Hi, to be able to use more than one webserver on my raspberry pi 4 using nextcloudpi script i want to change the access to my nextcloud server to https://192.168.0.15/nextcloud (as normally used when settings up nextcloud manually) from https://192.168.0.15 used by default with nextcloudpi script
And also to be able to use it outside from lan, it should use my no-ip domain name with â/nextcloudâ at the end
Iâd try redirect in .htaccess or use RedirectMatch in apache2âs nextcloud.conf
I thought âoverwrite.cli.urlâ would do the trick? Iâd try with just â/nextcloudâ,
Iâve never had the need to do this, so not sure, maybe someone more knowledgeable will stop by and provide an official way to achieve this.
