getCapabilities","class":"OC\\CapabilitiesManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":266,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":142,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":845,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":1200,"function":"init","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":37,"args":["/var/www/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"notify_push.Auth.preAuth\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"notify_push.Auth.preAuth\" as such route does not exist."}}
{"reqId":"Z8xF3SiSxb1QB2Hg256rawAAANE","level":1,"time":"2025-03-08T13:27:57+00:00","remoteAddr":"170.64.221.89","user":"--","app":"no app in context","method":"GET","url":"/.git/config","message":"Unable to generate a URL for the named route \"richdocuments.document.editOnline\" as such route does not exist.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.129 Safari/537.36","version":"28.0.14.1","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"richdocuments.document.editOnline\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":380,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":65,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":103,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":115,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/apps/richdocuments/lib/Capabilities.php","line":155,"function":"linkToRouteAbsolute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/CapabilitiesManager.php","line":74,"function":"getCapabilities","class":"OCA\\Richdocuments\\Capabilities","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":156,"function":"getCapabilities","class":"OC\\CapabilitiesManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":266,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":142,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":845,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":1200,"function":"init","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":37,"args":["/var/www/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"richdocuments.document.editOnline\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"richdocuments.document.editOnline\" as such route does not exist."}}
{"reqId":"Z8xF3SiSxb1QB2Hg256rawAAANE","level":1,"time":"2025-03-08T13:27:57+00:00","remoteAddr":"170.64.221.89","user":"--","app":"no app in context","method":"GET","url":"/.git/config","message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.129 Safari/537.36","version":"28.0.14.1","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":380,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":65,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":103,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/ImageManager.php","line":71,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/ThemingDefaults.php","line":314,"function":"getImageUrl","class":"OCA\\Theming\\ImageManager","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/Capabilities.php","line":105,"function":"getBackground","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/CapabilitiesManager.php","line":74,"function":"getCapabilities","class":"OCA\\Theming\\Capabilities","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":156,"function":"getCapabilities","class":"OC\\CapabilitiesManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":266,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":142,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":845,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":1200,"function":"init","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":37,"args":["/var/www/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist."}}
{"reqId":"Z8xF3SiSxb1QB2Hg256rawAAANE","level":1,"time":"2025-03-08T13:27:57+00:00","remoteAddr":"170.64.221.89","user":"--","app":"no app in context","method":"GET","url":"/.git/config","message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.129 Safari/537.36","version":"28.0.14.1","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":380,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":65,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":103,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/ThemingDefaults.php","line":305,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/Capabilities.php","line":143,"function":"getLogo","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/CapabilitiesManager.php","line":74,"function":"getCapabilities","class":"OCA\\Theming\\Capabilities","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":156,"function":"getCapabilities","class":"OC\\CapabilitiesManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":266,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":142,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":845,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":1200,"function":"init","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":37,"args":["/var/www/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist."}}
