i have already reported the issue in the GitHub repo of the NC Downloader app, but I think it will take time. anyone can help me to fix the issue?
today I upgrade NC from 26.0.4 to 27.0.1 and NCDownloader stop working.
I am using PHP 8.2 but it was fine with 26.0.4
i try with php 7.4, 8.0, 8.1 but no luck.
https://apps.nextcloud.com/apps/ncdownloader
Thanks
bb77
August 9, 2023, 12:54pm
2
how can i downgrade back to NC 26.0.4 in which NCDownloader works fine, once the developer update the NCDownloader i will upgrade NC to the latest versin.
bb77
August 10, 2023, 4:43am
4
You can’t, unless you made a full backup before the upgrade, which has to include the database. Downgarding an existing installation is not supported.
jtr
August 10, 2023, 5:58pm
5
For now, I’d disable the problematic app from the command via occ
. That should at least make it possible to use Nextcloud otherwise.
occ app:disable ncdownloader
Nextcloud is working fine but you cant access the app, when you click on NCDownloader then you get 500 error.
