Nextcloud version (eg, 20.0.5): 22.1.1 (via snap)
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4 (via snap – according to GitHub - nextcloud-snap/nextcloud-snap: ☁️📦 Nextcloud packaged as a snap)
PHP version (eg, 7.4): PhP 7.4 (via snap – according to https://github.com/nextcloud-snap/nextcloud-snap)
Enable the bundled matterbridge, connect the matterbridge to a matrix room on matrix.org. If I type a message on the NC-Talk side it shows up in the matrix room (via the Element app) as [nctalk] “example message”. However, if I type a message into the matrix room (via the Element app), then nothing shows up on the NC-Talk side. I expected a message to be shows by bridge-bot.
I have used two different room settings, the public #room:matrix.org and the “internal room address” Both had the same effect.
- Install and enable the bundled matterbridge app
- Enable matterbridge for a room, add a new matrix bridge
- Set the matrix room and login details
- Send test message from the NC talk room (and see it appear in the matrix room)
- Post a message in the matrix.org room (see nothing appear in the NC talk room)
From the Matterbridge log
time="2021-09-12T21:13:38Z" level=info msg="Running version 1.22.3 e45bbe45" prefix=main
time="2021-09-12T21:13:38Z" level=info msg="Parsing gateway myGateway" prefix=router
time="2021-09-12T21:13:38Z" level=info msg="Starting bridge: matrix.0 " prefix=router
time="2021-09-12T21:13:38Z" level=info msg="Connecting https://matrix.org" prefix=matrix
time="2021-09-12T21:13:38Z" level=info msg="Connection succeeded" prefix=matrix
time="2021-09-12T21:13:38Z" level=info msg="matrix.0: joining !baErXDzMymrfFMZTFD:matrix.org (ID: !baErXDzMymrfFMZTFD:matrix.orgmatrix.0)" prefix=matrix
time="2021-09-12T21:13:39Z" level=info msg="Starting bridge: nctalk.1 " prefix=router
time="2021-09-12T21:13:39Z" level=info msg=Connecting prefix=nctalk
time="2021-09-12T21:13:39Z" level=info msg=Connected prefix=nctalk
time="2021-09-12T21:13:39Z" level=info msg="nctalk.1: joining p65tuocw (ID: p65tuocwnctalk.1)" prefix=nctalk
time="2021-09-12T21:13:39Z" level=info msg="Gateway(s) started succesfully. Now relaying messages" prefix=main
From main admin logging
See
The config.php (set by snap):
'apps_paths' =>
0 =>
'path' => '/snap/nextcloud/current/htdocs/apps',
'url' => '/apps',
'writable' => false,
1 =>
'path' => '/var/snap/nextcloud/current/nextcloud/extra-apps',
'url' => '/extra-apps',
'writable' => true,
'supportedDatabases' =>
0 => 'mysql',
'redis' =>
'host' => '/tmp/sockets/redis.sock',
'port' => 0,
'log_type' => 'file',
'logfile' => '/var/snap/nextcloud/current/logs/nextcloud.log',
'logfilemode' => 416,
'passwordsalt' => 'yep, this was changed',
'secret' => 'yeah, this was changed too',
0 => 'localhost',
1 => 'nc.infinitylab.io',
'datadirectory' => '/var/snap/nextcloud/common/nextcloud/data',
'version' => '22.1.1.2',
'overwrite.cli.url' => 'http://localhost',
'dbname' => 'nextcloud',
'dbhost' => 'localhost:/tmp/sockets/mysql.sock',
'dbuser' => 'nextcloud',
'dbpassword' => 'yeah, this was changed',
'instanceid' => 'oc61z7wh99xd',
'default_phone_region' =>
1 => 'CA',
'mail_smtpmode' => 'smtp',
'mail_smtpauth' => 1,
'loglevel' => 2,