{"reqId":"Z8xF3SiSxb1QB2Hg256rawAAANE","level":1,"time":"2025-03-08T13:27:57+00:00","remoteAddr":"170.64.221.89","user":"--","app":"no app in context","method":"GET","url":"/.git/config","message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.129 Safari/537.36","version":"28.0.14.1","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":380,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":65,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":103,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/ThemingDefaults.php","line":305,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/Capabilities.php","line":147,"function":"getLogo","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/CapabilitiesManager.php","line":74,"function":"getCapabilities","class":"OCA\\Theming\\Capabilities","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":156,"function":"getCapabilities","class":"OC\\CapabilitiesManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":266,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":142,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":845,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":1200,"function":"init","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":37,"args":["/var/www/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist."}}
{"reqId":"Z8xF3SiSxb1QB2Hg256rawAAANE","level":1,"time":"2025-03-08T13:27:57+00:00","remoteAddr":"170.64.221.89","user":"--","app":"no app in context","method":"GET","url":"/.git/config","message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.129 Safari/537.36","version":"28.0.14.1","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":380,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":65,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":103,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/ThemingDefaults.php","line":305,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/Capabilities.php","line":148,"function":"getLogo","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/CapabilitiesManager.php","line":74,"function":"getCapabilities","class":"OCA\\Theming\\Capabilities","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":156,"function":"getCapabilities","class":"OC\\CapabilitiesManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":266,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":142,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":845,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":1200,"function":"init","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":37,"args":["/var/www/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"theming.Theming.getImage\" as such route does not exist."}}
{"reqId":"Z8xF4iiSxb1QB2Hg256rbAAAAMA","level":0,"time":"2025-03-08T13:28:04+00:00","remoteAddr":"91.64.111.64","user":"spurgo","app":"dav","method":"GET","url":"/ocs/v2.php/apps/user_status/api/v1/user_status?format=json","message":"Higher priority status detected, skipping calendar status change","userAgent":"Mozilla/5.0 (Windows) mirall/3.15.3 (build 20250107) (Nextcloud, windows-10.0.26100 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"28.0.14.1","data":{"app":"dav","user":"spurgo"}}
{"reqId":"I47I2XbRBPnNkkUXWiu3","level":1,"time":"2025-03-08T13:28:08+00:00","remoteAddr":"","user":"--","app":"related_resources","method":"","url":"--","message":"Could not resolve OCA\\Circles\\CirclesManager! Class \"OCA\\Circles\\CirclesManager\" does not exist","userAgent":"--","version":"28.0.14.1","data":{"app":"related_resources"}}
{"reqId":"1KODnzuVXZuAyL9Qtyn4","level":1,"time":"2025-03-08T13:28:10+00:00","remoteAddr":"","user":"--","app":"related_resources","method":"","url":"--","message":"Could not resolve OCA\\Circles\\CirclesManager! Class \"OCA\\Circles\\CirclesManager\" does not exist","userAgent":"--","version":"28.0.14.1","data":{"app":"related_resources"}}
{"reqId":"wujcyhyipqGCA8sNgAI1","level":1,"time":"2025-03-08T13:28:11+00:00","remoteAddr":"","user":"--","app":"related_resources","method":"","url":"--","message":"Could not resolve OCA\\Circles\\CirclesManager! Class \"OCA\\Circles\\CirclesManager\" does not exist","userAgent":"--","version":"28.0.14.1","data":{"app":"related_resources"}}
{"reqId":"X6fRU3hLW8Nb4ZXstmKR","level":1,"time":"2025-03-08T13:28:19+00:00","remoteAddr":"","user":"--","app":"related_resources","method":"","url":"--","message":"Could not resolve OCA\\Circles\\CirclesManager! Class \"OCA\\Circles\\CirclesManager\" does not exist","userAgent":"--","version":"28.0.14.1","data":{"app":"related_resources"}}
I wanted to avoid that until I know the backup-system works correctly.
I now extracted the database-File from the backup and there is this in the first line of the backup:
/*M!999999\- enable the sandbox mode */
I don’t get why this is even in the sql-file if it corrupts the backup?
Don’t worry, that’s ok.
Would also be nice to know:
php -v
So your setup seems ā€˜out of sync’. from nc server perspective (28.0:x, eol) your ncp should be around 1.53.x, php8.2.
I never messed about with db-file other than ncc commands.
An older backup around March 2024 could be a starting point to upgrade components (nc, ncp) synchronous.
So after getting rid of the faulty line in the database-backup (extracting, editing and importing the nextcloud-sqlbkp_XXXX-file) I was able to restore the backup on the RPi 5.
That worked so far. After that had to update my way back from NC28 (source-NC-Version) to NC29/30.
But sadly my files are not readable from the nextcloud-webgui. When I try to open any file, this or similar happens:
When I try to download, a 503-Error appears.
I ran nc-fix-permissions like a hundred times, but nothing changed. All files seem to be inaccessable (or offline).
