Hi together,
I try to use the backup option via rsync over the NC web panel.
I have the following constelation:
- Raspbeery Pi 4 with an external HDD without SD-Card.
- Synology NAS system which I would like to rsync with
I mount the backup directory from the Synology system to the my raspberry with the following script:
sudo mount -t cifs -o credentials=/appdata/config/passwd-nas,uid=1000,gid=1000,dir_mode=0700,file_mode=0600,vers=1.0 //<IP synology system>/backup/raspberry /media/nasbackup
Then I configure that passwordless access for the users “root” and “pi”.
On the raspberry console it’s working fine to logon with root or pi over ssh
pi@chickencoop:~ $ ssh root@192.168.178.60Linux chickencoop 5.4.83-v7l+ #1379 SMP Mon Dec 14 13:11:54 GMT 2020 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Thu Jan 28 18:51:18 2021 from 192.168.178.60Wi-Fi is currently blocked by rfkill.
Use raspi-config to set the country before use.root@chickencoop:~#
root@chickencoop:~# ssh pi@192.168.178.60Linux chickencoop 5.4.83-v7l+ #1379 SMP Mon Dec 14 13:11:54 GMT 2020 armv7l
Last login: Thu Jan 28 17:44:25 2021 from 192.168.178.60Wi-Fi is currently blocked by rfkill.
And also rsync works without problems if I do it manual:
root@chickencoop:/home/pi# rsync -e 'ssh -p 22' -aAv /home/pi/ /media/nasbackup/nc_datasending incremental file list
.gnupg/
.gnupg/private-keys-v1.d/
.ssh/
rpi-clone/
rpi-clone/.git/
rpi-clone/.git/branches/
rpi-clone/.git/hooks/
rpi-clone/.git/info/
rpi-clone/.git/logs/
rpi-clone/.git/logs/refs/
rpi-clone/.git/logs/refs/heads/
rpi-clone/.git/logs/refs/remotes/
rpi-clone/.git/logs/refs/remotes/origin/
rpi-clone/.git/objects/
rpi-clone/.git/objects/info/
rpi-clone/.git/objects/pack/
rpi-clone/.git/refs/
rpi-clone/.git/refs/heads/
rpi-clone/.git/refs/remotes/
rpi-clone/.git/refs/remotes/origin/
rpi-clone/.git/refs/tags/sent 1,952 bytes received 211 bytes 4,326.00 bytes/sec
total size is 222,199 speedup is 102.73
But via the NC web panel I get the following message:
Where’s my thinking error or what do I’m wrong?
