.ncdata not found, it does exist
    • 32.0.1
    • Linux 6.12.47+rpt-rpi-v8 aarch64
    • apache2? tutorial said nginx - dont know how?
    • nginx? dont really know
    • 8.3.27
    • yes
    • after install
    • bare metal -> docker
    • no
[…] Cron Errors: Invalid data directory, ensure there is a file called .ncdata in the root of the data directory.
The file does exist, with the right filecontent and i did chown www-data:www-data on it, and also chmod 755.
docker exec -u www-data nextcloud-app-1 cat /var/www/html/data/.ncdata
Nextcloud data directory
→ www-data has access to .ncdata and the file exists
  1. https://www.youtube.com/watch?v=jT7CUK5UNrw install using this tutorial
  2. have data on external ssd
  3. ???
  4. No Profit?
ExceptionHMAC does not match.
QueryNotFoundExceptionCould not resolve OCA\AppAPI\BackgroundJob\ExAppInitStatusCheckJob! Class “OCA\AppAPI\BackgroundJob\ExAppInitStatusCheckJob” does not exist
https://pastebin.com/HMt8mcTs
PASTE
cant find it
PASTE HERE
command not found, neither in container nor host
also, how do i configure a maintenance window? i tried to do it in config.php and it broke everything
your troubleshooting step is very close to the right one but as your problem is related to cron you need
docker exec -u www-data nextcloud-cron-1 cat /var/www/html/data/.ncdata
or much easier with compose
docker compose exec -u www-data cron cat /var/www/html/data/.ncdata
please share the relevant configs - we don’t want to follow 10 different tutorial per day..
refers to
https://raw.githubusercontent.com/pimylifeup/compose/main/nextcloud/signed/compose.yaml
which in turn configures
  app:
    image: nextcloud:apache
    volumes:
      - ${STORAGE_LOCATION}:/var/www/html/data
      - nextcloud:/var/www/html
  cron:
    volumes:
      - nextcloud:/var/www/html:z
as you can see cron container doesn’t mount data directory, which is required (cron must have same mounts as app).
you can find advanced working compose at How to docker-compose with notify_push (2024)