This is the ncp-report:
NextcloudPi image
OS                   Armbian-unofficial 24.8.2 Bookworm \l . 6.6.45-current-bcm2712 (aarch64)
automount            yes
USB devices          sda sdb
data in SD           no
rootfs usage         20G/118G
swapfile             /media/BackupPi/swap
Nextcloud check      ok
Nextcloud version    29.0.12.2
HTTPD service        up
PHP service          up
MariaDB service      up
Redis service        up
HPB service          up
Postfix service      up
Internet check       ok
Port 80              closed
Port 443             closed
Interface            end0
NAT loopback         no
Uptime               36min
            "0": "localhost",
            "7": "nextcloudpi",
            "11": "2a02:8109:9380:eb00:1bd5:c625:c4bc:5f69",
            "1": "192.168.1.105",
            "3": "nextcloudpi",
            "": "nextcloudpi",
            "14": "nextcloudpi"
        "dbtype": "mysql",
        "version": "29.0.12.2",
        "dbport": "",
        "redis": {
            "port": 0,
            "timeout": 0,
        "jpeg_quality": 60,
        "loglevel": 0,
        "log_type": "file",
        "theme": "",
        "data-fingerprint": "23be0a22e30e10acfc7196faf02ff519",
        "mail_smtpauth": 1,
            "admin"
            "hirnformation",
            "Bruchst\u00fccke"
HTTPd logs
[Sun Mar 09 10:21:58.044197 2025] [authz_host:error] [pid 1322:tid 1357] [remote 192.168.1.55:50754] AH01753: access check of 'localhost' to /img/files.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.105:4443/css/ncp.css
[Sun Mar 09 10:21:58.053756 2025] [authz_host:error] [pid 1322:tid 1364] [remote 192.168.1.55:50754] AH01753: access check of 'localhost' to /img/nc-button.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.105:4443/css/ncp.css
[Sun Mar 09 10:21:58.058488 2025] [authz_host:error] [pid 1322:tid 1340] [remote 192.168.1.55:50754] AH01753: access check of 'localhost' to /img/defaults-white.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.105:4443/css/ncp.css
[Sun Mar 09 10:21:58.058743 2025] [authz_host:error] [pid 1322:tid 1349] [remote 192.168.1.55:50754] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Sun Mar 09 10:22:15.568594 2025] [authz_host:error] [pid 1322:tid 1362] [remote 192.168.1.55:50754] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Sun Mar 09 10:22:15.701693 2025] [authz_host:error] [pid 1322:tid 1362] [remote 192.168.1.55:50754] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Sun Mar 09 10:22:19.568560 2025] [authz_host:error] [pid 1322:tid 1347] [remote 192.168.1.55:50754] AH01753: access check of 'localhost' to /img/download.svg failed, reason: unable to get the remote host name
[Sun Mar 09 10:22:19.568560 2025] [authz_host:error] [pid 1322:tid 1353] [remote 192.168.1.55:50754] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Sun Mar 09 10:22:19.571743 2025] [authz_host:error] [pid 1322:tid 1345] [remote 192.168.1.55:50754] AH01753: access check of 'localhost' to /img/delete.svg failed, reason: unable to get the remote host name
[Sun Mar 09 10:22:19.696381 2025] [authz_host:error] [pid 1322:tid 1353] [remote 192.168.1.55:50754] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Sun Mar 09 10:22:19.698258 2025] [authz_host:error] [pid 1322:tid 1345] [remote 192.168.1.55:50754] AH01753: access check of 'localhost' to /img/delete.svg failed, reason: unable to get the remote host name
[Sun Mar 09 10:22:19.702815 2025] [authz_host:error] [pid 1322:tid 1347] [remote 192.168.1.55:50754] AH01753: access check of 'localhost' to /img/download.svg failed, reason: unable to get the remote host name
