Sorry to hear you’re facing problems ![]()
example
longer
example
here
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can ![]()
Nextcloud version (eg, 20.0.5): v1.54.0
Operating system and version (eg, Ubuntu 20.04): Armbian-unofficial 24.2.1 Bookworm \l . 6.6.18-current-bcm2711 (aarch64)
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.59 (Debian)
PHP version (eg, 7.4): PHP 8.1.28
I am trying to add twingate for external access. At first it works fine, but later I run into a internal problem when I access it:
Internal Server Error
The server encountered an internal error and was unable to complete your request. Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report. More details can be found in the server log.
However, I can ssh it using twingate network. And I cannot ssh into it without the twingate(even though I am on the local network).
The database is located at my usb drive and it working fine before I log into the twingate network.
Is this the first time you’ve seen this error? (Y/N):Y
Here is print out of ncp-report:
<–! Paste this in GitHub report →
NextcloudPi diagnostics
grep: /etc/apache2/sites-available/nextcloud.conf: No such file or directory
NextcloudPi version v1.54.0
NextcloudPi image
OS Armbian-unofficial 24.2.1 Bookworm \l . 6.6.18-current-bcm2711 (aarch64)
automount yes
USB devices sda
datadir /opt/ncdata/data
data in SD yes
data filesystem ext2/ext3
data disk usage 5.0G/28G
rootfs usage 5.0G/28G
swapfile /var/swap
dbdir /media/secondDrive
Nextcloud check error
HTTPD service up
PHP service up
MariaDB service down
Redis service up
HPB service down
Postfix service up
Internet check ok
Public IPv4 ***REMOVED SENSITIVE VALUE***
Public IPv6 ***REMOVED SENSITIVE VALUE***
Port 80 closed
Port 443 closed
IP ***REMOVED SENSITIVE VALUE***
Gateway ***REMOVED SENSITIVE VALUE***
Interface end0
Certificates ***REMOVED SENSITIVE VALUE***
NAT loopback no
Uptime 2days
Nextcloud configuration
Doctrine\DBAL\Exception: Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/nextcloud/lib/private/DB/Connection.php:139
Stack trace:
#0 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1654): OC\DB\Connection->connect()
#1 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1081): Doctrine\DBAL\Connection->getWrappedConnection()
#2 /var/www/nextcloud/lib/private/DB/Connection.php(261): Doctrine\DBAL\Connection->executeQuery()
#3 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php(341): OC\DB\Connection->executeQuery()
#4 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php(377): Doctrine\DBAL\Query\QueryBuilder->executeQuery()
#5 /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(280): Doctrine\DBAL\Query\QueryBuilder->execute()
#6 /var/www/nextcloud/lib/private/AppConfig.php(421): OC\DB\QueryBuilder\QueryBuilder->execute()
#7 /var/www/nextcloud/lib/private/AppConfig.php(187): OC\AppConfig->loadConfigValues()
#8 /var/www/nextcloud/lib/private/AppConfig.php(377): OC\AppConfig->getApps()
#9 /var/www/nextcloud/lib/private/App/AppManager.php(128): OC\AppConfig->getValues()
#10 /var/www/nextcloud/lib/private/App/AppManager.php(149): OC\App\AppManager->getInstalledAppsValues()
#11 /var/www/nextcloud/lib/private/legacy/OC_App.php(231): OC\App\AppManager->getInstalledApps()
#12 /var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php(90): OC_App::getEnabledApps()
#13 /var/www/nextcloud/lib/base.php(700): OC\AppFramework\Bootstrap\Coordinator->runInitialRegistration()
#14 /var/www/nextcloud/lib/base.php(1200): OC::init()
#15 /var/www/nextcloud/console.php(48): require_once('...')
#16 /var/www/nextcloud/occ(11): require_once('...')
#17 {main}
HTTPd logs
Database logs
tail: cannot open '/var/log/mysql/*.log' for reading: No such file or directory
Nextcloud logs
