Nextcloud 24,0,3
ubuntu 22,04
Apache 2,4,54
nginx 1,23,1
PHP 8,0
hi
(that’s one amongst many in admin/settings/log - this one about Query)
[no app in context] Error: OCP\AppFramework\QueryException: Could not resolve externalMountProvider! Class "externalMountProvider" does not exist at <<closure>>
0. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/AppFramework/Utility/SimpleContainer.php line 133
OC\AppFramework\Utility\SimpleContainer->resolve()
1. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/ServerContainer.php line 161
OC\AppFramework\Utility\SimpleContainer->query()
2. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/AppFramework/DependencyInjection/DIContainer.php line 440
OC\ServerContainer->query()
3. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/AppFramework/Utility/SimpleContainer.php line 57
OC\AppFramework\DependencyInjection\DIContainer->query()
4. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/AppFramework/Bootstrap/FunctionInjector.php line 57
OC\AppFramework\Utility\SimpleContainer->get()
5. <<closure>>
OC\AppFramework\Bootstrap\FunctionInjector->OC\AppFramework\Bootstrap\{closure}("*** sensitive parameters replaced ***")
6. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/AppFramework/Bootstrap/FunctionInjector.php line 67
array_map()
7. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/AppFramework/Bootstrap/BootContext.php line 51
OC\AppFramework\Bootstrap\FunctionInjector->injectFn()
8. /home/eve/web/le.rez0.net/public_html/acces0nuage/apps/files_sharing/lib/AppInfo/Application.php line 113
OC\AppFramework\Bootstrap\BootContext->injectFn()
9. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/AppFramework/Bootstrap/Coordinator.php line 190
OCA\Files_Sharing\AppInfo\Application->boot()
10. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/legacy/OC_App.php line 207
OC\AppFramework\Bootstrap\Coordinator->bootApp()
11. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/legacy/OC_App.php line 140
OC_App::loadApp()
12. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/Files/SetupManager.php line 131
OC_App::loadApps()
13. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/Files/SetupManager.php line 339
OC\Files\SetupManager->setupBuiltinWrappers()
14. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/Files/SetupManager.php line 379
OC\Files\SetupManager->setupRoot()
15. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/Files/Mount/Manager.php line 95
OC\Files\SetupManager->setupForPath()
16. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/Files/View.php line 1386
OC\Files\Mount\Manager->find()
17. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/Files/Node/Root.php line 205
OC\Files\View->getFileInfo()
18. <<closure>>
OC\Files\Node\Root->get()
19. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/Files/Node/LazyFolder.php line 72
call_user_func_array()
20. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/Files/Node/LazyFolder.php line 149
OC\Files\Node\LazyFolder->__call()
21. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/Files/AppData/AppData.php line 141
OC\Files\Node\LazyFolder->get()
22. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/Template/JSCombiner.php line 88
OC\Files\AppData\AppData->getFolder()
23. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/Template/JSResourceLocator.php line 123
OC\Template\JSCombiner->process()
24. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/Template/JSResourceLocator.php line 76
OC\Template\JSResourceLocator->cacheAndAppendCombineJsonIfExist()
25. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/Template/ResourceLocator.php line 78
OC\Template\JSResourceLocator->doFind()
26. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/TemplateLayout.php line 377
OC\Template\ResourceLocator->find()
27. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/TemplateLayout.php line 205
OC\TemplateLayout::findJavascriptFiles()
28. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/legacy/OC_Template.php line 185
OC\TemplateLayout->__construct()
29. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/Template/Base.php line 132
OC_Template->fetchPage()
30. /home/eve/web/le.rez0.net/public_html/acces0nuage/lib/private/legacy/OC_Template.php line 334
OC\Template\Base->printPage()
31. /home/eve/web/le.rez0.net/public_html/acces0nuage/index.php line 74
OC_Template::printExceptionErrorPage()
PUT /index.php/apps/user_status/heartbeat
from 2a02:8440:5140:400:5c63:cea6:ae7d:a37a at 2022-08-17T01:07:12+00:00
The output of your config.php file in /path/to/nextcloud:
'instanceid' => '',
'passwordsalt' => '',
'secret' => '',
0 => 'localhost',
1 => 'domain.net',
2 => 'ip',
'datadirectory' => '/home/....',
'version' => '24.0.3.2',
'overwrite.cli.url' => 'https://domain.net',
'dbname' => '----
'dbhost' => 'localhost',
'dbuser' => '----
'dbpassword' => '-----',
'app_install_overwrite' =>
0 => 'documentserver_community',
'default_language' => 'fr',
'default_locale' => 'fr_FR',
'default_phone_region' => 'FR',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_from_address' => 'DOMAIN',
'mail_domain' => 'domain.net',
'mail_smtpauth' => 1,
'mail_smtphost' => 'mail.domain.net',
'mail_smtpport' => '465',
'mail_smtpname' => 'email@domain.net',
'mail_smtppassword' => '- - -',
'theme' => '',
'loglevel' => 0,
'redis' =>
'port' => 0,
'dbindex' => 0,
'password' => '',
'timeout' => 1.5,
The output of your Apache/
[Wed Aug 17 04:18:15.537453 2022] [suexec:notice] [pid 44805:tid 140076384196480] AH01232: suEXEC mechanism enab>
[Wed Aug 17 04:18:15.563040 2022] [ssl:warn] [pid 44806:tid 140076384196480] AH01909: 194.163.141.9:443:0 server>
[Wed Aug 17 04:18:15.566140 2022] [mpm_event:notice] [pid 44806:tid 140076384196480] AH00489: Apache/2.4.54 (Ubu>
[Wed Aug 17 04:18:15.566185 2022] [core:notice] [pid 44806:tid 140076384196480] AH00094: Command line: '/usr/sbi>
nginx/
2022/08/16 23:14:12 [warn] 108406#108406: "ssl_stapling" ignored, issuer certificate not found for certificate ">
2022/08/16 23:44:15 [warn] 1448#1448: "ssl_stapling" ignored, issuer certificate not found for certificate "/hom>
2022/08/17 01:25:08 [warn] 18924#18924: "ssl_stapling" ignored, issuer certificate not found for certificate "/h>
Some tiny small pics take more than 10sec to load:
So here is a little list of things that seem to really slow down the displaying of a page . .
I mentioned in another post the slowness of the dashboard (some cache config made it better tho)
I’d be happy to read your comments, and follow your lead if you think there is something to dig in here
. . i’m ready!