[Sun Mar 09 10:23:51.568518 2025] [authz_host:error] [pid 1322:tid 1344] [remote 192.168.1.55:50754] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Sun Mar 09 10:23:51.572584 2025] [authz_host:error] [pid 1322:tid 1370] [remote 192.168.1.55:50754] AH01753: access check of 'localhost' to /img/info.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.105:4443/css/ncp.css
[Sun Mar 09 10:23:51.709201 2025] [authz_host:error] [pid 1322:tid 1344] [remote 192.168.1.55:50754] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Sun Mar 09 10:23:51.712653 2025] [authz_host:error] [pid 1322:tid 1370] [remote 192.168.1.55:50754] AH01753: access check of 'localhost' to /img/info.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.105:4443/css/ncp.css
[Sun Mar 09 10:23:56.318589 2025] [authz_host:error] [pid 1322:tid 1339] [remote 192.168.1.55:50754] AH01753: access check of 'localhost' to /img/green-circle.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.105:4443/css/ncp.css
[Sun Mar 09 10:23:56.318608 2025] [authz_host:error] [pid 1322:tid 1340] [remote 192.168.1.55:50754] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Sun Mar 09 10:23:56.458062 2025] [authz_host:error] [pid 1322:tid 1339] [remote 192.168.1.55:50754] AH01753: access check of 'localhost' to /img/green-circle.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.105:4443/css/ncp.css
[Sun Mar 09 10:23:56.460269 2025] [authz_host:error] [pid 1322:tid 1340] [remote 192.168.1.55:50754] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
Database logs
Nextcloud logs
{"reqId":"pI9Lsvs1OISszEbhBSQs","level":0,"time":"2025-03-09T10:25:01+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"CLI cron call has selected job OCA\\TwoFactorBackupCodes\\BackgroundJob\\CheckBackupCodes (id: 31573, arguments: null)","userAgent":"--","version":"29.0.12.2","data":{"app":"cron"}}
{"reqId":"pI9Lsvs1OISszEbhBSQs","level":0,"time":"2025-03-09T10:25:01+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Starting job OCA\\TwoFactorBackupCodes\\BackgroundJob\\CheckBackupCodes (id: 31573, arguments: null)","userAgent":"--","version":"29.0.12.2","data":{"app":"cron"}}
{"reqId":"pI9Lsvs1OISszEbhBSQs","level":0,"time":"2025-03-09T10:25:01+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"dirty table reads: SELECT `id` FROM `*PREFIX*jobs` WHERE (`class` = :dcValue1) AND (`argument_hash` = :dcValue2) LIMIT 1","userAgent":"--","version":"29.0.12.2","exception":{"Exception":"Exception","Message":"dirty table reads: SELECT `id` FROM `*PREFIX*jobs` WHERE (`class` = :dcValue1) AND (`argument_hash` = :dcValue2) LIMIT 1","Code":0,"Trace":[{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":344,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":384,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":293,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/BackgroundJob/JobList.php","line":150,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/BackgroundJob/JobList.php","line":70,"function":"has","class":"OC\\BackgroundJob\\JobList","type":"->"},{"file":"/var/www/nextcloud/apps/twofactor_backupcodes/lib/BackgroundJob/CheckBackupCodes.php","line":69,"function":"add","class":"OC\\BackgroundJob\\JobList","type":"->"},{"file":"/var/www/nextcloud/lib/private/User/Manager.php","line":672,"function":"OCA\\TwoFactorBackupCodes\\BackgroundJob\\{closure}","class":"OCA\\TwoFactorBackupCodes\\BackgroundJob\\CheckBackupCodes","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/apps/twofactor_backupcodes/lib/BackgroundJob/CheckBackupCodes.php","line":60,"function":"callForSeenUsers","class":"OC\\User\\Manager","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