Hello
On updating to Nextcloud AIO v4.6.2 on my RPi4 using the latest-arm64 channel, my installation got caught in a restarting loop with the Apache container log gives
Waiting for Nextcloud to start…
and the Database container log states
The database import failed. Please restore a backup and try again.
and the Nextcloud container says
nc: getaddrinfo: Name does not resolve
Waiting for database to start…
On googeling a bit I got the impression that it was all related to the fulltext search app, and I tried to disable it by
sudo docker exec --user www-data -it nextcloud-aio-nextcloud php occ app:disable fulltextsearch
This gave
Doctrine\DBAL\Exception: Failed to connect to the database: An exception occurred in the driver: SQLSTATE[08006] [7] could not translate host name "nextcloud-aio-database" to address: Name does not resolve in /var/www/html/lib/private/DB/Connection.php:139
Stack trace:
#0 /var/www/html/3rdparty/doctrine/dbal/src/Connection.php(1519): OC\DB\Connection->connect()
#1 /var/www/html/3rdparty/doctrine/dbal/src/Connection.php(1041): Doctrine\DBAL\Connection->getWrappedConnection()
#2 /var/www/html/lib/private/DB/Connection.php(261): Doctrine\DBAL\Connection->executeQuery('SELECT * FROM "...', Array, Array, NULL)
#3 /var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php(345): OC\DB\Connection->executeQuery('SELECT * FROM "...', Array, Array)
#4 /var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php(281): Doctrine\DBAL\Query\QueryBuilder->execute()
#5 /var/www/html/lib/private/AppConfig.php(415): OC\DB\QueryBuilder\QueryBuilder->execute()
#6 /var/www/html/lib/private/AppConfig.php(180): OC\AppConfig->loadConfigValues()
#7 /var/www/html/lib/private/AppConfig.php(371): OC\AppConfig->getApps()
#8 /var/www/html/lib/private/legacy/OC_App.php(965): OC\AppConfig->getValues(false, 'installed_versi...')
#9 /var/www/html/lib/private/Server.php(725): OC_App::getAppVersions()
#10 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(162): OC\Server->OC\{closure}(Object(OC\Server))
#11 /var/www/html/3rdparty/pimple/pimple/src/Pimple/Container.php(122): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#12 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(129): Pimple\Container->offsetGet('OC\\Memcache\\Fac...')
#13 /var/www/html/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query('OC\\Memcache\\Fac...', false)
#14 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(57): OC\ServerContainer->query('OC\\Memcache\\Fac...')
#15 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(184): OC\AppFramework\Utility\SimpleContainer->get('OC\\Memcache\\Fac...')
#16 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(162): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(OC\Server))
#17 /var/www/html/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#18 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(129): Pimple\Container->offsetGet('OCP\\ICacheFacto...')
#19 /var/www/html/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query('OCP\\ICacheFacto...', false)
#20 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(57): OC\ServerContainer->query('OCP\\ICacheFacto...')
#21 /var/www/html/lib/private/Server.php(1119): OC\AppFramework\Utility\SimpleContainer->get('OCP\\ICacheFacto...')
#22 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(162): OC\Server->OC\{closure}(Object(OC\Server))
#23 /var/www/html/3rdparty/pimple/pimple/src/Pimple/Container.php(122): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#24 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(129): Pimple\Container->offsetGet('OCP\\Lock\\ILocki...')
#25 /var/www/html/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query('OCP\\Lock\\ILocki...', false)
#26 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(57): OC\ServerContainer->query('OCP\\Lock\\ILocki...')
#27 /var/www/html/lib/private/Server.php(2070): OC\AppFramework\Utility\SimpleContainer->get('OCP\\Lock\\ILocki...')
#28 /var/www/html/lib/private/Files/View.php(117): OC\Server->getLockingProvider()
#29 /var/www/html/lib/private/Server.php(462): OC\Files\View->__construct()
#30 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(162): OC\Server->OC\{closure}(Object(OC\Server))
#31 /var/www/html/3rdparty/pimple/pimple/src/Pimple/Container.php(122): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#32 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(129): Pimple\Container->offsetGet('OC\\Files\\Node\\H...')
#33 /var/www/html/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query('OC\\Files\\Node\\H...', false)
#34 /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php(57): OC\ServerContainer->query('OC\\Files\\Node\\H...')
#35 /var/www/html/lib/private/Server.php(1472): OC\AppFramework\Utility\SimpleContainer->get('OC\\Files\\Node\\H...')
#36 /var/www/html/lib/base.php(617): OC\Server->boot()
#37 /var/www/html/lib/base.php(1144): OC::init()
#38 /var/www/html/console.php(48): require_once('/var/www/html/l...')
#39 /var/www/html/occ(11): require_once('/var/www/html/c...')
Any ideas?
Thanks
/Andreas
