Nextcloud version 21.0.0
Operating system and version FreeBSD 11.4
Apache or nginx version Apache 2.4.46
PHP version 7.4.15
Is this the first time you’ve seen this error? Y:
- Install NC 21
- Select Activity app - displaying rotating circle with no result
{"reqId":"oAM5ppLpoaCr16465kie","level":3,"time":"2021-03-04T11:29:11+00:00","remoteAddr":"192.168.65.32","user":"0000","app":"no app in context","method":"GET","url":"/ocs/v2.php/apps/activity/api/v2/activity/all?format=json&previews=true&since=0","message":{"Exception":"Exception","Message":"Argument 1 passed to OCA\\Activity\\Controller\\APIv2Controller::getPreviewLink() must be of the type string, bool given, called in /usr/local/www/nextcloud/apps-pkg/activity/lib/Controller/APIv2Controller.php on line 398","Code":0,"Trace":[{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/App.php","line":157,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Route/Router.php","line":302,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/usr/local/www/nextcloud/ocs/v1.php","line":63,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/usr/local/www/nextcloud/ocs/v2.php","line":24,"args":["/usr/local/www/nextcloud/ocs/v1.php"],"function":"require_once"}],"File":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","Line":159,"Previous":{"Exception":"TypeError","Message":"Argument 1 passed to OCA\\Activity\\Controller\\APIv2Controller::getPreviewLink() must be of the type string, bool given, called in /usr/local/www/nextcloud/apps-pkg/activity/lib/Controller/APIv2Controller.php on line 398","Code":0,"Trace":[{"file":"/usr/local/www/nextcloud/apps-pkg/activity/lib/Controller/APIv2Controller.php","line":398,"function":"getPreviewLink","class":"OCA\\Activity\\Controller\\APIv2Controller","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/activity/lib/Controller/APIv2Controller.php","line":356,"function":"getPreviewFromPath","class":"OCA\\Activity\\Controller\\APIv2Controller","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/activity/lib/Controller/APIv2Controller.php","line":304,"function":"getPreview","class":"OCA\\Activity\\Controller\\APIv2Controller","type":"->"},{"file":"/usr/local/www/nextcloud/apps-pkg/activity/lib/Controller/APIv2Controller.php","line":209,"function":"get","class":"OCA\\Activity\\Controller\\APIv2Controller","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":218,"function":"getFilter","class":"OCA\\Activity\\Controller\\APIv2Controller","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":127,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/App.php","line":157,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Route/Router.php","line":302,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/usr/local/www/nextcloud/ocs/v1.php","line":63,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/usr/local/www/nextcloud/ocs/v2.php","line":24,"args":["/usr/local/www/nextcloud/ocs/v1.php"],"function":"require_once"}],"File":"/usr/local/www/nextcloud/apps-pkg/activity/lib/Controller/APIv2Controller.php","Line":416},"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (Windows NT 10.1; rv:52.0) Gecko/20100101 Firefox/52.0","version":"21.0.0.18","id":"6040c491865b4"}
'apps_paths' =>
0 =>
'path' => '/usr/local/www/nextcloud/apps',
'url' => '/apps',
'writable' => true,
1 =>
'path' => '/usr/local/www/nextcloud/apps-pkg',
'url' => '/apps-pkg',
'writable' => false,
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'dbindex' => 0,
'instanceid' => '*************',
'passwordsalt' => '*************',
'secret' => '**************',
0 => '*',
'datadirectory' => '/data/nextcloud',
'version' => '21.0.0.18',
'overwrite.cli.url' => 'https://nc21.*************',
'dbname' => 'NC21TEST',
'dbhost' => 'localhost:/tmp/mysql.sock',
'dbuser' => 'oc_00001',
'dbpassword' => '**************************',
'has_internet_connection' => false,
'updatechecker' => false,
'appstoreenabled' => false,
'mail_smtpmode' => 'smtp',
'mail_send_plaintext_only' => true,
'trusted_proxies' =>
0 => '192.168.68.0/24',
'overwritecondaddr' => '^192\\.168\\.68\\.[0-9]+$',
'log_rotate_size' => 67108864,
'ldapIgnoreNamingRules' => false,
'enable_previews' => false,
'trashbin_retention_obligation' => 'auto,5',
'logtimezone' => 'UTC',
'log_query' => false,
'loglevel' => 1,
'filesystem_check_changes' => 1,
'theme' => '',
'skeletondirectory' => '',
'data-fingerprint' => '********************',
'defaultapp' => 'files',