/Job.php","line":80,"function":"run","class":"OCA\\TwoFactorBackupCodes\\BackgroundJob\\CheckBackupCodes","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/QueuedJob.php","line":61,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->"},{"file":"/var/www/nextcloud/lib/public/BackgroundJob/QueuedJob.php","line":47,"function":"start","class":"OCP\\BackgroundJob\\QueuedJob","type":"->"},{"file":"/var/www/nextcloud/cron.php","line":177,"function":"execute","class":"OCP\\BackgroundJob\\QueuedJob","type":"->"}],"File":"/var/www/nextcloud/lib/private/DB/Connection.php","Line":320,"message":"dirty table reads: SELECT `id` FROM `*PREFIX*jobs` WHERE (`class` = :dcValue1) AND (`argument_hash` = :dcValue2) LIMIT 1","tables":["oc_appconfig","oc_jobs","oc_user_status","oc_notifications_settings","oc_deck_sessions","oc_filecache","oc_filecache_extended","oc_files_metadata","oc_files_metadata_index","oc_login_flow_v2"],"reads":["oc_jobs"],"exception":{},"CustomMessage":"dirty table reads: SELECT `id` FROM `*PREFIX*jobs` WHERE (`class` = :dcValue1) AND (`argument_hash` = :dcValue2) LIMIT 1"}}
{"reqId":"pI9Lsvs1OISszEbhBSQs","level":0,"time":"2025-03-09T10:25:01+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Finished job OCA\\TwoFactorBackupCodes\\BackgroundJob\\CheckBackupCodes (id: 31573, arguments: null) in 0 seconds","userAgent":"--","version":"29.0.12.2","data":{"app":"cron"}}
{"reqId":"pI9Lsvs1OISszEbhBSQs","level":0,"time":"2025-03-09T10:25:01+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1","userAgent":"--","version":"29.0.12.2","exception":{"Exception":"Exception","Message":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1","Code":0,"Trace":[{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":344,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":384,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":293,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/BackgroundJob/JobList.php","line":208,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/cron.php","line":163,"function":"getNext","class":"OC\\BackgroundJob\\JobList","type":"->"}],"File":"/var/www/nextcloud/lib/private/DB/Connection.php","Line":320,"message":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1","tables":["oc_appconfig","oc_jobs","oc_user_status","oc_notifications_settings","oc_deck_sessions","oc_filecache","oc_filecache_extended","oc_files_metadata","oc_files_metadata_index","oc_login_flow_v2"],"reads":["oc_jobs"],"exception":{},"CustomMessage":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1"}}
{"reqId":"Z81spBcwC7bY89KTrTM2eQAADQc","level":0,"time":"2025-03-09T10:25:41+00:00","remoteAddr":"192.168.1.55","user":"spurgo","app":"PHP","method":"POST","url":"/apps/notify_push/pre_auth","message":"json_decode(): Passing null to parameter #1 ($json) of type string is deprecated at /var/www/nextcloud/apps/richdocuments/lib/Service/CapabilitiesService.php#148","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:136.0) Gecko/20100101 Firefox/136.0","version":"29.0.12.2","data":{"app":"PHP"}}
{"reqId":"6GlHZMSLhm1r6G75EJT8","level":0,"time":"2025-03-09T10:25:42+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/Generate.php#252","userAgent":"--","version":"29.0.12.2","data":{"app":"PHP"}}
{"reqId":"6GlHZMSLhm1r6G75EJT8","level":0,"time":"2025-03-09T10:25:42+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/PreGenerate.php#214","userAgent":"--","version":"29.0.12.2","data":{"app":"PHP"}}
