Hello All,
so we have Nextcloud running on a VM w/ CentOS 6.8 and CODE running in a separate VM (Ubuntu 16.04 + docker + apache reverse proxy). The problem that we are having is that when we have multiple users collaborating on a document and someone tries to print it gets stuck and says “Downloading” at the bottom - the same behavior with the Export feature. We are trying to figure one or the two options:
- Is there a way to fix this issue and does anyone else have the same problem?
- Is there a way in NC to pass the option to Hide the Print and Export features to CODE
By the way, here is what the CODE docker image displays when opening a document - not sure if there is a way to pass the DisableExport and DisablePrint options:
wsd-00025-0028 23:26:36.603348 [ client_ws_0006 ] WRN Missing JSON property [HidePrintOption]| wsd/Storage.cpp:353
wsd-00025-0028 23:26:36.603421 [ client_ws_0006 ] WRN Missing JSON property [HideSaveOption]| wsd/Storage.cpp:353
wsd-00025-0028 23:26:36.603451 [ client_ws_0006 ] WRN Missing JSON property [HideExportOption]| wsd/Storage.cpp:353
wsd-00025-0028 23:26:36.603511 [ client_ws_0006 ] WRN Missing JSON property [EnableOwnerTermination]| wsd/Storage.cpp:353
wsd-00025-0028 23:26:36.603537 [ client_ws_0006 ] WRN Missing JSON property [DisablePrint]| wsd/Storage.cpp:353
wsd-00025-0028 23:26:36.603562 [ client_ws_0006 ] WRN Missing JSON property [DisableExport]| wsd/Storage.cpp:353
wsd-00025-0028 23:26:36.603704 [ client_ws_0006 ] WRN Missing JSON property [DisableCopy]| wsd/Storage.cpp:353
wsd-00025-0028 23:29:02.963868 [ client_ws_0006 ] WRN SocketProcessor [client_ws_0006]: Connection closed.| common/IoUtil.cpp:100
wsd-00025-0028 23:29:07.964248 [ client_ws_0006 ] ERR Auto-save before closing failed.| wsd/LOOLWSD.cpp:984
wsd-00025-0026 23:51:13.682909 [ client_ws_0008 ] WRN Missing JSON property [HidePrintOption]| wsd/Storage.cpp:353
wsd-00025-0026 23:51:13.683015 [ client_ws_0008 ] WRN Missing JSON property [HideSaveOption]| wsd/Storage.cpp:353
wsd-00025-0026 23:51:13.683053 [ client_ws_0008 ] WRN Missing JSON property [HideExportOption]| wsd/Storage.cpp:353
wsd-00025-0026 23:51:13.683090 [ client_ws_0008 ] WRN Missing JSON property [EnableOwnerTermination]| wsd/Storage.cpp:353
wsd-00025-0026 23:51:13.683129 [ client_ws_0008 ] WRN Missing JSON property [DisablePrint]| wsd/Storage.cpp:353
wsd-00025-0026 23:51:13.683176 [ client_ws_0008 ] WRN Missing JSON property [DisableExport]| wsd/Storage.cpp:353
wsd-00025-0026 23:51:13.683215 [ client_ws_0008 ] WRN Missing JSON property [DisableCopy]| wsd/Storage.cpp:353
thanks.
