NC 35.0.2 Code Integrity Error - seq-009.lock
    • 35.0.2
    • Linux
    • Apache
    • 8.4
    • Yes
    • After updating to NC 25.0.x
    • Shared hosting one-click-installation
In the administration panel, I’m getting an code integrity error regarding the file
tmp/sfi_file_sequence_xxxxxxxxxxx/seq-009.lock
tmp/sfi_file_sequence_xxxxxxxxxxxx/seq-009.lock] => Array
                            [expected] =>
                            [current] => bb0fbec93af3af1e9631f848682849802645aa2c16fdba307969cc2674d9db75db06849f0be60446379680daabfe8788d582138e6e8e2852fd2decfbeeb0a051
Deleting the file seq-009.lock removes the message, but the file ist generated again and so is the error message…
  1. Update NC to 35.0.x
PASTE HERE
Thank you for help or explanation of this issue!
Looks like your temp folder is inside the Nextcloud folder? These files are usually created when ACPu is not available to have correctly sequenced snowflake ids. That’s generally fine (the files), but temp shouldn’t be within the Nextcloud folder. Additionally you might want to consider APCu
Thank you, your offer to help is very much appreciated!
First of all, I have to confess that I’m no programmer, I just run a preconfigured “one-click-installation-NC” on my shared webspace at all-inkl.com.
Indeed my temp folder is located inside the nextcloud folder, so when I delete it (which I actually have to do every time I update NC to a new version since the installer is very much annoyed by its existence) my log is flooded with
[no app in context] Warnung: Temporary directory /www/htdocs/w1234567/my-domain.de/cloud/tmp/ is not present or writable
These messages do of course stop to appear when I create the tmp directory inside of my cloud directory.
So that probably means that I’m not able to change the path of the temp directory from
to
my-domain.de/tmp/
or am I? In which configuration file is this path specified? Is this something I can modify myself in a NC file or am I at the mercy of my hosting company here?
Thanks,
Ralph
Ha, I managed to pull myself out of the swamp by asking a search engine! :slight_smile:
I found that I CAN specify the temp directory myself in
my.domain/cloud/config/config.php
I moved the tmp directory one level higher (i.e. outside of the cloud directory) and bingo, it worked and the code integrity error does not show up anymore.
Thank you for putting me on the right way to go!
Regards,
Ralph