{"reqId":"6GlHZMSLhm1r6G75EJT8","level":1,"time":"2025-03-09T10:25:42+00:00","remoteAddr":"","user":"--","app":"related_resources","method":"","url":"--","message":"Could not resolve OCA\\Circles\\CirclesManager! Class \"OCA\\Circles\\CirclesManager\" does not exist","userAgent":"--","version":"29.0.12.2","data":{"app":"related_resources"}}
{"reqId":"2AdcTEbCswRRVwdxwM6x","level":0,"time":"2025-03-09T10:25:42+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/Generate.php#252","userAgent":"--","version":"29.0.12.2","data":{"app":"PHP"}}
{"reqId":"2AdcTEbCswRRVwdxwM6x","level":0,"time":"2025-03-09T10:25:42+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/PreGenerate.php#214","userAgent":"--","version":"29.0.12.2","data":{"app":"PHP"}}
{"reqId":"2AdcTEbCswRRVwdxwM6x","level":1,"time":"2025-03-09T10:25:42+00:00","remoteAddr":"","user":"--","app":"related_resources","method":"","url":"--","message":"Could not resolve OCA\\Circles\\CirclesManager! Class \"OCA\\Circles\\CirclesManager\" does not exist","userAgent":"--","version":"29.0.12.2","data":{"app":"related_resources"}}
{"reqId":"vb86HbxYBj9Rl4c9HUZ4","level":0,"time":"2025-03-09T10:25:43+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/Generate.php#252","userAgent":"--","version":"29.0.12.2","data":{"app":"PHP"}}
{"reqId":"vb86HbxYBj9Rl4c9HUZ4","level":0,"time":"2025-03-09T10:25:43+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/PreGenerate.php#214","userAgent":"--","version":"29.0.12.2","data":{"app":"PHP"}}
{"reqId":"vb86HbxYBj9Rl4c9HUZ4","level":1,"time":"2025-03-09T10:25:43+00:00","remoteAddr":"","user":"--","app":"related_resources","method":"","url":"--","message":"Could not resolve OCA\\Circles\\CirclesManager! Class \"OCA\\Circles\\CirclesManager\" does not exist","userAgent":"--","version":"29.0.12.2","data":{"app":"related_resources"}}
{"reqId":"Z81sqRcwC7bY89KTrTM2gQAAFww","level":0,"time":"2025-03-09T10:25:45+00:00","remoteAddr":"192.168.1.55","user":"spurgo","app":"PHP","method":"GET","url":"/apps/files/api/v1/stats","message":"json_decode(): Passing null to parameter #1 ($json) of type string is deprecated at /var/www/nextcloud/apps/richdocuments/lib/Service/CapabilitiesService.php#148","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:136.0) Gecko/20100101 Firefox/136.0","version":"29.0.12.2","data":{"app":"PHP"}}
{"reqId":"CH5I7Ai0YNsFsUoqepzR","level":0,"time":"2025-03-09T10:25:55+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/Generate.php#252","userAgent":"--","version":"29.0.12.2","data":{"app":"PHP"}}
{"reqId":"CH5I7Ai0YNsFsUoqepzR","level":0,"time":"2025-03-09T10:25:55+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/PreGenerate.php#214","userAgent":"--","version":"29.0.12.2","data":{"app":"PHP"}}
{"reqId":"CH5I7Ai0YNsFsUoqepzR","level":1,"time":"2025-03-09T10:25:55+00:00","remoteAddr":"","user":"--","app":"related_resources","method":"","url":"--","message":"Could not resolve OCA\\Circles\\CirclesManager! Class \"OCA\\Circles\\CirclesManager\" does not exist","userAgent":"--","version":"29.0.12.2","data":{"app":"related_resources"}}
php -v
PHP 8.3.12 (cli) (built: Sep 27 2024 04:03:53) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.3.12, Copyright (c) Zend Technologies with Zend OPcache v8.3.12, Copyright (c), by Zend Technologies
Something with your nameresolution?
192.168.1.105 / 192.168.1.5
Can you please elaborate? Did you delete the complete line in the file?
I’m interested because I have the same error…
omg. I am such an idiot :smiley: Thanks. Yeah.
Had my DHCP-Server provide the numbers and didn’t recalibrate…
I have edited it so, that only the right things are in the comment-Section (/* */):
/*M!99999 */
-- MariaDB dump 10.19 Distrib [...]
Finally this also worked for me. Thank you!
