Hi everybody,
Since i have migrated my Nextcloud 14 to Ubuntu 18.04 from Ubuntu 16.04 i cannot manage to make the images preview working on some extensions like TIF, RAW, or AI.
I tried a lot of things even launching my own php scripts with imagick which are working on the server.
It’s weird because it’s working with PNG or JPEG with Nextcloud.
Does someone encountered the same problems.
Nextcloud version : 14.0.4
Operating system and version : Ubuntu 18.04
Apache : 2.4
PHP version : 7.2
OCP\Files\NotFoundException:
/var/www/nextcloud-14.0.4/lib/private/Preview/Generator.php - line 118:
OC\Preview\Generator->getMaxPreview(OC\Files\Sim ... {}, OC\Files\Node\File {}, "image/x-dcraw")
/var/www/nextcloud-14.0.4/lib/private/PreviewManager.php - line 205:
OC\Preview\Generator->getPreview(OC\Files\Node\File {}, 200, 200, false, "fill", "image/x-dcraw")
/var/www/nextcloud-14.0.4/apps/gallery/lib/Service/PreviewService.php - line 106:
OC\PreviewManager->getPreview(OC\Files\Node\File {}, 200, 200, false)
/var/www/nextcloud-14.0.4/apps/gallery/lib/Controller/Preview.php - line 167:
OCA\Gallery\Service\PreviewService->createPreview(OC\Files\Node\File {}, 200, 200, true, false)
/var/www/nextcloud-14.0.4/apps/gallery/lib/Controller/Preview.php - line 117:
OCA\Gallery\Controller\PreviewController->getPreviewData(OC\Files\Node\File {}, true, 200, 200, true, false)
/var/www/nextcloud-14.0.4/apps/gallery/lib/Controller/PreviewController.php - line 134:
OCA\Gallery\Controller\PreviewController->getData(3623549, 200, 200)
/var/www/nextcloud-14.0.4/lib/private/AppFramework/Http/Dispatcher.php - line 166:
OCA\Gallery\Controller\PreviewController->getPreview(3623549, 200, 200)
/var/www/nextcloud-14.0.4/lib/private/AppFramework/Http/Dispatcher.php - line 99:
OC\AppFramework\Http\Dispatcher->executeController(OCA\Gallery\ ... {}, "getPreview")
/var/www/nextcloud-14.0.4/lib/private/AppFramework/App.php - line 118:
OC\AppFramework\Http\Dispatcher->dispatch(OCA\Gallery\ ... {}, "getPreview")
/var/www/nextcloud-14.0.4/lib/private/AppFramework/Routing/RouteActionHandler.php - line 47:
OC\AppFramework\App::main("PreviewController", "getPreview", OC\AppFramew ... {}, { fileId: "3 ... "})
OC\AppFramework\Routing\RouteActionHandler->__invoke({ fileId: "3 ... "})
/var/www/nextcloud-14.0.4/lib/private/Route/Router.php - line 297:
call_user_func(OC\AppFramew ... {}, { fileId: "3 ... "})
/var/www/nextcloud-14.0.4/lib/base.php - line 987:
OC\Route\Router->match("/apps/gallery/preview/3623549")
/var/www/nextcloud-14.0.4/index.php - line 42:
OC::handleRequest()
