Доброго времени суток!
Прошу помочь, подсказать, направить по следующей проблеме. После автообновления до версии 22.2.0snap2 посыпались ошибки в логах и на Windows-клиентах: Ошибка сервера при попытке прочитать каталог: Операция отменена.
Лог ниже
Doctrine\DBAL\Query\QueryException: More than 1000 expressions in a list are not allowed on Oracle.
- /var/snap/nextcloud/28586/nextcloud/extra-apps/groupfolders/lib/ACL/RuleManager.php - line 113:
OC\DB\QueryBuilder\QueryBuilder->execute() -
/var/snap/nextcloud/28586/nextcloud/extra-apps/groupfolders/lib/ACL/ACLManager.php - line 77:
OCA\GroupFolders\ACL\RuleManager->getRulesForFilesByPath() - /var/snap/nextcloud/28586/nextcloud/extra-apps/groupfolders/lib/ACL/ACLManager.php - line 118: OCA\GroupFolders\ACL\ACLManager->getRules()
- /var/snap/nextcloud/28586/nextcloud/extra-apps/groupfolders/lib/ACL/ACLCacheWrapper.php - line 98: OCA\GroupFolders\ACL\ACLManager->preloadPaths()
- /var/snap/nextcloud/28586/nextcloud/extra-apps/groupfolders/lib/ACL/ACLCacheWrapper.php - line 68: OCA\GroupFolders\ACL\ACLCacheWrapper->preloadEntries()
- /snap/nextcloud/28586/htdocs/lib/private/Files/Cache/Wrapper/CacheWrapper.php - line 103: OCA\GroupFolders\ACL\ACLCacheWrapper->getFolderContentsById()
- /snap/nextcloud/28586/htdocs/lib/private/Files/Cache/Wrapper/CacheWrapper.php - line 103: OC\Files\Cache\Wrapper\CacheWrapper->getFolderContentsById()
- /snap/nextcloud/28586/htdocs/lib/private/Files/View.php - line 1461: OC\Files\Cache\Wrapper\CacheWrapper->getFolderContentsById()
- /snap/nextcloud/28586/htdocs/apps/dav/lib/Connector/Sabre/Directory.php - line 264: OC\Files\View->getDirectoryContent()
- /snap/nextcloud/28586/htdocs/3rdparty/sabre/dav/lib/DAV/Tree.php - line 200: OCA\DAV\Connector\Sabre\Directory->getChildren()
- /snap/nextcloud/28586/htdocs/3rdparty/sabre/dav/lib/DAV/Server.php - line 900: Sabre\DAV\Tree->getChildren()
- /snap/nextcloud/28586/htdocs/3rdparty/sabre/dav/lib/DAV/Server.php - line 982: Sabre\DAV\Server->generatePathNodes()
- /snap/nextcloud/28586/htdocs/3rdparty/sabre/dav/lib/DAV/Server.php - line 1661: Sabre\DAV\Server->getPropertiesIteratorForPath()
- /snap/nextcloud/28586/htdocs/3rdparty/sabre/dav/lib/DAV/Server.php - line 1646: Sabre\DAV\Server->writeMultiStatus()
- /snap/nextcloud/28586/htdocs/3rdparty/sabre/dav/lib/DAV/CorePlugin.php - line 346: Sabre\DAV\Server->generateMultiStatus()
- /snap/nextcloud/28586/htdocs/3rdparty/sabre/event/lib/WildcardEmitterTrait.php - line 89: Sabre\DAV\CorePlugin->httpPropFind()
- /snap/nextcloud/28586/htdocs/3rdparty/sabre/dav/lib/DAV/Server.php - line 472: Sabre\DAV\Server->emit()
- /snap/nextcloud/28586/htdocs/3rdparty/sabre/dav/lib/DAV/Server.php - line 253: Sabre\DAV\Server->invokeMethod()
- /snap/nextcloud/28586/htdocs/3rdparty/sabre/dav/lib/DAV/Server.php - line 321: Sabre\DAV\Server->start()
- /snap/nextcloud/28586/htdocs/apps/dav/lib/Server.php - line 333: Sabre\DAV\Server->exec()
- /snap/nextcloud/28586/htdocs/apps/dav/appinfo/v2/remote.php - line 35: OCA\DAV\Server->exec()
- /snap/nextcloud/28586/htdocs/remote.php - line 166: require_once("/snap/nextc … p")
System: Ubuntu 20.04.2 LTS x86_64
Заранее благодарю!
