Nc-aio stuck loading redis
    • Unraid 7.2.3
    • Aio v 12.3.0
    • Cloudflared tunnel
Nc-aio master container is failing to start the next cloud container, which appears to be being caused by redis throwing an error
#### 2026-01-12T02:09:47.585947956Z Memory overcommit is disabled but necessary for safe operation
2026-01-12T02:09:47.585980567Z See https://github.com/nextcloud/all-in-one/discussions/1731 how to enable overcommit
2026-01-12T02:09:47.585983392Z Redis has started
2026-01-12T02:09:47.596294248Z 7:C 12 Jan 2026 02:09:47.596 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being disabled, it can also cause failures without low memory condition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
2026-01-12T02:09:47.600050516Z 7:M 12 Jan 2026 02:09:47.600 # Short read or OOM loading DB. Unrecoverable error, aborting now.
2026-01-12T02:09:47.600062799Z 7:M 12 Jan 2026 02:09:47.600 # Internal error in RDB reading offset 0, function at rdb.c:3714 -> Unexpected EOF reading RDB file
2026-01-12T02:09:47.601471362Z \[offset 0\] Checking RDB file dump.rdb
2026-01-12T02:09:47.601481461Z \[offset 26\] AUX FIELD redis-ver = '8.2.3'
2026-01-12T02:09:47.601483464Z \[offset 40\] AUX FIELD redis-bits = '64'
2026-01-12T02:09:47.601484917Z \[offset 52\] AUX FIELD ctime = '1767391714'
2026-01-12T02:09:47.601486149Z \[offset 67\] AUX FIELD used-mem = '2246088'
2026-01-12T02:09:47.601487302Z \[offset 79\] AUX FIELD aof-base = '0'
2026-01-12T02:09:47.601488544Z \[offset 81\] Selecting DB ID 0
2026-01-12T02:09:47.601489706Z --- RDB ERROR DETECTED ---
2026-01-12T02:09:47.601490858Z \[offset 495616\] Unexpected EOF reading RDB file
2026-01-12T02:09:47.601492040Z \[additional info\] While doing: read-key
2026-01-12T02:09:47.601493203Z \[additional info\] Reading type 0 (string)
2026-01-12T02:09:47.601494375Z \[info\] 846 keys read
2026-01-12T02:09:47.601495607Z \[info\] 844 expires
2026-01-12T02:09:47.601497491Z \[info\] 837 already expired
2026-01-12T02:09:47.601499434Z \[info\] 0 subexpires
Hi, first of all I would recommend that you follow the instructions below. Maybe this fixes your problem already:
I followed the steps on that link, and verified that the file is there with that flag set, but I am still getting the same errors each time it reboots
Hm, can you stop the containers via the AIO interface, run sudo docker rm nextcloud-aio-redis; sudo docker volume rm nextcloud_aio_redis and start the containers again via the AIO interface and check if that helps?
That seems to have resolved the memory overcommit bit, but the logs are showing redis still isn’t happy, and NC is still waiting for it before launching
2026-01-12T21:32:56.227538834Z Redis has started
2026-01-12T21:32:56.235483345Z 7:M 12 Jan 2026 21:32:56.235 # Short read or OOM loading DB. Unrecoverable error, aborting now.
2026-01-12T21:32:56.235497952Z 7:M 12 Jan 2026 21:32:56.235 # Internal error in RDB reading offset 0, function at rdb.c:3714 -> Unexpected EOF reading RDB file
2026-01-12T21:32:56.236708121Z [offset 0] Checking RDB file dump.rdb
2026-01-12T21:32:56.236709974Z [offset 26] AUX FIELD redis-ver = '8.2.3'
2026-01-12T21:32:56.236711407Z [offset 40] AUX FIELD redis-bits = '64'
2026-01-12T21:32:56.236712689Z [offset 52] AUX FIELD ctime = '1767391714'
2026-01-12T21:32:56.236713892Z [offset 67] AUX FIELD used-mem = '2246088'
2026-01-12T21:32:56.236715104Z [offset 79] AUX FIELD aof-base = '0'
2026-01-12T21:32:56.236716416Z [offset 81] Selecting DB ID 0
2026-01-12T21:32:56.236717759Z --- RDB ERROR DETECTED ---
2026-01-12T21:32:56.236718981Z [offset 495616] Unexpected EOF reading RDB file
2026-01-12T21:32:56.236720213Z [additional info] While doing: read-key
2026-01-12T21:32:56.236721406Z [additional info] Reading type 0 (string)
2026-01-12T21:32:56.236722618Z [info] 846 keys read
2026-01-12T21:32:56.236723820Z [info] 844 expires
2026-01-12T21:32:56.236725093Z [info] 837 already expired
2026-01-12T21:32:56.236726315Z [info] 0 subexpires
I still can’t seem to make any progress on this, even doing a restore isn’t helping, it seems like in order to do anything to the redis db, I need redis to start properly, but as its not starting, I Can’t seem to get a terminal up on it to try and delete the database or anything like that.
Last option is fully pave and reinstall, but I would really rather avoid that as its going to be a giant pain getting my parents to migrate to a new instance!
There should be a new release available since today. Can you upgrade and check if that resolves your issues?
The update by itself didn’t fix it, but running
after the update did manage to solve the issue, thanks for all the help!
