example
longer
example
here
Nextcloud version (eg, 18.0.2): 20.0.1 (docker-compose)
Operating system and version (eg, Ubuntu 20.04): Debian GNU/Linux 10 (buster)
Apache or nginx version (eg, Apache 2.4.25): nginx/1.14.2
PHP version (eg, 7.1): 7.4.12
I tried to change the background tasks setting to use Cron
. For this, I created another docker container in which the
Here is a snippet of my docker-compose.yml
nextcloud:
image: nextcloud
container_name: nextcloud
networks:
- nextcloud
ports:
- "127.0.0.1:8080:80"
volumes:
- ${NEXTCLOUD_ROOT}/html:/var/www/html
- ${NEXTCLOUD_ROOT}/data:/opt/nextcloud/data
extra_hosts:
- "${NEXTCLOUD_FQDN}:${NEXTCLOUD_IPADDRESS}"
- "${COLLABORA_FQDN}:${NEXTCLOUD_IPADDRESS}"
depends_on:
- mariadb
- redis
environment:
- NEXTCLOUD_TRUSTED_DOMAINS='${NEXTCLOUD_FQDN}'
- NEXTCLOUD_DATA_DIR=/opt/nextcloud/data
- MYSQL_DATABASE=${MYSQL_DATABASE}
- MYSQL_USER=${MYSQL_USER}
- MYSQL_PASSWORD=${MYSQL_PASSWORD}
- MYSQL_HOST=${MYSQL_HOST}
- REDIS_HOST=${REDIS_HOST}
- REDIS_HOST_PASSWORD=${REDIS_PASSWORD}
restart: unless-stopped
cron:
image: nextcloud
restart: always
volumes:
entrypoint: /cron.sh
depends_on:
- mariadb
- redis
networks:
- nextcloud
Log output for this cron container:
cron_1 | 2020-11-09T19:00:00.756923492Z crond: crond (busybox 1.30.1) started, log level 0
cron_1 | 2020-11-09T19:00:00.756948589Z crond: user:www-data entry:(null)
cron_1 | 2020-11-09T19:00:00.756950963Z 100001000010000100001000010000100001000010000100001000010000
cron_1 | 2020-11-09T19:00:00.756952927Z 111111111111111111111111
cron_1 | 2020-11-09T19:00:00.756954630Z 11111111111111111111111111111111
cron_1 | 2020-11-09T19:00:00.756957756Z 111111111111
cron_1 | 2020-11-09T19:00:00.756959369Z 1111111
cron_1 | 2020-11-09T19:01:00.757199354Z crond: user:www-data entry:(null)
cron_1 | 2020-11-09T19:01:00.757228800Z 100001000010000100001000010000100001000010000100001000010000
cron_1 | 2020-11-09T19:01:00.757231234Z 111111111111111111111111
cron_1 | 2020-11-09T19:01:00.757233088Z 11111111111111111111111111111111
cron_1 | 2020-11-09T19:01:00.757234891Z 111111111111
cron_1 | 2020-11-09T19:01:00.757237045Z 1111111
cron_1 | 2020-11-09T19:01:00.757238799Z crond: wakeup dt=60
cron_1 | 2020-11-09T19:01:00.757240562Z crond: file www-data:
cron_1 | 2020-11-09T19:01:00.757242355Z crond: line php -f /var/www/html/cron.php
cron_1 | 2020-11-09T19:02:00.757306747Z crond: wakeup dt=60
cron_1 | 2020-11-09T19:02:00.757325472Z crond: file www-data:
cron_1 | 2020-11-09T19:02:00.757327796Z crond: line php -f /var/www/html/cron.php
cron_1 | 2020-11-09T19:03:00.757446224Z crond: wakeup dt=60
cron_1 | 2020-11-09T19:03:00.757473535Z crond: file www-data:
cron_1 | 2020-11-09T19:03:00.757475859Z crond: line php -f /var/www/html/cron.php
cron_1 | 2020-11-09T19:04:00.757618548Z crond: wakeup dt=60
cron_1 | 2020-11-09T19:04:00.757647873Z crond: file www-data:
cron_1 | 2020-11-09T19:04:00.757650949Z crond: line php -f /var/www/html/cron.php
cron_1 | 2020-11-09T19:05:00.757767467Z crond: wakeup dt=60
cron_1 | 2020-11-09T19:05:00.757798646Z crond: file www-data:
cron_1 | 2020-11-09T19:05:00.757801531Z crond: line php -f /var/www/html/cron.php
cron_1 | 2020-11-09T19:05:00.757803715Z crond: job: 0 php -f /var/www/html/cron.php
cron_1 | 2020-11-09T19:05:00.757903222Z crond: child running /bin/bash
cron_1 | 2020-11-09T19:05:00.757992670Z crond: USER www-data pid 6 cmd php -f /var/www/html/cron.php
cron_1 | 2020-11-09T19:05:00.772297251Z Could not open input file: /var/www/html/cron.php
Do you have any idea what’s going on here?
Executing docker exec -it -u www-data nextcloud php -f /var/www/html/cron.php
manually is working fine…
nothing related to background tasks / cron
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'redis' =>
'host' => 'nextcloud-redis',
'password' => 'xxx',
'port' => 6379,
'instanceid' => 'xxx',
'passwordsalt' => 'xxx',
'secret' => 'xxx',
0 => 'xxx',
'datadirectory' => '/opt/nextcloud/data',
'version' => '20.0.1.1',
'overwrite.cli.url' => 'xxx',
'dbname' => 'nextcloud',
'dbhost' => 'nextcloud-mariadb',
'dbuser' => 'xxx',
'dbpassword' => 'xxx',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'tls',
'mail_from_address' => 'xxx',
'mail_domain' => 'xxx',
'mail_smtpauth' => 1,
'mail_smtphost' => 'xxx',
'mail_smtpport' => 'xxx',
'mail_smtpname' => 'xxx',
'mail_smtppassword' => 'xxx',
'twofactor_enforced' => 'false',
0 => 'admin',
'trusted_proxies' =>
1 => '127.0.0.1',
'overwritehost' => 'xxx',
'loglevel' => 2,
